I made a _____ for my TJ! (post your homemade Jeep stuff here) - Page 19 - JeepForum.com
 4Likes
post #271 of 3576 Old 10-11-2007, 06:16 PM
JEEP97TJ
Originally Posted by TJJEEPER
I built a hitch hauler for mine.
That looks saweet. All that storage space....would be nice. And nice departure angle.
Blacksburg, VA
JEEP97TJ is offline
post #272 of 3576 Old 10-11-2007, 06:34 PM
ScottD06X
2011 JK Wrangler
Yeah , best one I have ever seen. All of the others I've seen are straight out, hitch level and always dragging on everything. Does it also secure to the spare for stability?
ScottD06X is offline
post #273 of 3576 Old 10-11-2007, 07:10 PM
TJJEEPER
TJJEEPER's Avatar
No, it barely touches the spare. The spare was a 31/10.50 when I built it, when I up'd it to a 33" I had to slide it out and redrill the pin hole. When I mount the box on it, I secure it to the bumper with ratchet straps to stabilize it a little more. It fits pretty tight anyway, I ran beads of weld down the side of the tubing and ground down to a tight fit in the receiver. Four of us have traveled to Camp Jeep 02 in Branson, and CJ 03 in Virginia and on to Va Beach for a week in it. Told the kids to pack light, but we had room for all our luggage. Had to buy the large duffel, to lash to the top, at CJ 03 to get all our souvenirs home. Couldn't drive at night, the lights pointed too high.
JEEP, Not Just a Vehicle. A WAY
97 TJ, 4.0, 5sp, OME Susp., 1 3/4 coil spacers, 1" BL, 35" Xterrains, Dynatrac Trail 60 with ARB, D30F, 4.56's, LockRite F, Discs F&R, K&N, Borla Header, Flowmaster Super 44 Off-Road Muffler, Front LineLock, Diehard Platinum P-1...
06 Commander
TJJEEPER is offline
post #274 of 3576 Old 10-11-2007, 08:56 PM
adamhendrickson
wow
Man i gotta practice my welding
Black 97 w/ -- 2" procomp lift--33x12.50 D C Crushers on 15x10 Black ION wheels--Warn M8000 on AtoZ Fab plate--Xenon flat-style flares--Delta lights on the bumper, the windshield and the rollbar facing the rear--and the list grows daily!
adamhendrickson is offline
post #275 of 3576 Old 10-11-2007, 10:02 PM
Corey4x4man
for sure keep em comin!
98 tj 4.0, 4" RC, 1" body,4.88s, Auburn ECTED in front, 8.8 with ARB in rear, rollin on 35s. JKS discos, SYE/CV DS, MML, milemarker 8000, homemade OBA, more to come it never stops.
Corey4x4man is offline
post #276 of 3576 Old 10-13-2007, 11:23 AM
Guitarhead09
this is one of the best threads, bump
Guitarhead09 is offline
post #277 of 3576 Old 10-16-2007, 06:53 PM
sealion2288
This thread needs to be made permanent! BUMP!!
sealion2288 is offline
post #278 of 3576 Old 10-16-2007, 07:37 PM
chappy84
chappy84's Avatar
What a bunch of really great ideas!@! I am impressed with some of the inginuity on this thread. I want to see more!
-CHAPPY-
chappy84 is offline
post #279 of 3576 Old 10-16-2007, 08:03 PM
NMLJ
NMLJ's Avatar
I modified my trans skid's crossmember so it would not rub my driveline. I welded a 3/16 strap to the bottom of the crossmember under the area I wanted to cut out. Then I cut out the front of the crossmember and removed it. Then I made two cuts on top perallel to my front cuts. Next I bent the top down and welded it to the strap I welded in previousley. It is harder to try to explain what I did than it was to do it.
/l ,[___],
l--L --OlllllO-
()_) ()_)-o-)_)
-2006 Impact Orange LJ-
MY BUILD THREAD
THE HARDEST THING ABOUT A ZOMBIE OUTBREAK WOULD BE PRENTENDING NOT TO BE EXCITED
NMLJ is offline
post #280 of 3576 Old 10-16-2007, 08:23 PM
ej's tj
ej's tj's Avatar
check out my gallery for some pix of my back bumper I built......I can not figure out how to post them here
2005 Unlimited Rubicon bright red, wet okole, 2 1/2" (more like 3"+) HD OME 1 1/4" JKS BL, JKS Discos, 1" JKS MML,28575R16 BFG MTs, Custom HD rear bumper, 2 year old Akita,
9500 lb. milemarker winch, kilby gas tank skid, home made rear bumper and tire carrier, lite dot taillights, more to come!!!!!!
Integrity is a rare find!
ej's tj is offline
post #281 of 3576 Old 10-16-2007, 09:07 PM
nolo263
looks good you should have made a write up that certainly looks different than the other ones I have seen..good job..
Does it rattle at all??
nolo263 is offline
post #282 of 3576 Old 10-17-2007, 07:28 AM
GroundAssault
GroundAssault's Avatar
Bump, I am not very good at coming up with ideas but I want to keep this thread going so I can get some good ideas
2006 Jeep Wrangler---SOLD!
Nowhere at present is there such a measureless loathing of their country by educated people as in America. --Eric Hoffer
Originally Posted by rmb2485
cheap mods are like a drug dealer giving you your first few for free...they will only get you addicted and before you know it every paycheck goes into your new habit :rofl:
GroundAssault is offline
post #283 of 3576 Old 10-17-2007, 08:16 AM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
i made lower bump stops, well didn't really make them but i did a custom install of hockey pucks. drilled and tapped the lower spring mount.
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #284 of 3576 Old 10-17-2007, 09:06 AM
Chipper004
Originally Posted by rock-rash
Since I now have the LoD rear tire bumper/carrier I needed to get a third brake light on there somehow. So I took the factory third brake light and cut it seven and a half inches from the top. I drilled a 1/2 hole just below where the light has that little cover on the front side and mounted it to the stud at the top of the tire carrier. The stud is there to mount a hi lift jack. (My hi lift is mounted inside of the jeep.) I have a few inches of clearance between the top of the spare and the light. This allows for up-sizing the tires in the future.
The wiring is the same as factory only with added length.
Attachment 29021
Attachment 29022
I did the exact same thing. But got a thin piece of metal and bent it at a 90*. Drilled pilot holes in the very top of the carrier and then used self tapping bolts to fassen it on there. It sticks up a bit more so if I decide to go w/ 35's some day I'll have clearance. I also didn't go through the bolt provided on the carrier b/c I have my Hi-lift attached to it. Here's a pic.
Chipper004 is offline
post #285 of 3576 Old 10-22-2007, 06:16 PM
sealion2288
More great ideas?
home made , homemade , tj
I made a _____ for my YJ! (post your homemade Jeep stuff here) shinigami YJ Wrangler Technical Forum 3596 05-15-2017 01:26 PM
Has anyone made a Homemade Hardtop Sunroof? snaustin09 YJ Wrangler Technical Forum 10 04-14-2015 06:31 AM
where is the homemade stuff thread??????????????????????????????/ michaelg TJ Wrangler Technical Forum 9 11-11-2008 07:33 PM
Anyone made a homemade Hood lift? Sky Hye TJ Wrangler Technical Forum 10 10-15-2007 09:16 PM
home made stuff surfsmeller YJ Wrangler Technical Forum 1 05-03-2004 06:32 PM
