I made a _____ for my TJ! (post your homemade Jeep stuff here) - Page 202 - JeepForum.com
 4Likes
post #3016 of 3576 Old 06-25-2011, 10:41 PM
woodscavenger
1976 CJ5
Slick fire ext mount. good location on the electronics box. I would like to move the air intake and put a bigger ammo can tool box in that same place.
woodscavenger is offline
post #3017 of 3576 Old 06-26-2011, 02:37 AM
djflyy
Thanks! It was the only place in the engine compartment that I wouldnt have had to drill holes, wires were easy to run to, and it mounted up perfectly. What more can you ask for!
djflyy is offline
post #3018 of 3576 Old 06-26-2011, 03:32 AM
jclauson
I know I have a YJ and feel like im cheating on the YJ section but that fire ext mount is pretty sweet. ill probably steal that idea and fab one up.
1990 YJ w/ lots of home made sh*t
check it out
http://www.jeepforum.com/forum/f22/hysterias-90-yj-build-1190617/
jclauson is offline
post #3019 of 3576 Old 06-26-2011, 03:09 PM
mattlock1983
mattlock1983's Avatar
thanks, i like it. this mount was more of a proof of concept prototype than a finished product. the next one will be easier to make. i am going to change the design to use an open ended / closed ended wrench for the center piece and use U channel bar for the part that mounts to the roll bar. that way there will be minimal welding, no plasma cutting, and hardly any grinding.
2004 Rubicon Artic Silver, Automatic
~2.5" Lift, LT285 MTR's, Currie HD steering, Currie Anti-Rock, Nth Oil Pan Skid, Kilby Steering Skid, Warn HS9500, Rockcrusher Diff covers, Nth Slider rear DS skid, custom bumpers, PIAA reverse lights, Tuffy Console, Uniden PC78 elite CB, Nth TT (not installed)
mattlock1983 is offline
post #3020 of 3576 Old 06-27-2011, 06:20 PM
JDEEEWP
Recycle Bin Holder!!
Easy way to keep the stale beer smell out of the Jeep! it looks a little goofy on recycle day but that's only till the end of my long driveway, i hope... I haven't forgotten about it yet but i am sure it would be interesting once i hit the highway.
'01 TJ Sport (black), 4.0L, 5speed, Dana44, Flowmaster 50, 2"BB + OME, 32"ATs on 16" alloys.
'01 Suzuki GSX-R750(red), -1T 520 kit.
JDEEEWP is offline
post #3021 of 3576 Old 06-28-2011, 03:03 PM
rtbtitans50
Originally Posted by drift2death View Post
can you send me the tread to that bumper build?
I added it to my sig
HILLTOP O.R.V.
rtbtitans50 is offline
post #3022 of 3576 Old 07-03-2011, 11:12 PM
tbevans
Rear Work Lights
So I had earlier on this thread posted my installing work lights on to my Jeep to a) give me lighting to the rear to accomplish miscellaneous tasks and b) have brighter lights when I'm in reverse. I wanted to be able to switch my lights to come on when I wanted to, switch them off, and switch them so that they only came on when I was in reverse. It took some drinking to figure it out and by my 4th Guiness I had drew out the schematic of how it would all work...I was also in need of a ride from the bar. This is a cleaned up version of how it works:
Reverse Lights Project by lumineferusother, on Flickr
I installed a relay in my right rear fender well. This is for the side of the switch that would only come on when I was in reverse. The coil side of the relay was wired into the right reverse light wire (Violet/Black). The switch side was wired to one side of the switch.
Relay for Rear Work Lights by lumineferusother, on Flickr
The trick to all of this was to wire the switch "backwards" i.e. the "INCOMING (+)" terminal was wired straight to the lights and the upper "OUTGOING (+)" terminal was joined with the lower "Outgoing (+)" terminal and spliced with a wire going to a position on my auxiliary fuse block fused with a 20A fuse.
