I need help please...what is this? - JeepForum.com
post #1 of 13 Old 07-17-2010, 09:21 PM Thread Starter
willrigdon
I've been to autozone and advanced auto parts and we can't figure out what this is...it came off my transfer case near the rear output shaft...its causing a massive fluid leak and needs replaced...i've crawled the fourm and can't seem to find anything...the best we could come up with is a speed sensor...but i know theres a speed sensor on the transmission and we pulled up speed sensor on their computer and it wasn't the same thing...this is really killing me so any advice would help...thank you
willrigdon is offline
post #2 of 13 Old 07-17-2010, 09:27 PM
Recoil
Recoil's Avatar
1988 MJ Comanche
Yep it's a speed sensor you must have a rubicon.
Recoil is offline
post #3 of 13 Old 07-17-2010, 09:37 PM Thread Starter
willrigdon
I do have a rubicon...why doesn't autozone or advanced auto have this...when we typed speed sensor it came up with the one on the transmission...do you know where I can get this part?
post #4 of 13 Old 07-18-2010, 03:39 AM
TeeJay00
But it looks like a temp sensor!!! How does it sense speed like that How does it work?
TeeJay00 is offline
post #5 of 13 Old 07-18-2010, 04:47 AM
RogueSpear2023
It goes in the transfer case I believe, because we Rubicon owners have an electronic speed sensor. Not a gear in the t-case like all the other jeeps.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #6 of 13 Old 07-18-2010, 04:50 AM
TeeJay00
Originally Posted by RogueSpear2023 View Post
... we Rubicon owners...
You make it sound as if you are different species
TeeJay00 is offline
post #7 of 13 Old 07-18-2010, 05:44 AM
tjthorson
tjthorson's Avatar
2014 JK Wrangler
The rubicon speed sensor is not gear driven like the regular jeeps, its an "electronic" sensor. Basically its a hall effect type sensor - as something on the transfer case output shaft comes close to the sensor, it detects a "revolution" - from those pulses it calculates speed.
No matter what Wrangler you have, rubicon or not, the sensors are at the rear of the transfer case. On a 2 wheel drive vehicle, it would be at the rear of the trans. They were looking up the wrong vehicle and/or part.
But - all you should need to replace is the o-ring on it. The do go bad and need replacing - shouldnt need to replace the whole sensor!
Todd Thorson
2013 Jeep Wrangler Sport Orange Crush
Orange Crush Jeep Club Member #50
2013 Jeep Wrangler Unlimited Gecko Green (Wife's DD)
Gecko Green Jeep Club Member #1
2005 Yellow Unlimited Rubicon (sold)
My Band! ->
tjthorson is offline
post #8 of 13 Old 07-18-2010, 05:56 AM
asbury
dealer part
JEEP NAKED !!
asbury is offline
post #9 of 13 Old 07-18-2010, 08:36 AM
Recoil
Recoil's Avatar
1988 MJ Comanche
Yeah what he said. If you were to open your tcase up you would see that just below that there is a metal ring and as the ring turn that sensor allows the PCM to calculate speed. From the looks of the sensor I see no reason to replace it just put a new o ring on it and bolt it back on.
Recoil is offline
post #10 of 13 Old 07-18-2010, 10:31 AM Thread Starter
willrigdon
It's not the oring that's messed up it's the plastic grove the oring sits in that's messed up...not sure how it happened but the plastic got bent up somehow creating a gap and replacing the oring won't fix the problem...but thank you all for your quick and helpful responses
post #11 of 13 Old 07-18-2010, 10:34 AM
Recoil
Recoil's Avatar
1988 MJ Comanche
Try some black rtv on the plastic then place the o ring on. Tighten it down and test drive. If that dosent work I'd look into a new one.
Recoil is offline
post #12 of 13 Old 07-18-2010, 11:04 AM
jkp
Here you go: More Information for AIRTEX / WELLS 5S4942
Found it under 2005 Rubicon on Rock Auto...
'92 Islander
'06 Rubicon
jkp is offline
post #13 of 13 Old 07-19-2010, 05:57 PM Thread Starter
willrigdon
thanks for all the help guys...i ended up going to the dealership and ordering it...tried fixing the part myself...it was a complete failure
rubicon , speed sensor , transfer case
