I made a _____ for my TJ! (post your homemade Jeep stuff here) - Page 24 - JeepForum.com
post #346 of 3568 Old 12-04-2007, 06:10 PM
raskull
raskull's Avatar
Great idea, but I still don't see what's so hard about removing the #4 fuse.. put a small pair of needle nose pliers in your glove box.
(O|||||||O)
l_l*-----*l_l
Raskull - Metallic Silver '03 Jeep TJ Sport (
<- Write-ups on mods/maintenance/trips and a video/image gallery
raskull is offline
post #347 of 3568 Old 12-04-2007, 06:31 PM
03Wrangler
03Wrangler's Avatar
2010
Originally Posted by Thunderstrike
BEST MOD I'VE SEEN LATELY. Fuse mod also takes out the buzzer warning for lights, so this mod's much better. I would improve on the mod to add an open hook side to slide under a screw at the other side.
to the OP ,you said you broke both of your switches... how did this happen if the bar was there to prevent them from becoming damaged... im quite confused...
03Wrangler is offline
post #348 of 3568 Old 12-04-2007, 06:32 PM
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
Problem with that is it also disables warning buzzer for headlight being on. So, down South one has to drive with headlights on when raining. You can leave the headlight on easily when you leave for lunch or get back. Almost had run down the battery.
2009 JK Rubicon (Former Daily Driver); 2014 VW Jetta GLI Autobahn w NAV.
Auto, Power, Remote Start, Towing Package, MyGig Navigation with Lockpick, Rear View Camera, B&M 70268 Transmission Cooler, Aeroforce Interceptor, Valentine 1, Tub Sound-Deadened with Raamat and Ensolite, Hard Top Heat Insulated with 1/2" Styrofoam Insulation, Bilstein Shocks Front & Rear, PIAA Dual Horns, IPF 920H4 Headlights.
Protection: Skid Row Engine Skid, Lower Control Arm skid & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Differential Skid Front & Rear.
Recovery Gear: Warn 9.5Ti Winch, 11,000# Pull-Pal.
Communication: Uniden 520XL CB, Diesel External Speaker, 3' FireStik Whip.
Shrockworks Mid-width Front Bumper with Warn 9.5Ti Winch -- Ordered 7/17/2009; Bumper Received 12/4/2009.
1" Coil Spacer Front & 1/2" Coil Spacer Rear restored OEM Rake.
4x4 Trips:
Moab - 4/2006, 5/2008, 4/2009, 5/2011, 4/2013
Ouray - 8/2007
Rubicon - 9/2008
Gone, but not forgotten: 2004 TJ, 1999 Audi A4, 1992 VW Jetta GL 5 Speed
Thunderstrike is offline
post #349 of 3568 Old 12-04-2007, 07:12 PM
rmb2485
rmb2485's Avatar
Do you make it a habit to drive with the doors off in the rain?
rmb2485 is offline
post #350 of 3568 Old 12-04-2007, 07:21 PM
Thunderstrike
2009 JK Wrangler
No, but I use the switch to turn "off" the #4 fuse when I have doors open for a long time to save battery from lightening up interior light, e.g., loading, unloading, working on my rig, etc. Then, I would forget to toggle the switch back on. So, when I use headlight during daytime I end up leaving it off. I now try to remember to turn the toggle switch back on.
4x4 Trips:
Ouray - 8/2007
Rubicon - 9/2008
post #351 of 3568 Old 12-04-2007, 08:52 PM
NalinMFG
bump. wow. this is by far the best thread ive seen anywhere. ever.
NalinMFG is offline
post #352 of 3568 Old 12-04-2007, 09:52 PM
BaddAndy
Originally Posted by Unlimited04
Nice work. that kinda setup isn't for me, but that is definitely one of the cleanest wiring jobs i've seen.
Thanks for the compliment. I figure a clean job prevents problems further down the line.
I like the switch for the domes/warning chime, I probably use it 20 times on a trail run at night, doors on or off.