Rear Work Lights Switch by lumineferusother, on Flickr
My lights were mounted to my Rock Hard 4x4 Rock Rack. The result was pretty impressive:
Untitled by lumineferusother, on Flickr
Work Lights at Night by lumineferusother, on Flickr
Here's my total list of parts:
Pair of cheap Auto Zone lights
Automotive Relay
ON/OFF/ON Rocker Switch with Battery Icon (courtesy of OTRATTW)
14 guage wire (black and red)
10 guage wire (black and red)
A bunch of push-on terminals
2 spade terminals for my ground
All in all an approx. $40-50 project!
tbevans is offline
post #3023 of 3576 Old 07-06-2011, 01:31 PM
Digitac
On board running water! I'll just post a link to my other thread:
http://www.jeepforum.com/forum/f9/ob...build-1236148/
Basically it's a pressurized Sceptre water can with a faucet on the lid.
::Digitac
Digitac is offline
post #3024 of 3576 Old 07-09-2011, 07:51 PM
dbbd1
dbbd1's Avatar
I notched some 1 1/2" tubing to mate onto my Bestop tire carrier, welded it on. A tall piece up and a stubby piece down, then mounted my Fourtreks clamps and now I can hang my hi-lift on my tire carrier. (you could also just do the same thing without the clamps by just using nuts and bolts o nto the welded extensions, I just did not want to violate the structural integrity of the tire carrier tubes)
The opinions of worthless people, are worthless.
The only problem that you have with anyone in this world, is what you expect of them.
Society is no match for a stupid person.
"Life Is tough but it is tougher when you are stupid"
-John Wayne
dbbd1 is offline
post #3025 of 3576 Old 07-21-2011, 10:43 PM
djflyy
Revival of an untouched thread, just wanted to add this here as well as in the thread I made. I built this fire extinguisher mount to allow me to keep it right under my feet in the driver's seat at all times. Simple 1" steel bar bent, cut, and rivited to the quick-release Kidde mount and FA110 extinguisher.
djflyy is offline
post #3026 of 3576 Old 07-22-2011, 05:39 AM
06RubiconBlue
I have posted these in another thread already but, im pretty damn proud of them. I made a front and rear bumper (swing tire carrier to come after the 33x12.50 upgrade) . (FYI I DID NOT make the Winch plate or tubing)
06RubiconBlue is offline
post #3027 of 3576 Old 07-22-2011, 06:22 AM
djflyy
Great bumpers! The front one looks like something you could by through Quadratec!
djflyy is offline
post #3028 of 3576 Old 07-22-2011, 05:16 PM
Elwood
Elwood's Avatar
2016 JK Wrangler
nu_yorka_ , could I have more info on how you fasten your shelf to the tub and more pics. please? That looks very sharp, I like it!
A quote from my wife: "I don't even want to know how much it cost, I'm not in the mood to be that pissed off today."
Elwood is offline
post #3029 of 3576 Old 07-28-2011, 07:21 PM
Djay101
I made a wooden shelf that sits on the tire wells in the back, makes easier for gear to be access easier
""" Its a jeep thing, you wouldn't understand!"""
""" Jeep... is it in you? """
my build thread...
Djay101 is offline
post #3030 of 3576 Old 07-29-2011, 10:08 AM
skouklis
made a speaker box / storage
skouklis is offline
home made , homemade , tj
I made a _____ for my YJ! (post your homemade Jeep stuff here) shinigami YJ Wrangler Technical Forum 3596 05-15-2017 01:26 PM
Has anyone made a Homemade Hardtop Sunroof? snaustin09 YJ Wrangler Technical Forum 10 04-14-2015 06:31 AM
where is the homemade stuff thread??????????????????????????????/ michaelg TJ Wrangler Technical Forum 9 11-11-2008 07:33 PM
Anyone made a homemade Hood lift? Sky Hye TJ Wrangler Technical Forum 10 10-15-2007 09:16 PM
home made stuff surfsmeller YJ Wrangler Technical Forum 1 05-03-2004 06:32 PM
