Idle Air Control - JeepForum.com
post #1 of 2 Old 07-10-2006, 09:59 AM Thread Starter
FLATFENDER54
FLATFENDER54's Avatar
Idle Air Control
I read in another post that you can remove and clean the Idle air control. I searched this in the posts but found "almost" nothing -Is it easy to clean the idle air control motor - what would you suggest you clean it with? I know some things are not supposed to be cleaned. Any tips for removing it and what should I look for?
FLATFENDER54 is offline
post #2 of 2 Old 07-10-2006, 10:40 AM
98JEEPTJ
2005 WK
Pull it off and blast it with Throttle Body cleaner. Worked pretty good for me. Try cleaning up the whole throttle body to just use liberal amounts and just soak the crap out of it and don't be afraid to get to much on there.
OUT WITH THE OLD R.I.P. 98 TJ Sport 4" Procomp lift/adjustable lower control arms and track bar **** Cepek FCII 33x12.50x15/**** Cepek DC-1 wheels
IN WITH THE NEW 05 WK LIMITED EDITION 5.7L
98JEEPTJ is offline
Seeking new Idle Air Control and TPS 89jeepnut YJ Wrangler Technical Forum 5 03-02-2010 07:16 AM
Anyone have an idle air control pic? thefear YJ Wrangler Technical Forum 4 11-14-2007 05:54 PM
TJ idle-up control Jockorock TJ Wrangler Technical Forum 1 09-07-2007 03:11 PM
Idle Air Control Mod 2003Rubi TJ Wrangler Technical Forum 3 08-01-2007 05:50 AM
Idle air control Bob1 TJ Wrangler Technical Forum 1 12-13-2006 10:01 PM
