I see coolant I smell Coolant But can't find leak. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > I see coolant I smell Coolant But can't find leak.
Unread 07-16-2010, 02:00 PM   #1
MrB
Had the jeep parked for about 4 days while i was running my company truck back and forth to work. Started her up today and smelled coolant coming from the engine compartment. Popped the hood didn't see anything at the time. Drove 45 minutes home, all was well temp gauge stayed at 210 the whole way at highway speeds. Parked the jeep came out about an hour later and had drips of water on the drag link and front axle but still can't see where it's comming from. I have checked all hoses, reservoir, water pump and pulled the radiator cap. I have a feeling it's leaking on cool down but not a clue where.
MrB is offline   Reply With Quote Quick reply to this message
Unread 07-16-2010, 02:28 PM   #2
Benderff
Benderff's Avatar
Look for the white residue. You won't find a small leak when it's hot. Start it up when it's cold and look.
Benderff is offline   Reply With Quote Quick reply to this message
Unread 07-16-2010, 02:50 PM   #3
MarkF
Drips of water or drips of coolant? Drips of water could be condensation from your AC lines. The coolant smell could be your heater core inside the jeep.
Were the drips on the axle on the driver's side or passenger side? Pass side could be A/C, driver's side most likely coolant
98 Gunmetal Sport - RE 4.5 LA, BFG 35", 1" BL/MM, D44 & lots of armor.
MarkF is offline   Reply With Quote Quick reply to this message
Unread 07-16-2010, 03:14 PM   #4
Rio_Grande
When I had a very similar leak I found that it was my upper seal on the radiator where the plastic cap meets the aluminum the crimp had come loose. I replaced the seal and recrimped it only to have it leak again later.
It would fill the channel around the seal with coolant and leak down one side.
Worth a look, no reason it couldnt happen on the bottom.
I love this crap!!
Rio_Grande is offline   Reply With Quote Quick reply to this message
Unread 07-16-2010, 03:33 PM   #5
cidd
check the Front shaft on the water pump had one leak when hot and most of the antifreez would get sprayed away by the fan blade would only leave a small amount on the ground when I would first shut it off hot.
cidd is offline   Reply With Quote Quick reply to this message
Unread 07-16-2010, 04:08 PM   #6
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Check the weep hole for leaking at bottom of water pump.
GOLENJEEPTJ is offline   Reply With Quote Quick reply to this message
Unread 07-16-2010, 04:16 PM   #7
robncar
Check the passenger side floor.
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline   Reply With Quote Quick reply to this message
Unread 07-16-2010, 10:04 PM   #8
wushaw
Rockin jeep
wushaw's Avatar
Originally Posted by golenjeeptj View Post
check the weep hole for leaking at bottom of water pump.
x2
wushaw is offline   Reply With Quote Quick reply to this message
Unread 07-16-2010, 10:10 PM   #9
silver97tj
Hi all
If you are not losing coolant outside, and can smell when you get in,.....it is heater core.........................
1998 Blue TJ, 4 Cyl., Auto (30rh), Hardtop with installed Sunroof, mostly stock.
31x10.5x15 Mud Tires, TJ Rubicon springs, Mopar Deep Trans Pan and Cooler
Army Vet and proud of it! Have you served your country?
Support our Troops!! Thank You!!!
silver97tj is offline   Reply With Quote Quick reply to this message
Unread 07-16-2010, 10:12 PM   #10
little_Jeep
Go to AutoZone and barrow their Radiator pressure tester. When your engine is cold, connect tester and pumper up..... if it doesn't hold pressure for 10 minutes, you have a leak, which will be easier to find on a COLD engine that has it's coolant system under pressure.
AutoZone calls is a "Coolant Pressure Tester W/ Adapters" part number is OEM27049
little_Jeep is offline   Reply With Quote Quick reply to this message
Unread 07-16-2010, 10:13 PM   #11
wushaw
Rockin jeep
wushaw's Avatar
Originally Posted by silver97tj View Post
Hi all
Heater cores don't leak on the ft. axle.
Unread 07-17-2010, 09:08 AM   #12
robncar
The A/C condensation does though. (Actually, on the control arm)
Unread 07-17-2010, 09:26 AM   #13
Dryseals
1980 CJ7
The key is are you losing coolant? Mine does the same, the smell, pops up now and then. But after a few months I haven't lost a bit of coolant.
The smell?? The over flow bottle. The cap allows the fumes to escape and in the prcoess of heating and cooling down it tranfers coolant back and forth. Every time it does you can smell it.
Dryseals is offline   Reply With Quote Quick reply to this message
Unread 07-17-2010, 09:29 AM   #14
Apex
Recon death squad
Apex's Avatar
Freeze plug?
We thought this XJ had a head gasket leak, so we tore the head off and found out the freeze plug on the back of the head had a pin hole in it and was spraying anti-freeze everywhere.
Apex is offline   Reply With Quote Quick reply to this message
Unread 07-17-2010, 10:49 AM   #15
little_Jeep
Freeze plug?
I have heard where guys use these rubber drain block (intended for plumbing use), they change the wing nut for a hex nut and simply insert into edge of freeze out plug, then tighten, no more leak, not need to remove head. I personally haven't done this repair, but I got one I'm going to try it on.
Coolant leak , anit-freeze leak
