I made a _____ for my TJ! (post your homemade Jeep stuff here) - Page 32 - JeepForum.com
 4Likes
post #466 of 3576 Old 01-30-2008, 09:25 PM
Justin Brimm
Originally Posted by mall0y
$7 bucks??? Damn, I just went to radio shack and spent $15 on the stuff that I need. I didn't assemble it yet, but I will this weekend. What all did you get? Heres my shopping list:
  • Inline fuse holder - $2.99
  • Rocker Switch (nothing fancy) - $2.99
  • 4-Pack of fuse taps - $1.99
  • 20 ft. roll of 12guage wire - $4.99
  • 1 10A fuse - $1.99
Everything came out to $14.95.
Probably because he didn't buy any fuse related items when he did his, which is perfectly fine as you don't need a fuse in this situation. All you are doing when you do this mod is adding a switch into an existing fused circuit, so if anything shorts out including the new switch you have added, the factory fuse will blow all the same.
A good rule of thumb, is if you are simply modifying an existing fused circuit, you do not need to add a fuse. If you however, are creating a new circuit or modifying an existing un-fused circuit, you need to add a fuse.
Of course, when in doubt, fuse it. This case however, it is not needed and you can take the fuse holder, fuse taps and fuse back. You also got ripped off on the fuse; you can get an assorted 20 pack of them at any auto or electronics shop for $5 bucks.
One last thing; Radio-shack last I checked, only carries solid-core wire, not stranded (braided) wiring. Solid core is fine for electronics projects, but braided wiring must be used in automotive conditions as solid-core breaks after repeated bending where braided does not, and the vibrations of a vehicle will make the solid-core break apart.
Justin Brimm is offline
post #467 of 3576 Old 01-30-2008, 09:40 PM
rmb2485
rmb2485's Avatar
If the switch were to 'short out' (not really even the right term here) in the closed position it would just be as if the switch didn't exist and the circuit was unmodified. If it 'shorted out' in the open position then no current could flow through it. Either way, the switch will NEVER blow ANY fuse no matter how hard you try.
True, but I've bought braided wire at RadioShack before. I wouldn't recommend it because its insanely over priced just like everything else there, but they do have it.
rmb2485 is offline
post #468 of 3576 Old 01-30-2008, 09:43 PM
mall0y
I'm no electrician but do have a reasonable amount of experience with wiring and the like. I saw the setup for sale in the Q-tec magazine and decided to replicate it. Then I found this write up: http://www.4x4icon.com/offroad/dome_...itch/index.htm .
So this is more or less what I am going to do. It's basically just "moving" the fuse from the fusebox to the inline holder. Also, the wire I picked up is braided. Don't worry, I wouldn't have even thought of using solid core. As for the fuse, it was there, so was I, the auto part store was another 5 minutes down the road, I bought it, it's all good. Normally I wouldn't get this kind of stuff from radio-shack but it was actually cheaper than the local auto parts store.
mall0y is offline
post #469 of 3576 Old 01-30-2008, 09:51 PM
rmb2485
rmb2485's Avatar
So this is more or less what I am going to do. Also, the wire I picked up is braided. Don't worry, I wouldn't have even thought of using solid core. As for the fuse, it was there, so was I, the auto part store was another 5 minutes down the road, I bought it, it's all good. Normally I wouldn't get this kind of stuff from radio-shack but it was actually cheaper than the local auto parts store.
Ok, by that writeup you do need a fuse because you're essentially removing the factory fuse. The way I did mine and I think how most people do theirs is to snip one of the wires behind the factory fuse and put a switch in-line. In that case all you're doing is using the switch to make or break the connection between the dome light and the factory fuse.
rmb2485 is offline
post #470 of 3576 Old 01-30-2008, 09:55 PM
mall0y
Correct, this is what I was going for. This way you don't have to worry about cutting any wires and whatnot. So, if I ever wanted to remove the switch, It's as simple as replacing a fuse.
mall0y is offline
post #471 of 3576 Old 01-30-2008, 10:07 PM
Justin Brimm
I just meant in general anything he adds to the circuit will be protected by the factory fuse already in the circuit. Sorry if I wasn't entirely clear about what I meant.
I didn't know he was cutting the factory fuse out of the circuit; if you are doing that, definitely add another fuse! But there's really no reason to cut the factory fuse out of the circuit. All you have to do is tap the switch into the 12v+ and ground wires of the original circuit.
post #472 of 3576 Old 01-30-2008, 11:37 PM
97MilitaryTJ
97MilitaryTJ's Avatar
Originally Posted by frankiejr
Jappe, I'd love to see more pics of that hard tonneau cover, if you have any. That thing looks sweet. Looks aluminum... home made, right?
Could you post a shoot of you rear gate open? Did you weld and graft the lower portion of the door to the jeep? Nice looking job....
97 TJ, 2.5, Auto, 33x9.50/15 on MT's, WARN front and rear bumpers, Best Top tinted top, Pioneer Stereo, 4 4.25" Kenwood speakers, D30HP and D35 with 4.56 gears, 3.5 Skyjacker lift
BLACK JEEP CLUB MEMBER #1997
2008 National Topless Day Participant #1
97MilitaryTJ is offline
post #473 of 3576 Old 02-01-2008, 11:56 AM
OrionAZ
I made a trailer
About two years ago I built that. It tows great and keeps us dry and warm. http://picasaweb.google.com/Ellswort...79626624626754
OrionAZ
2000 Sport Wrangler, I6 4.0L Dana 30-35 3.73
Mods so far - After market A/C, Security system, Custom made add a trunk, Black bezels, 3" Full Traction lift, Bridgestone dueler revo 31x10.5x15 tires on Black steeles. Still Married!