2001 Jeep TJ Sport, SOLD!
2013 JK Sport, 6 Speed manual, RC 3.5" Series II, GY DTs 315/70/17, Pro Comp 7005s 17x8, Rubi 44s
BaddAndy is offline
post #353 of 3568 Old 12-04-2007, 09:55 PM
brooksjeep
This needs to be a permanent thread! right under the wheeling pics!
brooksjeep is offline
post #354 of 3568 Old 12-05-2007, 07:07 AM
skeebs
Thanks for the compliments guys, much appreciated
I was bored one day and figured I'd try it cause I saw those little brackets in the drawer, figured they'd do the trick. And I was sick of wedging my hand a pliers behind the glove box to pull that fuse.
The reason the switches broke is the arc in the bracket. When I closed the door it pushed them in further than they are supposed to be.
I ride with my lights on in every vehicle I drive, it's just my common practice to shut them off when I shut the vehicle off. I am sure we all know it's the law to ride with your lights on in PA thru construction zones, when it's raining, etc.....and PA is in constant state of road construction...LOL So I just got used to turning them on when I get in and shutting them off when I get out.
skeebs is offline
post #355 of 3568 Old 12-05-2007, 07:31 AM
legend6009
legend6009's Avatar
why doesnt anyone put that number four fuse on a switch? just flip it off when the doors are off...seems would be easier to do then keep taking your glove box out?
-Andy-
06-tj-2.4 4 cyl, 6 speed. red, 2.25 bb on 31s, rear aussie locker, hella 500 series on bumper, mile marker pe8000, rock krawler rear bumper w/ hitch, optilux lights mounted on stainless steel windshield light brackets, in cab winch switch
red jeep club member 479
my myspace^
legend6009 is offline
post #356 of 3568 Old 12-05-2007, 07:36 AM
skeebs
I hear of a lot of people that do that. If i ever find a switch laying in my garage I might do that, but this was the best price - FREE.....aside from busting the buttons; which will never happen again after I replace them, if I even replace them that is.
skeebs is offline
post #357 of 3568 Old 12-05-2007, 08:01 AM
wahooz04jeep
Originally Posted by BostonJosh19
I really like this. Looks good. do you have any pics of the interior? I'm curious of how you attached it to the tub. Also, how do you keep it locked so no one can open it from the outside?
Do you have a write up for this. I would love to do that to mine.
2007 Jeep Patriot Sport
OlllllllO
I wave
wahooz04jeep is offline
post #358 of 3568 Old 12-05-2007, 08:03 AM
wahooz04jeep
Originally Posted by markc522
OK this is the write up that I want. lol sorry guys
OlllllllO
I wave
post #359 of 3568 Old 12-05-2007, 08:23 AM
GroundAssault
GroundAssault's Avatar
Looks so good. I want to do something like that this summer. Is the top strong enough for a tire to be mounted, or a cooler.....you know that kind of thing? Is the measurements hard? I was a metal worker and could get down to the .001 of an inch by sight....but when it comes to wood I am retarded. Any suggestions would be great...
2006 Jeep Wrangler---SOLD!
Nowhere at present is there such a measureless loathing of their country by educated people as in America. --Eric Hoffer
cheap mods are like a drug dealer giving you your first few for free...they will only get you addicted and before you know it every paycheck goes into your new habit :rofl:
GroundAssault is offline
post #360 of 3568 Old 12-05-2007, 09:19 AM
BozoWise
BozoWise's Avatar
Mine is on a switch. Writeup in my build post.
My 1 ton TJ build project "Evil Monkey":
BozoWise is offline
home made , homemade , tj
I made a _____ for my YJ! (post your homemade Jeep stuff here) shinigami YJ Wrangler Technical Forum 3592 Yesterday 03:49 PM
Has anyone made a Homemade Hardtop Sunroof? snaustin09 YJ Wrangler Technical Forum 10 04-14-2015 07:31 AM
where is the homemade stuff thread??????????????????????????????/ michaelg TJ Wrangler Technical Forum 9 11-11-2008 08:33 PM
Anyone made a homemade Hood lift? Sky Hye TJ Wrangler Technical Forum 10 10-15-2007 10:16 PM
home made stuff surfsmeller YJ Wrangler Technical Forum 1 05-03-2004 07:32 PM
