idk what kind of extras i need with a lift kit
| Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line | DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97- | GR8TOPS Introduces the Exogate HD Tire Carrier |
#1 | |
i was thinking about getting the 2.5 RC progressive rate coils it seems to be a good lift and a good price i was wondering if besides the coils and shocks if there is anything else i should get that would be a good idea such as rear trac bar relocation? t-case drop? sye? also would it be better to install a 1" BL or a 1" coil spring spacers? i want to run 33" tires
#2 |
I am currently searching for a lift myself, enough to fit 33"s, and I have almost decided on this lift. I'm going with the combo option they offer, comes w/ that 2.5" lift, 1.25" BL, and transfer case spacers. I tried finding out more info and I think this is all that will be necesary but I'm not 100% sure yet. Good luck!
#3 |
ya i have read alot about the lift and it seems really good i just would rather get everything i need to get and install it all at once instead of forgetting something and haveing to get back under there and i hear the back axle can shift alot thats why i am wondering about the trac bar relocation bracket
#4 |
http://www.dpgoffroad.com/TJ_LJ_OME_Kits.htm
talk to dirk at DPG. his lifts are designed for what you guys are looking for. great lifts too. and not to mention dirks a great guy. |
#5 |
what are the prices for dirks lifts??? i can get the RC 2.5 with shocks for 289 and with a 1.25" BL for 389 which is alot cheaper than anything i have seen
#6 |
You can get a 2" BB and run 33's. I ran one like that for years till I went with the RE superflex kit. Save the $ and don't buy the RC kit. Do your lift once!
#7 |
the prices are on the website underneath the kits. If i were you i would save up and buy the deluxe kit. this is a complete kit that comes with OME shocks, springs, 1.25 BL, 1.25 MML, extended bump stops, rear trackbar relocation bracket, and JKS Quicker discos. to me its a better bang for your buck if your lifting your rig. with using this kit you wont need the SYE/CV to get rid of vibes. the way dirk designed these kits was to utilize stock suspension angles. and for $855.00 your getting a pretty good deal. you can run up to 33's and you dont have to worry. give him a call atalk to him about what you're trying to do and he can help you out.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
