Quantcast Idaho Jeep Build - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Idaho Jeep Build
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.com
Old 09-07-2008, 11:08 PM   #31
Idaho-Jeep
ΜΟΛΩΝ ΛΑΒΕ!
Idaho-Jeep's Avatar
Originally Posted by Gabe View Post
what's the part # on the AA kit? I see a note in 4WPs system that says something about modifying the fork rail shifter or something like that??
Here is what is on my invoice - I believe this is the number.
1 KIT 1 0 50-7906 NP T/C FIXED YOKE KIT 178.06 178.06
Idaho-Jeep is offline   Reply With Quote
Old 09-07-2008, 11:09 PM   #32
Gabe
yup that's the one I'm ordering. Thanks
Originally Posted by Rubi22
Holy ****, did someone log onto Mean Fish's account and say something thoughtful?
Gabe is offline   Reply With Quote
Old 09-08-2008, 09:40 AM   #33
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
Looks good.
Stretched TJ Future, Coil overs, 40s, 60/14 bolt
My Build Thread.
www.kifourwheelers.com www.indyorv.com
For Sale:
TJ 44 Combo, 4.88s, detroit, Alloy USA shafts, Disc Brakes, HD lower mounts, Clayton tube Truss
35" procomp tires with Aluminum wheels $650
(4) 5x4.5 steel beadlocks $200
3 11"& 2 13" BBCS shocks
Ford Dana 60 Rear $150
Big Daddy Offroad HD tie Rod
(4) 15x8 5x4.5 TJ, YJ, XJ, etc bolt pattern Aluminum wheels $175
JeepRocks86 is offline   Reply With Quote
Old 09-10-2008, 12:19 PM   #34
Dogman
My wife took a look this morning and said "you are never going to be able to put that back together" She has a lot of faith in me.
Ah...it goes together faster than it comes apart
Dogman is offline   Reply With Quote
Old 09-10-2008, 12:41 PM   #35
grogie
Too little time
grogie's Avatar
Great buildup... and thanks for the links. I had to comment that your rear bumper is sweet. Keep up the posts!
And yes, that is a great house you have. I'd love to design my own too someday but I'm not an architect.
Red Jeep Club #345
2006 TJ Sport
2004 KJ Limited
grogie is offline   Reply With Quote
Old 09-10-2008, 12:57 PM   #36
-Rudy-
1997 XJ Cherokee
Beautiful jeep, but I must say... that house is simply stunning. Lol. I come from a family of architects and remodeling contractors and I think I'm more interested in the house than the jeep now.
Originally Posted by SarahRose
something big and fun
-Rudy- is offline   Reply With Quote
Old 09-10-2008, 01:38 PM   #37
bortz1892
i too am an architect, just graduated. you should check out the book 'arcadian architecture'. juding by your house you would love it. i think most of the houses in the book are by bolin cewinski jackson...based out here on the east coast. they're great, i guess they just designed that new glass apple store on 5th avenue in new york.
anyway, im done being a nerd. did you say you have a suspension for sale?
bortz1892 is offline   Reply With Quote
Old 09-10-2008, 02:02 PM   #38
Idaho-Jeep
ΜΟΛΩΝ ΛΑΒΕ!
Idaho-Jeep's Avatar
Thanks again for the comments!
I assume you mean that you are an "Intern Architect" if you just graduated? Are you working in a firm yet? PA has a 3 year internship, yes?
Yes, I am familiar with Bohlin Cywinski Jackson's work. I don't have that book but his work is in several other books I do have. Great stuff - A little more contemporary than what a lot of my clients want to build. If you are interested, our website is: networkarch.com I am a principal in a modest sized firm and manage the McCall office.
And, yes I do have a 4" short arm suspension for sale.
Old 09-11-2008, 10:32 AM   #39
bortz1892
yes..i'm in IDP right now. program goes from 3-5 years out here. i am working for a firm....but thinking about moving to boston or philly.
how much for the suspension shipped to 18087?
Old 09-13-2008, 07:59 PM   #40
Idaho-Jeep
ΜΟΛΩΝ ΛΑΒΕ!
Idaho-Jeep's Avatar
Update
This last week I had some late meetings and could only spend a couple evenings in the garage so I was not able to accomplish much. I did however take care of the control arm frame mounts. Because I am going to run a long arm kit I needed to remove the lower arm frame mounts and decided to also remove the upper arm mounts while I was at it.
Like most people, I used a grinder to grind down the welds, a saws-all to cut the mount down the middle and then a BFH to work the halves back and forth until they come off. The lower arm mounts were fairly easy but the upper arm mounts were more difficult to get to - especially the front uppers.
Here is a before shot:
A shot after the mounts are cut off:
I used a grinder to take the welds down and then a flap wheel to smooth everything out. I plan on painting the entire frame with hammerite.
