Idle issues - JeepForum.com
post #1 of 22 Old 05-07-2015, 03:04 PM Thread Starter
CatfishsLJ
Idle issues
I have a 2004 unlimited, when driving while going a steady speed I sometimes get a push of power and accelerate even though I didn't hit the gas at all, also when I am driving and let off the gas to go brake or turn my RPMs drop to almost 0 (I have stalled twice my friend helping me diagnose the problem stalled it 3 times). It will drop fast to around 100 RPM and go back up to the normal idle RPM of 700/800 around there. I could use some help please.
CatfishsLJ is offline
post #2 of 22 Old 05-08-2015, 03:29 AM Thread Starter
CatfishsLJ
Guys please help me I am at a dead end
post #3 of 22 Old 05-08-2015, 03:40 AM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Do you have a CEL/MIL showing?...
Knuckelhead is offline
post #4 of 22 Old 05-08-2015, 04:20 PM Thread Starter
CatfishsLJ
CEL says bad thortal position sensor high circuit I replaced the TPS gave it a test drive was still stalking on low rpms under 1500 but now I think it might be transmission related but I don't know much.
post #5 of 22 Old 05-08-2015, 05:43 PM
chevy2169
What is the code?
Some say a comet will fall from the sky.
Followed by meteor showers and tidal waves.
Followed by faultlines that cannot sit still.
Followed by millions of dumbfounded dip****s.
chevy2169 is offline
post #6 of 22 Old 05-09-2015, 01:38 AM Thread Starter
CatfishsLJ
Originally Posted by chevy2169 View Post
What is the code?
P0123 and a random Evap code that's been on it since I've gotten it
post #7 of 22 Old 05-10-2015, 10:20 AM
chevy2169
1. Check the Throttle Position Sensor (TPS). Unplug the TPS connector and check the signal wire for 5 volts.
2. If OK, jumper the signal wire to the sensor ground and it should go to near 0 volts if the sensor ground is good.
3. Check the 5 volt reference wire.
4. If the wiring is OK, replace the TPS.
post #8 of 22 Old 05-14-2015, 07:46 AM Thread Starter
CatfishsLJ
The TPS signal wire is getting 5 volts but it's flashing (not steady current) (also reading wires awesome my sort of task) I don't see any damage on connectors no reason for a wire to break but it is definitely shorting. What now?
post #9 of 22 Old 05-14-2015, 11:41 AM
chevy2169
I believe the signal wire is supposed to pulse. The 5 volt reference wire should be a steady voltage.
You could check voltage drops to be sure. Just check voltage at different positions of the wire.
post #10 of 22 Old 05-14-2015, 09:18 PM Thread Starter
CatfishsLJ
Just an idea I took it in to a mechanic I know just to get a face to face opinion he read the codes did a diagnosis for me this is what he said, "found two codes p0123, p1596, voltage to TPS is flashing 5 volts, volts will not change even when unplugged. Believe it is a short or ECM problem. Also dirt/mud in ADAL connector (no idea what this is) possible water damage recommend dealer."
I did have this issue after pressure washing the engine block so that's the full story hit me with your inputs
post #11 of 22 Old 05-15-2015, 10:15 AM
chevy2169
Just an idea I took it in to a mechanic I know just to get a face to face opinion he read the codes did a diagnosis for me this is what he said, "found two codes p0123, p1596, voltage to TPS is flashing 5 volts, volts will not change even when unplugged. Believe it is a short or ECM problem. Also dirt/mud in ADAL connector (no idea what this is) possible water damage recommend dealer." I did have this issue after pressure washing the engine block so that's the full story hit me with your inputs
Maybe the PCM/ECM ended up getting wet when you sprayed the engine. Sometimes time is worth more than money, so you may consider the dealer like your mechanic suggested. They'll find it.
post #12 of 22 Old 05-16-2015, 04:55 AM Thread Starter
CatfishsLJ
Thanks man I am out of options so dealer it is I guess
post #13 of 22 Old 05-16-2015, 08:43 PM
ElDuderino762
Did you unnplug the clockspring and see if it quits?
ElDuderino762 is offline
post #14 of 22 Old 05-27-2015, 06:15 PM Thread Starter
CatfishsLJ
whats the clockspring and how could it stop it? if it does what do I need to change?
post #15 of 22 Old 05-28-2015, 09:15 PM
ElDuderino762
The clockspring is behind the steering wheel. Take off the plastic around the steering column and disconnect it. I think you can also just unplug the horn relay to test it too, but im not 100% sure on that. It sounds crazy, but that clockspring will short out and backfeed the tps causing the 123 code.
engine , idle , lj , rpm
