Idle air control valve cleaning - JeepForum.com
post #1 of 13 Old 11-11-2008, 09:57 PM Thread Starter
unlimited4x4
Would a dirty IAC cause the jeep to idle lower than normal? If so, how do you clean the IAC valve?
Thanks
05 Unlimited 4x4
I don't want to take Mommy's car. It doesn't have sky in it like Daddy's. - CJsPerson
unlimited4x4 is offline
post #2 of 13 Old 11-11-2008, 10:23 PM
LJameson
Yes, it could. Do a search for cleaning the IAC valve and you'll find lots of threads about it.
1990 YJ
LJameson is offline
post #3 of 13 Old 11-12-2008, 04:30 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
TheBoogieman is offline
post #4 of 13 Old 11-12-2008, 05:45 AM Thread Starter
unlimited4x4
Thanks guys, I swear, the JF needs to have a Ask Jerry Room in here. The man is a genius.
05 Unlimited 4x4
post #5 of 13 Old 12-06-2010, 12:00 PM
Dgroper
What about a sudden drop in rpms when you shift out of gear coming to a stop, and I mean almost stalling out and not just the normal drop when you take it out of gear haha? Would this be related to the IAC as well? Sorry if this is a dumb question I'm still kinda new to this. Any help is greatly appreciated!
Dgroper is offline
post #6 of 13 Old 12-06-2010, 12:05 PM
SpaceWrangler
Gnarly Adventurer
SpaceWrangler's Avatar
Location: Where the Girls Dance Different With Familiar Grace
This thread is a pretty good How-To...
http://www.jeepforum.com/forum/f9/cl.../#post10277503
"It always seems impossible until it is done." -Nelson Mandela
SpaceWrangler is offline
post #7 of 13 Old 12-06-2010, 09:14 PM
Dgroper
Thanks SpaceWrangler...appreciate it a lot!
Dgroper is offline
post #8 of 13 Old 01-03-2011, 03:20 PM
jensjeep
I have a 98 Jeep Grand Cherokee Laredo L6 4.0 and Ive been having problems with my jeep stalling, sputtering and high idleing and has backfired 3 times. My jeep has done this while driving doesnt matter if it's 55mph or 35mph. Sitting at a light or idleing in the driveway. At first it ony did it sparratically then after replacing the MAP sensor and the Ignition coil it was worse ( only replaced because codes pulled said they were bad) anyway after it got worse we decided that maybe it was the fuel pump/filter so we replaced that. The problem returned again stalling and sputtering high idle no backfires though. Did a tune up on it spark plugs, wire, distibutor cap, distributor rotor and we were still having the same problem it would stall and high idle and sputter but only slighty less than it did after replacing the MAP sensor and ignition coil. We just replaced the air filter and the TP sensor and cleaned the throttle body and IAC Valve now the only problem we seem to be having is it stalling while its in park. My husband removed the IAC Valve connection and said he hasnt had any problems with it. I beleive its too soon to tell. could this be the problem. We had the codes pulled again and the check engine light was on saying that it was the TP sensor and the throttle body was dirty and the IAC Valve might be bad. Ive also read that it might be the computer im not sure what to do? Can you tell me how to clean the IAC Valve? Any insight would be helpful.
jensjeep is offline
post #9 of 13 Old 01-21-2011, 02:21 PM
johnny9
my jeep acted like it had a racing cam today when i started it up..shut it down and ran fine next time..has been giving me longer starts for the past 6 months and was afraid it was fuel pump related..
cleaned the iac valve a few minutes ago and wow,,starts up fast again..tryed it a few times and definitly made a big diffrence in starting my jeep..
JACK OF ALL TRADES,,,MASTER OF NONE
fla cracker head born and bred
build-
johnny9 is offline
post #10 of 13 Old 08-15-2011, 09:14 PM
JeepChic
IAC cleaning
OK I see that some of these replies are old BUT: I am having major issues w/ the newly named 'Christine' sitting in my driveway...just glad I got her home. Anyway....this is a chic that has no clue about cars but not afraid to get dirty and can follow directions...is this something(cleaning IAC) a 'no car knowledge' chic can handle? Only have about 4 hours total to complete...posts say about 1 1/2 hrs but figured I would add chic time
Have been having idle/check engine/don't want to start issues for some time....figure she got REALLY pissed cause I looked at a 2005 Volvo this past weekend.....
JeepChic is offline
post #11 of 13 Old 03-05-2013, 09:18 PM
irishff903
1997 YJ Wrangler
Idling at 2000 2500
I have a 1997 YJ and its idles high. I have no idea what it could be. I am told to check intake manifold and it could be TPS and the IAC. what should my first move be?
irishff903 is offline
post #12 of 13 Old 03-05-2013, 09:27 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
1997 Jeep Wranglers are TJ's.
How high is the idle?...
Knuckelhead is offline
post #13 of 13 Old 03-06-2013, 05:27 AM
tjindiana
2015 JK Wrangler
That would make it easier for Jerry. He wouldn't have to troll every thread.
tjindiana is offline
Adjusting the IAC - Idle Air Control valve CJHVN YJ Wrangler Technical Forum 11 12-05-2012 05:19 AM
tips on cleaning the egr valve mtn_wrangler YJ Wrangler Technical Forum 3 07-22-2008 02:19 PM
Higher idle after IAC cleaning? nbf6165 TJ Wrangler Technical Forum 6 01-22-2008 01:26 PM
idle air control valve Why J? YJ Wrangler Technical Forum 0 08-09-2005 12:05 PM
How do you remove the Idle Air Control Valve? 92GTX YJ Wrangler Technical Forum 3 02-13-2003 06:53 AM