The scrap pile of frame mounts:
Old 09-13-2008, 08:24 PM   #41
never monday
nice to see all that research coming together.
Get Savvy
never monday is offline   Reply With Quote
Old 09-13-2008, 09:10 PM   #42
Idaho-Jeep
ΜΟΛΩΝ ΛΑΒΕ!
Idaho-Jeep's Avatar
Last night I needed a brake from the grinder so I decided to focus on the Evap system and relocating it. Because I have extended wheel well corners I had to trim some of my tub wheel well. After trimming it was obvious that something needed to be done with the Evap system. I searched around and found information that indicated I could bypass the charcoal filter canister. With that in mind, figured I could maybe keep the system in the corner of the tub.
As you can see, that black canister sticks out into my wheel well:
With the cover plate off you can see the canister and evap system.
Take off a couple bolts and a nut, unplug the electrical connection and two fuel tank lines and pull it out.
I then removed the canister filter and trimmed down the mounting plate in the wheel well and the mounting plate that the evap system is attached to. I then drilled two holes in what was the top mount for the canister. I ran the hose through these holes which helped align and stabilize them. Using some 5/8" flexible fuel line, 4 hose clamps and two male-male fittings I connected an end to each existing hose and bypassed the canister.
After that I put the stock cover plate back on and was happy with the results.
I bought some black rubber sheet material to use for a wheel well liner on the front tube fenders, I plan on using some of that same material to fashion a liner for the back of each corner to prevent rock and mud from getting into these back corner areas. I am also going to paint the wheel wells black with hammerite paint.
Old 09-13-2008, 09:17 PM   #43
jimaug87
Subscribed! Excellent buildup. look for something similar to come along more slowly ($10/hr lifeguard while in school) from me starting after the winter (I'm also plowing!)
Love the house, love the Jeep, and I'll be checking in regularly
2005, I6, 6 Speed, RC 2.5", RC front adj. track bar, 31" Goodyear DuraTracs
"Nobody is comepletly useless. We can always serve as a bad example."
jimaug87 is offline   Reply With Quote
Old 09-13-2008, 10:21 PM   #44
Idaho-Jeep
ΜΟΛΩΝ ΛΑΒΕ!
Idaho-Jeep's Avatar
Today I decided to focus on getting my axles ready for the re-gear, lockers, and trusses.
Working on these while on jack stands (and/or blocks of wood) was a little cumbersome so decided to copy a brilliant idea I saw on "BozoWise's" build thread http://www.jeepforum.com/forum/f9/started-another-project-vehicle-423989/index31.html For about $15 I put together this little cart and it makes moving and rotating the axles while working on them a lot easier.
I started with the 44. My Long Arm kit will reuse the lower control arm axle mounts, coil spring bases and sway bar mounts but I needed to remove the upper control arm mounts, track bar mount and shock mounts. Here is the rear axle on my new axle cart.
After a few hours of cutting and grinding I had the brackets off. I then spent some more time with a wire brush attachment on my drill cleaning all the dirt and surface rust. I taped over the vent tube hole but that did not stop a nice diff fluid mess on my floor from happening when I turned the axle upside down.
I was able to test fit the TnT D44 truss - With the axle at 17* and truss at 0*, it fits perfect!
Well the day was half over and I still had a dirty axle to deal with so why go fishing huh?
During this build I plan on upgrading my front brakes to the VanCo. big brake system. Because of this I decided to remove the brake rotors & Calipers along with the shafts and knuckles. I have never touched disc brakes before on a vehicle so this was a new experience. I used stu-offroad.com to provide some how to info on the removal. Here is the 30 to start:
The removal of everything went fairly smoothly (impact wrench was helpful for the axle nut). Getting the knuckles off took some doing however. There is a small area meant for hammer blows but it would not take long to bang up the knuckles whacking away so I used a second BFH placing it on the dedicated spot and then hitting the sledge with the sledge. I was surprised how much encouragement was required but it did finally come loose. Now I can send these knuckles off to Van!
Once I had both sides finished I moved on to removing the upper control arm axle mounts. The one that is cast into the pumpkin took a while to cut off - wish I had a plasma cutter! Once I had both mounts cut off I again used the grinder and flap wheel to smooth things out. I also exposed the steel on the axle tubes where the truss would need to be welded on. After that I again used the wire brush on the drill to clean up the axle.
And again did a test fit on the TnT truss - another great fit at with the axle at 5* and the truss at 0*
I had considered swapping out the 30 for a 44 - but after some consideration decided to stick it out with the 30 for now. If need be I will upgrade the shafts.
Once the trusses are welded on I will be painting them with black hammerite paint.
Old 09-14-2008, 10:22 AM   #45
RVA_TJ06
Man I am jealous. Nice build so far. When is the lift going on?
Finally paid off...
RVA_TJ06 is offline   Reply With Quote
Glock Forum
