Ideal Cruising RPM for 4.0 from Gearing - Page 2 - JeepForum.com
post #16 of 25 Old 06-11-2011, 11:30 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Originally Posted by 1C41N0 View Post
Secondly, and finally, why is 2600-2700 RPM sought after for the 4.0 when the factory RPM limit is 3,000 RPM? Any input is appreciated, and I hope this thread helps someone else out too!
Yes 26-2700 is ideal for bigger tires like you are running. Where in the world did you hear or read that the factory rpm limit is only 3000 rpm? Your TJ's engine rpm limit is where the redline is on your tachometer which is well over 5K rpms.
And hopefully you went with the above solid advice to install 4.88 gearing which is ideal for 33" tires and the 42RLE transmission. 4.10 and 4.56 will produce rpms that are too low due to your transmission's ultra-low .69 overdrive gear ratio.
Gone wheeling Friday through Sunday.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is offline
post #17 of 25 Old 06-11-2011, 11:58 AM
Peterpsc
Although my LJ is not a DD I find cruising w/ overdrive engaged at hiway speeds and flat areas not all that uncomfortable. I have 5.13s, auto, and 37s. My rpms at 65 - 70 are about 2100 - 2250. Frankly, I don't like running at 70 mph plus although the rig runs out smooth and occaisionally I do it...I simply didn't built it to be a hiway cruiser. Again, I'm not on the hiway much at all with the LJ and sometimes I just run w/ overdrive disengaged cruising closer to 2550 rpms which sounds/feels ideal and puts me at 55 mph, which is a safer "jeep" speed imho.
I'd agree w/ JB, ideal rpms for cruising is 2500-2700. Hopefully you geared for your desired road speed, per/ JB, and geared your transfer case to your wheeling needs.
Peterpsc is offline
post #18 of 25 Old 06-11-2011, 04:45 PM Thread Starter
1C41N0
For starters I did take the advice (thanks everyone) and went with 4.88's to match my 33s. I also went with true-tracs front and rear. (My wife can't drive a vehicle with lockers, and we have a lot of snow/ice in Nebraska) and I deploy frequently (got back from another tour 45 days ago). So she has to be able to drive it. I couldn't go any lower with the gearing due to the Dana 30.
I haven't done anything with TC yet... beings it's a DD I don't really wheel (no mud or rock crawling at all) in it, but I love it for a hunting/trail rig (plenty of deep snow.
I thought my Jeep was governing out at 3k rpm in OD (did that once) to figure out what it was.
I live where it's pretty flat with a few hills, mainly we get a really strong mid-west wind. I drive home (5 hrs) about once or maybe twice a quarter. The speed limit fluctuates between 60-75 mph. On average I stick between 70 and 75 on the interstate, I have no need to go any faster than that.
1C41N0 is offline
post #19 of 25 Old 06-12-2011, 08:40 PM Thread Starter
1C41N0
Well, I got it back today and I'm impressed. I can tell I would not be happy if I went with 4.56 or anything like that.
1C41N0 is offline
post #20 of 25 Old 06-12-2011, 08:59 PM
robncar
robncar's Avatar
Congrats and thank you for your service!
Sent from my DROID2 using JeepForum
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #21 of 25 Old 06-12-2011, 09:50 PM
rlk_99
Ive got 4.88's on 33's and Im running 3K at 70 with the 5spd and get about 13 mpg, 4.10's maybe 4.56's would probably suit your DD needs better then 4.88's would and yes I know you have the AUTO so there is some differences but the 4.10's on 33's puts it back to a stock style set up at least for the 5 spd.
'02 Sport..... Stock no more.... RE 3.5 SF, RE adjustable trackbar(F/R) and 33x12.50x15 BFG MT's installed
rlk_99 is offline
post #22 of 25 Old 06-12-2011, 09:53 PM
LuckRider
LuckRider's Avatar
I really love how people post about what works for them without taking into consideration the needs of the person they are talking about. 5-speed and 42rle 4-speed auto.... very different things. I also love when people post about what someone else should do when that other person has already made their move.
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #23 of 25 Old 06-12-2011, 10:55 PM
robncar
robncar's Avatar
Reading comprehension?
robncar is offline
post #24 of 25 Old 06-12-2011, 11:05 PM
Rubi4Us
Glad you like the 4.88's because that is all that matters. Some folks might have similar or exact setups as you and their advice really helps while others have great experience and opinions. I've helped a few that PM'd me because I'm running exactly what they are thinking. Hell, I even sent them pics of my speedo and rpms to help them decide what is real life with their setup.
Go drive that thing now and enjoy it!!
LJ 2005 Rubicon Unlimited "Sahara" Limited Edition #0146 of 1000
35 inch KM2's with 5.5 inch Rock Krawler Long Arm
Rubi4Us is offline
post #25 of 25 Old 06-13-2011, 06:31 AM
Boundless
thats the setup I have now and I like it. still sucks in the mountains, but not near as bad as 3.73s/31s.
This might help:
http://www.jeepforum.com/forum/f9/33...6/#post9838564
That linked post should be a sticky
__________________________________________
Rusty
Satellite Bch, FL
2005 Jeep Wrangler Unlimited (LJ) 6cyl, 4spd auto, dana 30/44 3.73, rear trac-loc, hard top, BFG KM2 35/12.5 x 15 on rattle can black stock Ravine wheels & 1.5" spacers, trimmed flares, budget PA 1" BL & RC 1" MML, Ford Explorer roof rack, Hella e-code headlight housings, 55 watt DDM HID Hi/Lo 6000k, EBC Yellow Stuff front brake pads, Platinum P4 battery, Rusty's 3" 305s front and 303s rear springs, RC rear track bar bracket and Hella 500FFs with DDM's 55watt 6000k H3 HIDs on windshield hinge brackets. Currie's front upper and lower control arms. Hummm whats next? Building a Dana HP30 with 4.88 and ? locker
Boundless is offline
rpm , cruise , cruising , ideal , 4.0 , lj , wrangler , 3.73 , 33
Highway Cruising Speeds? DaveinHouston YJ Wrangler Technical Forum 7 03-18-2010 06:43 PM
Craigslist Cruising.. jim_bert Wrangler General Discussion 12 09-19-2009 09:39 PM
Cruising for no reason. michaelmjc Wrangler General Discussion 30 06-22-2008 02:12 PM
cruising at 3000 rpm turkish6 TJ Wrangler Technical Forum 16 03-25-2007 11:07 PM
TJ throttle response when cruising... swoodnj TJ Wrangler Technical Forum 12 12-21-2003 08:33 PM
