Identify the noise? - JeepForum.com
post #1 of 10 Old 05-26-2016, 02:12 PM Thread Starter
Fusco
2016 JK Wrangler
Identify the noise?
Can anyone identify what is causing this noise? It sounds like someone is choking a cat. The fuel pump was replaced less than a year ago. Alternator was replace 3 months ago. I know the '05-'06 TJs suffer from the dreaded OPDA issue. I do have the upgraded Crown unit, just haven't installed it yet. Thoughts?
Youtube link... https://youtu.be/kTX0CkoLLZI
Thanks!
2016 Jeep JK 2D Sport S
2006 Jeep TJ Rubicon Impact Orange - SOLD :-)
Fusco is offline
post #2 of 10 Old 05-26-2016, 02:30 PM
NotURMailman
NotURMailman's Avatar
I don't really hear much of anything in your video.
But from your description, it may be a good idea to take your belt off and check all of your pulleys to see if any of them are sloppy or feel rough when turned.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #3 of 10 Old 05-26-2016, 02:35 PM
irnmadn88
Does it change when you push in the clutch? Or turn on-off the defrost/AC?
It sounds like bearing noise to me...
Colorado Jeep Club Member #667
irnmadn88 is offline
post #4 of 10 Old 05-26-2016, 03:22 PM Thread Starter
Fusco
2016 JK Wrangler
It does go away when I put it into drive. Returns a little when I'm at idle. U think its the idler pulley?
Fusco is offline
post #5 of 10 Old 05-26-2016, 03:42 PM
irnmadn88
Likely.
And if it isn't, cheap part.
post #6 of 10 Old 05-26-2016, 04:00 PM Thread Starter
Fusco
2016 JK Wrangler
Likely.
If its not that, whats Option B, u think?
Fusco is offline
post #7 of 10 Old 05-26-2016, 05:09 PM
irnmadn88
Your video is only from the outside of the Jeep.
Pop the hood.
If the noise is a belt driven accessory it should be obvious which one.
If it is not, move around the engine bay to hear where it is coming from.
post #8 of 10 Old 05-26-2016, 06:36 PM Thread Starter
Fusco
2016 JK Wrangler
Pop the hood.
I have the doors and top off...even with the hood open, it sounds louder in the cab.
Fusco is offline
post #9 of 10 Old 05-26-2016, 06:45 PM
irnmadn88
Well, you have an auto transmission, yes?
post #10 of 10 Old 05-26-2016, 06:49 PM Thread Starter
Fusco
2016 JK Wrangler
yes
Fusco is offline
