I want to run 35's on my TJ - Page 2 - JeepForum.com
post #16 of 77 Old 05-23-2010, 10:56 AM
UltimateCC
I went with the lcg method but its never ending be because once you fix one thing something else breaks or needs upgrading...it sure is fun though...
UltimateCC is offline
post #17 of 77 Old 05-23-2010, 11:02 AM
jforse
sticky please
1997 TJ - Build in process.
2004 WJ Freedom Edition 4.7HO
jforse is offline
post #18 of 77 Old 05-23-2010, 11:03 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Originally Posted by USAFSahara View Post
I see you say upgrade to Vanco but I have read that if you upgrade to EBC pads and rotors you get the same results. Is this true? I see the slotted rotors are $170/pr and the pads are $137/pr so why not go with them? Just curious. And I also see you say to upgrade to HD Tie Rods what about Hydraulic Steering? Is it needed at this point with 35s? Just bought 35s and have everything in order but the brakes. Lookin for opinions here.
No you don't get the same results. And, even if you did, you've still failed to address the weak cast sliders that will flex further under the higher braking forces. You still haven't addressed a crappy weak stock caliper, and you haven't addressed the smallish rotor diameter.
You already have hydraulic steering.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #19 of 77 Old 05-23-2010, 11:06 AM Thread Starter
never monday
Originally Posted by jforse View Post
sticky please
I prefer not, thanks
never monday is offline
post #20 of 77 Old 05-23-2010, 12:11 PM
TJamz
Prob a good idea to mention frame tie-ins for the tire carrier? 35 inch is heavy. Just my
TJamz is offline
post #21 of 77 Old 05-23-2010, 02:29 PM
USAFRecon
Thanks Blaine. Next on my list is the EBC Rotors and pads and once I drive it a bit and see how I feel I will upgrade as necessary.
USAFRecon is offline
post #22 of 77 Old 07-04-2010, 10:28 AM
Stubbs89
LCG is the way to go it seems.
Stubbs89 is offline
post #23 of 77 Old 07-04-2010, 10:35 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
not if you set it up wrong.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #24 of 77 Old 07-04-2010, 10:47 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Or wheel where ground clearance is priceless.
I am Savvy
mrblaine is offline
post #25 of 77 Old 11-14-2010, 06:43 PM
ironzap2
what does LCG mean. might sound like a stupid question, but i'm slowly building up for 35's and i'll take any advice I can get.
ironzap2 is offline
post #26 of 77 Old 11-14-2010, 06:48 PM
Unlimited04
LCG = Low Center of Gravity
LCG is typically defined as less than 1" of lift per 1" increase in tire size.
"old school" convention is typically 1" of lift per 1" increase in tire size.
Useful Write-Ups:
Funny:
post #27 of 77 Old 11-14-2010, 07:38 PM
Border Dave
Got Sand?
Border Dave's Avatar
Don't you mean 1" of lift per 2" increase in tire size?
edit: Never mind, I was thinking bump stops.
Border Dave is offline
post #28 of 77 Old 01-27-2011, 11:16 PM
Bscherm
sub'd
Bscherm is offline
post #29 of 77 Old 01-28-2011, 06:46 AM
EricFaulkenberg
something like this i believe. -its my ultimate goal with enough money.
4-1/2" of lift total, some trimming, and BAM 42" of rubber!
http://www.4wheeloffroad.com/techart...rds/index.html
EricFaulkenberg is offline
post #30 of 77 Old 02-08-2011, 12:55 AM
btn
Maybe add info on how much total bump stop extension is needed to keep 35s out of stock fenders.
btn is offline
35's on a 3.5''??? gamble3527 TJ Wrangler Technical Forum 11 09-29-2009 10:16 AM
Let's see JK on 35's JayDLT JK Wrangler Technical Forum 59 02-28-2007 01:33 PM
4.5 w/35's Rubicon153 TJ Wrangler Technical Forum 28 02-19-2007 12:09 AM
35's and a d30 stevegittings TJ Wrangler Technical Forum 7 10-27-2005 03:09 PM
RE 3.5 with 35's jeep jake TJ Wrangler Technical Forum 25 10-07-2005 12:42 AM