OrionAZ is offline
post #474 of 3576 Old 02-01-2008, 05:54 PM
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
That's a nice tear drop trailer. Can you tell me how much money and labor hours it took?
2009 JK Rubicon (Former Daily Driver); 2014 VW Jetta GLI Autobahn w NAV.
Auto, Power, Remote Start, Towing Package, MyGig Navigation with Lockpick, Rear View Camera, B&M 70268 Transmission Cooler, Aeroforce Interceptor, Valentine 1, Tub Sound-Deadened with Raamat and Ensolite, Hard Top Heat Insulated with 1/2" Styrofoam Insulation, Bilstein Shocks Front & Rear, PIAA Dual Horns, IPF 920H4 Headlights.
Protection: Skid Row Engine Skid, Lower Control Arm skid & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Differential Skid Front & Rear.
Recovery Gear: Warn 9.5Ti Winch, 11,000# Pull-Pal.
Communication: Uniden 520XL CB, Diesel External Speaker, 3' FireStik Whip.
Shrockworks Mid-width Front Bumper with Warn 9.5Ti Winch -- Ordered 7/17/2009; Bumper Received 12/4/2009.
1" Coil Spacer Front & 1/2" Coil Spacer Rear restored OEM Rake.
4x4 Trips:
Moab - 4/2006, 5/2008, 4/2009, 5/2011, 4/2013
Ouray - 8/2007
Rubicon - 9/2008
Gone, but not forgotten: 2004 TJ, 1999 Audi A4, 1992 VW Jetta GL 5 Speed
Thunderstrike is offline
post #475 of 3576 Old 02-01-2008, 06:33 PM
OrionAZ
About $5000 and 3 months of night and weekends. PM me your email and I will send you some others pics. The Trailer is sitting on a 5000 lb axle and custom frame its warm in the winter but you cook outside. The back hatch covers a full gally kitchen.
OrionAZ
OrionAZ is offline
post #476 of 3576 Old 02-02-2008, 12:39 PM
JWitt333
i did not not buy any fuses, I cut the wires behind the fuse box. the only real expense was the switch. i bought enough wire to do multiple projects. this was the cheapest mod i have ever done...
'99 Gunmetal TJ
Blue Jeep Club Member #256
4" RC X-Series, 1in BL
Rokmen Armor
KC Day Lighters, 33 BFG M/T
with more to come
OlllllllO
JWitt333 is offline
post #477 of 3576 Old 02-02-2008, 06:02 PM
sweetguardian00
1946 CJ2A
I made custom reverse lights for my TJ, they look stock and only cost $20.00
and a shock........they actually make a difference
id add pics if i knew how
cam
sweetguardian00 is offline
post #478 of 3576 Old 02-02-2008, 07:09 PM
rmb2485
rmb2485's Avatar
cam
Upload the pics to photobucket or some other photo site then post links to them here. One of us will make them click free for you because you need 50 posts to do that.
rmb2485 is offline
post #479 of 3576 Old 02-03-2008, 09:01 AM
ZBDsTJ
back window holder-upper
How about this? Hate to roll up your back window when it's dirty or crusty, or lay it someplace when you get to your wheelin' spot? Or even leave it at home when it's a little chilly or raining or ...? I fixed mine so it would swing in toward the roll bar and tie up out of the way. Take the tailgate bar out of the bottom of the window. On the front side, the side that goes against the black metal piece on the tub, you will see a hollow plastic piece about 3 or 4 inches long. Thread a shoe string, leather or webbing (I used an old dog leash about 1/2" wide) from the inboard side through to the out side and back through to the inboard side and tie a knot. Now you should have a loop ont the outboard side and a knot on the inboard side. Swing the window inward toward the back of the front seats and tie it off to the roll bar through the loops you just made at each end of the tailgate bar. Cheap, easy, no scratches, you've got your back window for the ride home. Took it for, a spin yesterday with no front door uppers, did have the rear sides on, and it doesn't flop around. Had it up to 65 or so. "I just love it when a plan comes together." Just an idea.
ZBDsTJ is offline
post #480 of 3576 Old 02-03-2008, 10:42 PM
JWitt333
any pics????
'99 Gunmetal TJ
Rokmen Armor
with more to come
OlllllllO
JWitt333 is offline
home made , homemade , tj
I made a _____ for my YJ! (post your homemade Jeep stuff here) shinigami YJ Wrangler Technical Forum 3593 02-26-2017 05:43 PM
Has anyone made a Homemade Hardtop Sunroof? snaustin09 YJ Wrangler Technical Forum 10 04-14-2015 06:31 AM
where is the homemade stuff thread??????????????????????????????/ michaelg TJ Wrangler Technical Forum 9 11-11-2008 07:33 PM
Anyone made a homemade Hood lift? Sky Hye TJ Wrangler Technical Forum 10 10-15-2007 09:16 PM
home made stuff surfsmeller YJ Wrangler Technical Forum 1 05-03-2004 06:32 PM
