I want to run 35's on my TJ - Page 5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > I want to run 35's on my TJ
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 07-30-2012, 03:59 PM   #61
TheRealKTrain
JK Wrangler
Originally Posted by Nate M View Post
Dang! I need a son
Not if you want to keep buying Jeep parts you dont! Ask me how I know!
"We are what we repeatedly do. Excellence, then, is not an act, but a habit." Aristotle
Μολὼν λαβέ
TheRealKTrain is offline   Reply With Quote Quick reply to this message
Unread 02-05-2013, 06:10 PM   #62
Hellga
Going from stock to 33's with moderate wheelin' should this advise from the original post be followed? I'm looking at a 4in lift. Regearing, Dana 44's and super 35's have got me hung. I would love a check list for running 33's (if anyone has the time) I do use my jeep as a daily driver. Thanks for any help
Hellga is offline   Reply With Quote Quick reply to this message
Unread 02-05-2013, 06:20 PM   #63
Tblack
Fill in your profile so we can see what you have. If you have a 6 cylinder and 3.73's with a manual. I would try it without re-gearing and decide later if it is really worth it. But if you have the auto, or you have a 4 cylinder I would recommend a re-gear.
Safety 3rd!
Tblack is offline   Reply With Quote Quick reply to this message
Unread 02-05-2013, 06:23 PM   #64
MotoSoul
Bringing this old out dated post back from the dead eh. Honestly put a 2 inch budget boost a 1 inch body lift and front disconnects. Then take it out and you will learn from there exactly what you want/need.
Without doing a real total part by part you can be up to 8-10 grand to do a 4 inch lift properly with lockers re gearing or axle swaps.
I like the arms, they are a good solution, but they really aren't worth the effort for the average person and you already see the BS that goes on over bushings VS JJ's, the crap that would go on over J arms would be epic.
MotoSoul is offline   Reply With Quote Quick reply to this message
Unread 02-05-2013, 07:25 PM   #65
biffgnar
biffgnar's Avatar
It's "old", but not out dated. Advice is rock solid.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is online now   Reply With Quote Quick reply to this message
Unread 02-05-2013, 08:34 PM   #66
Tblack
Biff.... This may be the only post you have posted that I agree with.....
Safety 3rd!
Unread 02-05-2013, 08:36 PM   #67
biffgnar
biffgnar's Avatar
The rumors of my *******ness are greatly exaggerated
Unread 02-05-2013, 10:49 PM   #68
MotoSoul
Perhaps that was the wrong word. It is a very good description of the initial concept for what you will need, but still leaves many gaps for a new owner trying to figure it all out.
Unread 05-12-2013, 11:21 AM   #69
njohnson412
hey i am just getting into the whole axle swap stuff. So what exactly makes a d30 a hp d30? and where can i get a good price on axles?
Sienna jeep club #63
njohnson412 is offline   Reply With Quote Quick reply to this message
Unread 05-12-2013, 11:24 AM   #70
biffgnar
biffgnar's Avatar
HP = high pinion, in contrast to the low pinion that TJs come with. Options for swap include finding an XJ axle (96-99 preferred years), watching the classifieds and Craig's list, buying from somewhere like East Coast Gear Supply, etc.
Unread 05-12-2013, 11:37 AM   #71
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
High pinion means the pinion is above the axle shafts.
Wheelin98TJ is offline   Reply With Quote Quick reply to this message
Unread 05-12-2013, 07:13 PM   #72
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Like this:
Knuckelhead is offline   Reply With Quote Quick reply to this message
Unread 12-10-2013, 05:10 AM   #73
JPLJ
Slow build towards 35's
I want to run 35's on my lj. Can't do it all in 1 shot I understand how crazy it would get w/$. I want to know the best way to get there 1 step, part or project at a time . No rush it's my DD it has 3" spacer lift would like those gone & 32" tires. So what I'm asking is where do I start ? Lift, regear etc. I would also like to do it each right the 1st time
JPLJ is offline   Reply With Quote Quick reply to this message
Unread 12-11-2013, 09:34 PM   #74
Ken Cooke
Just buy the 35s, install them on your Jeep, and tackle the side-effects of 35s from gears to brakes to axle shafts to steering... You'll still be happier than if you bought 33s, plus you'll learn how to maintain your track bar and control arms in the cold of winter.LOL
Ken Cooke is offline   Reply With Quote Quick reply to this message
Unread 12-11-2013, 09:50 PM   #75
LukeADukes
And u joints and hubs and all that other good stuff here here
Always look both ways before crossing the stream.
LukeADukes is offline   Reply With Quote Quick reply to this message
