I made a window holder out of a 2x6 - JeepForum.com
post #1 of 9 Old 06-01-2008, 08:39 PM Thread Starter
jgorm
jgorm's Avatar
I decided to build something to hold the front windows in the jeep while the top is down, but didn't want to use straps. I cut a 2x6 to fit, then notched out groves for the little tie down things. I removed 2 brackets from the rear (not sure what they are for) and reused the bolts to hold down the 2x6. I had to drill out a good chunk of the 2x6 to fit the short bolts in. I then drilled some holes to hold the metal bars of the font windows. One hole needed to be nearly on top of my mounting bolt, but it still works fine. It holds them securely and blends in well so i am happy. I love when projects only take me a couple hours!
More pics here.
jgorm is offline
post #2 of 9 Old 06-01-2008, 08:43 PM
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
That's a great mod. I'll have to do this when I get my half doors painted and mounted on my rig. Thanks for posting.
2009 JK Rubicon
Shrockworks Mid-width, Warn 9.5Ti; Skid Row Engine Skid, LCA & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Diff Skids, 11,000# Pull-Pal. Uniden 520XL CB; 1" Front & 1/2" Coil Spacer Rear; Aeroforce Interceptor, Valentine 1.
Moab - TJ-4/2006, TJ-5/2008, 4/2009, 5/2011, 4/2013, 5/2016, 4/2017
Ouray - TJ-8/2007
Rubicon - TJ-9/2008
Thunderstrike is offline
post #3 of 9 Old 06-01-2008, 09:15 PM
iMTB
That's nice, I just slot them behind the back seats but that looks much better.
iMTB is offline
post #4 of 9 Old 06-02-2008, 05:58 AM
sportcoupe
2017 WK
That works because you don't have a rear seat. I al looking for a way to keep my rear seat (kids) and keep my door uppers off and with me with the top down.
Right now if my top is down the door uppers and side windows stay home since there's no place for them in the jeep.
sportcoupe is offline
post #5 of 9 Old 06-02-2008, 06:01 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Ummm....Judging by where that 2x6 is in the pics, you could do this with your back seat still in place.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #6 of 9 Old 06-02-2008, 07:18 AM
RLD831
RLD831's Avatar
I used to do that without the 2x6 when I had a back seat in and half doors. They fit fine.
RLD831 is offline
post #7 of 9 Old 06-02-2008, 09:00 AM Thread Starter
jgorm
jgorm's Avatar
Right. I used to keep them behind the seat but needed something to hold them when the seat is out. The seat and windows still fit with the 2x6 in place, but the 2x6 is not needed if the seat is there because the seat holds the windows just fine. I do not plan on removing the 2x6 when the seats are in.
jgorm is offline
post #8 of 9 Old 06-02-2008, 09:06 AM
Recoil
Recoil's Avatar
1988 MJ Comanche
yeah I think this is a great idea for when the seat is out...when the seat is in I just stick the uppers between the back seat and the top and then roll the side windows up and put them under the uppers and the top behind the seat...if no one is in the back seat I even take the doors off and set them back there on the seat...Love having half doors!
Recoil is offline
post #9 of 9 Old 06-02-2008, 09:08 AM
sportcoupe
2017 WK
It seems way to tight on mine but it may be because the rear window is left in and rolled up when I lower my top.
Home made accessories for a factory made roof rack jeepgunner12 TJ Wrangler Technical Forum 0 11-11-2009 06:16 PM
Screws stripped for rear window holder... itasor TJ Wrangler Technical Forum 15 07-28-2008 03:18 AM
Soft top rear window holder thingies Dudewayne TJ Wrangler Technical Forum 2 06-05-2006 02:00 PM
Rear side window bar/frame (Any pads made for it??) natef26 TJ Wrangler Technical Forum 2 08-30-2004 04:03 PM
Home made window storage roll storysunfolding TJ Wrangler Technical Forum 13 07-10-2004 08:24 AM
