Idiotic questions. Avoiding stress on the clutch while off roading? - JeepForum.com
post #1 of 19 Old 04-16-2011, 04:22 PM Thread Starter
JCJeep97
So. . . .
Dumb question. Is there any way to help avoid the stress on the clutch while off roading? I ride it quite a bit when I crawl, even in four low. Any tips to keep my **** from getting worn out faster than it already will?
JCJeep97 is offline
post #2 of 19 Old 04-16-2011, 04:28 PM
robncar
robncar's Avatar
Lower gears, but you know this...
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #3 of 19 Old 04-16-2011, 04:31 PM
freedommachine
2016 JK Wrangler
E-brake. It can help you from rolling backwards or forwards so you are not trying to hit the clutch, gas, brake all at the same time.
In memory of JF member: mrknowitall666
Rest in peace brother- wounded warrior find your peace
freedommachine is offline
post #4 of 19 Old 04-16-2011, 04:41 PM
tchaap
There are times when feathering the clutch is just something that is necessary...a necessary evil I guess you could say with a manual. And, the clutch is a wear item, it is eventually going to wear out.
However, you would see a huge difference if you re-geared. 3.73's with 35's is pretty high but I think you already know this.
TC
Crawling For Reid March 3-5, 2017 Adventure Off-road Park
tchaap is offline
post #5 of 19 Old 04-16-2011, 04:58 PM
BlueFlame
BlueFlame's Avatar
Originally Posted by JCJeep97 View Post
So. . . .
Learn not to ride it so much? Choose the correct gear and keep your foot off that clutch.
BlueFlame is offline
post #6 of 19 Old 04-16-2011, 06:30 PM
wushaw
Rockin jeep
wushaw's Avatar
I have 4:88/4:3:1 on 35s, I couldn't imagine what 3:73/2:72 would be on 35s. I can understand there would be lots of clutch slippage.
wushaw is offline
post #7 of 19 Old 04-16-2011, 08:59 PM
2003X
I actually wonder this too. I haven't been able to get off road yet with the new 4.88s and 35s. Can it still stall when crawling in 4LO when riding the brake only trying to avoid the clutch as much as possible? I understand if you are trying to crawl a steep rock that its almost necessary to go from clutch, brake, gas, ect.
My Build
2003X is offline
post #8 of 19 Old 04-16-2011, 09:07 PM
Imped
Imped's Avatar
The ONLY time I ever touch the clutch when wheeling (you aren't wheeling if you're not in 4low) is when coming to a complete stop.....aside from shifting or backing up to try another line (duh). Otherwise, don't bother with it. Just let the gas out without giving it any gas. Even with crappy gears, it should still take off just fine due to the gear reduction of 4 low.
OlllllllO
IndyORV
Imped is offline
post #9 of 19 Old 04-16-2011, 09:10 PM
tchaap
I have 4.10's with a 4:1 transfer case and I can stall it in 4L but I've really got to stand on the brake.
TC
tchaap is offline
post #10 of 19 Old 04-16-2011, 09:43 PM
epeck87
i assume your talking about crawling through rock beds where you use the clutch so the jeep doesnt jerk back and fourth from your foot bouncing on the gas. one of my favorite mods i have done to my jeep is a hand throttle. and its not expensive. you can rig up your own with a bike brake cable or quadratec sells a nice kit. by using your hand to control the throttle your hand wont bounce like your foot and the jeep wont jerk as much eliminating the need for you to try to smoth out the ride with the clutch.
Associates Degree in automotive technology
A1-A8 ASE MASTER CERTIFIED TOYOTA MECHANIC
epeck87 is offline
post #11 of 19 Old 04-16-2011, 10:33 PM
silverjeep
Imped is right on!!! I have 35s and 3.73 gears. Feels like I put more stress on the clutch when doing street driving since I have to feather it more. In low gear its just fine.
Jeep parts and accessories
silverjeep is offline
post #12 of 19 Old 04-16-2011, 10:56 PM
2003X
Thanks, this answered my question.
My Build
2003X is offline
post #13 of 19 Old 04-16-2011, 11:35 PM
Cresso
I've been in situations where the terrain isn't challenging, but it's very rocky for extended periods of time. Bowling ball-sized rocks. I was driving a friend's Jeep that was on stock 3.73 gears and 31" tires. In 4-Low, 1st gear with zero throttle (just idling), the speed was still way too fast. The ride was like a bucking bronco. The only way I could slow it down to a non-damaging speed was to feather the clutch for an extended period of time. Yes, the tires were aired down. What else can be done in those situations?
Cresso is offline
post #14 of 19 Old 04-17-2011, 12:04 AM
andy02
I let out the clutch and feather the brakes if I find I am moving too fast.
Originally Posted by Hendrix
September 11 2001
Never Forget!
andy02 is offline
post #15 of 19 Old 04-17-2011, 11:38 AM
epeck87
read my post above. hand throttles are great for that stuff.
epeck87 is offline
clutch , off road
Off Roading = Clutch Monster? white94YJ Wrangler General Discussion 14 03-24-2011 05:36 PM
Idiotic Moment Axl Jack Wrangler General Discussion 3 05-14-2010 02:20 PM
avoiding pinstriping rickm8 TJ Wrangler Technical Forum 15 07-16-2009 06:48 PM
Couple Questions about Off-Roading Florida_Model TJ Wrangler Technical Forum 26 06-04-2009 07:11 AM
simple off roading questions. jimG16 Wrangler General Discussion 10 01-23-2009 06:15 PM
