I swear this is like christmas lights!!!!!! :brickwall - JeepForum.com
post #1 of 6 Old 05-12-2012, 02:35 PM Thread Starter
FMFTJ
Hey all, so i have a 02 TJ with a turn signal problem. It likes to work when ever it feels like it. i might get one good blink then nothing sometimes a glitchy noise or nothing at all, this goes on both sides. I started small and changed out the bulbs, no go, then the turn signal switch in the column, also no go. Tested the flasher relay and it works fine. I noticed one of the bulb harnesses in the front was all corroded. so i replaced the at too. But still nothing seems to work. Anybody have any idea where this thing might be shorting at or what else it could be?
FMFTJ is offline
post #2 of 6 Old 05-12-2012, 02:54 PM
TheBoogieman
Disturbed
TheBoogieman's Avatar
This double post reminds me of Groundhog day!(the movie) This double post reminds me of Groundhog day!(the movie)
TheBoogieman is offline
post #3 of 6 Old 05-12-2012, 03:51 PM
wushaw
Rockin jeep
wushaw's Avatar
Get a wiring diagram and start checking your grounds.
wushaw is offline
post #4 of 6 Old 05-13-2012, 07:15 PM Thread Starter
FMFTJ
ya sorry about that double post, internet went all wierdo on me, guess i hit the submit button twice or something. Thanks for your replies guys spent most of this weekend with a test light going from the bulb all the way up to the column, And as far as i can tell with that its doing the same glitchy thing all the way up. From what i can see all the wiring looks good.
FMFTJ is offline
post #5 of 6 Old 06-03-2012, 08:12 AM Thread Starter
FMFTJ
So turn signals are fixed. It was a ground issue after all.
FMFTJ is offline
post #6 of 6 Old 06-03-2012, 09:35 AM
SlackJaw
baby jeep
SlackJaw's Avatar
Cool, where did you find the fault?
Sent from my Android using JeepForum
Can you afford the car? Have I provided you all the information you need on the car? Do you like the car? Then buy the car.
SlackJaw is offline
electrical issue , lights , signal , turn
Tuffy console jammed!! help! :brickwall ibacavergrl YJ Wrangler Technical Forum 45 08-20-2011 05:14 PM
Air bag light with code P1486?! Help, dashboard lights up like a christmas tree. sene TJ Wrangler Technical Forum 7 12-05-2009 06:55 AM
:brickwall need help with rear disc brake conversion on TJ? saltydawg1845 TJ Wrangler Technical Forum 7 10-31-2009 04:08 PM
Help: Intake, exhaust and gasket :brickwall funJ YJ Wrangler Technical Forum 8 07-07-2006 07:31 PM
Last time i ask...i swear :) SixInline TJ Wrangler Technical Forum 24 09-21-2004 06:07 PM
