I made a _____ for my TJ! (post your homemade Jeep stuff here) - Page 25 - JeepForum.com
 4Likes
post #361 of 3576 Old 12-09-2007, 08:56 PM
stedwest
Bump.....!
2003 SE, 4.88's, Yukon axles, Rancho springs, JKS Disco's & MML, RE trackbars, ZJ steering, and a bunch of other stuff my wife hasn't found out about...
stedwest is offline
post #362 of 3576 Old 12-19-2007, 03:31 AM
Krisfyr
Bump to top, bump bump
2003 Wrangler Sport, Lightforce Striker 170's, 33 in Goodyear MT/R's
A to Z Fabrication Rocker Guards
Nth Degree 5 Inch Long Arm with Rear diff Slider, Tummy Tucker, QuickSilver Disco's
Old Man Emu Shocks and steering stabilizer, Tom Woods Custom Driveshaft
AA SYE, Rokmen Mercenary Front Bumper,L O D Offroad Rear Bumper/tire carrier
Warn 9.5 Ti
Krisfyr is offline
post #363 of 3576 Old 12-19-2007, 06:55 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
STICKIE Stickie!
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #364 of 3576 Old 12-19-2007, 10:24 AM
Tahoezr
Originally Posted by Dcomf
The main idea was borrowed from here:
http://www.helton.com.au/
Most of it is outlined there and they show the exchanger mounted in different vehicles. I made my own heat exchanger from 3" copper pipe and copper refrigerator coil much like the heaton exchanger. If you build your own they show the internals of their exchanger to give you an idea how it's done. It is mounted and plumbed into your coolant lines going to the heater core. It is efficient enough that there is usually no need for a second pass through to get water at shower temp. The pump is a small Flojet 1.1 gpm RV pump with a shutoff of 35psi that feeds into the exchanger. Pump was around $35. Use simple garden hose for gazinta and gozoutta water lines and find a place to mount everything.
Here’s an idea that anyone can use. That is, if you don’t have an automatic transmission.
About 10 years ago, I replaced my radiator in my ’86 CJ-7 from a 2 core to a 3 core. The radiator is the same for an auto or standard tranny.
As I was installing the radiator, I noticed on the bottom of it were the attachments for the auto tranny cooler. Since I had a standard, the fittings were capped off.
So I took off the caps and fitted one with a brass quick connect for the output and the other I connected a low flow RV water pump. I put the quick connect before the pump for the input. When I tried the pump on the output side, the heat tended to make the pump stop working properly. You can experiment with that and let me know.
I also used a low flow shower head. It won’t have the pressure you’re used to at home, but keeping the flow slow helped the water get warm. I put in a valve on the output side to control the temp. The faster the water came out, the cooler it was. So, it was a simple but effective temp control.
So, with a water source and the engine running, it wasn’t a bad little shower.
Good luck.
Tahoezr is offline
post #365 of 3576 Old 01-02-2008, 11:04 AM
jdub92179
jdub92179's Avatar
2009 JK Wrangler
stickie please!
l_JEEP_l
(OlllllllO)
jdub92179 is offline
post #366 of 3576 Old 01-02-2008, 01:34 PM
bman9089
bman9089's Avatar
Originally Posted by jdub92179
stickie please!
x2 - please sticky this thread!
"The American Republic will endure, until politicians realize they can bribe the people with their own money." -- Alexis de Tocqueville
“Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it” -- Mark Twain
Romans 12:5 | 1 Peter 3:15 | Matthew 9:37-38
bman9089 is offline
post #367 of 3576 Old 01-02-2008, 03:50 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
This thread is now a sticky.
Wheelin98TJ is offline
post #368 of 3576 Old 01-02-2008, 05:17 PM
jdub92179
jdub92179's Avatar
2009 JK Wrangler
Sweet!
l_JEEP_l
(OlllllllO)
post #369 of 3576 Old 01-02-2008, 06:59 PM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
and what did you do to your TJ isnt a stickey
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #370 of 3576 Old 01-02-2008, 07:08 PM
03Wrangler
03Wrangler's Avatar
2010
diddn't it used to be?
03Wrangler is offline
post #371 of 3576 Old 01-02-2008, 07:56 PM
JeepRocks86
I think this thread bumped it off
For Sale:
post #372 of 3576 Old 01-02-2008, 10:43 PM
PBR
PBR's Avatar
finished front bumper i build today. thinking about putting in a radiator/hood hoop soon also!
PBR is offline
post #373 of 3576 Old 01-03-2008, 05:48 AM
jonesy02
got me some new seats
call me a pansy but leather sure is comfy!
http://www.jeepforum.com/forum/f9/jeep-wj-99-04-grand-cherokee-seats-tj-502230/
jonesy02 is offline
post #374 of 3576 Old 01-03-2008, 07:05 PM
ballanjl
ballanjl's Avatar
Great Look'in Bumber
REDTJ35, You have any plans drawn up you care to share? That's a great look'in bumber! How heavy of material did you use? What about the winch mount, was it a separate piece?
Jim B
ballanjl is offline
post #375 of 3576 Old 01-03-2008, 07:29 PM
PBR
PBR's Avatar
sorry no plans. its 4x2x3/16 rectangle tube. 42" wide. i used rokmen front bumper mounts. and the little stinger or grill guard whatever u call it is off a bronco bumper i bought for 5 bucks, i just cut that part off it and put it on my bumper. the winch is on a warn winch plate. also ill be putting on clevis mounts to.
PBR is offline
home made , homemade , tj
I made a _____ for my YJ! (post your homemade Jeep stuff here) shinigami YJ Wrangler Technical Forum 3596 05-15-2017 01:26 PM
Has anyone made a Homemade Hardtop Sunroof? snaustin09 YJ Wrangler Technical Forum 10 04-14-2015 06:31 AM
where is the homemade stuff thread??????????????????????????????/ michaelg TJ Wrangler Technical Forum 9 11-11-2008 07:33 PM
Anyone made a homemade Hood lift? Sky Hye TJ Wrangler Technical Forum 10 10-15-2007 09:16 PM
home made stuff surfsmeller YJ Wrangler Technical Forum 1 05-03-2004 06:32 PM
