#2476 | |
My guess it that it's gravity fed.... If the valve isn't open, the water is just laying in the hose, just like at home... But what do I know?
Dirty Mudder seat covers/Steering column covers/spare tire covers Like my Dirty Mudder FB fan page here: http://www.facebook.com/pages/Dirty-Mudder/135372306475827?ref=search 01 Jeep Wrangler Sport 4.0L, auto Sienna Mine 07 2D Rubicon Flame Red His |
#2477 | |
Please re-read the OP's post... ![]()
07 Unlimited Rubi Rescue Green/Auto/pwr 5" Frankenlift/37" KM2/5.13/Spidertrax 1.5"/Tailgate shock/Orbit Remote Start/Smittybilt XRC8/Hella Black Magic/Etc etc |
#2478 |
Thanks for clearing that up, sorry for the bad info....
#2479 |
Jack all master of none
Does the pump have a built in pressure cut-off or something? What happens if it's on but the pistol grip isn't being squeezed down to open the tap?
You can get a Shure Flow water pump designed for an RV that has a demand switch built in that turns it off and on. It would work great for this application.
No matter how smart you might feel that you are. Remember there once was a time your main goal was learning not to crap in your pants. True evolution is an awakening. |
#2480 | |
Was thinking of trying to solve the issue using compressed air in a sealed water tank so you simulated gravity fed water pressure... but this way sounds much easier ![]() |
#2481 |
I don't have any fancy pressure switch set up. You simply flip the switch, squeeze the nozzle, then flip the switch to off when you're done. I'm sure there are better setups but for under $30 I couldn't beat this one.
#2482 |
I did a RV pump with a hose. Just set the suction side into a creek and hook up 12V. Unlimited water supply. I had a screen on the suction to prevent trash pickup.
90 YJ, 4.2 with 2150 carb 4.0 Head and headers, Nutter with TFI and MSD. 1" BL, 2.5" spring lift, 33", Goodrich KM Mud Tires. Dana 30 w Aussie, Ford 8.8 w LS. 9000lb HF Winch. |
#2483 |
Made a Trail Rack with Third Brake Light and Jerry Can Mounts:
Trail Rack: ![]() Trail Rack w/Jerry Can Mounts ![]() |
#2484 |
nice rack! on the jeep that is,haha
JACK OF ALL TRADES,,,MASTER OF NONE fla cracker head born and bred build- http://www.jeepforum.com/forum/f22/punishers-ezgo-build-thread-1065655/ |
#2485 |
Well, you know what they say, "If ya got it you may as well flaunt it." Uh, the rack that is.
![]() Thanks, Johnny9. It was my first project attempt at welding. |
#2486 |
![]() Not super impressive, but it solves a chicago winter problem. I love the rain x latitude wipers but they don't come in jeep sizes. This is a 26" that I took apart and shortened. No more issues with the old metal wiper frames freezing up. Last edited by cbossio; 07-31-2010 at 11:36 PM.. Reason: Bigger Image |
#2487 | |
New Jersey...the only state you can thank your friends for farting in the car... [url]www.jerseyjeepers.com[/url] [url]www.modernclassicenterprises.com[/url] <---[B]Flat fenders[/B] [url]http://www.jeepforum.com/forum/f22/blackheeps-build-up-1026712/[/url] <---[B]My Build[/B] |
#2488 |
Rear cargo rack for the LJ. I store my tools and cooler under the rack for wheelin. And lock valuables under it for daily driver duty. I built it out of 1" square tubbing and skinned it using expanded metal. The rack sits on the rear wheel tubs and bolts through them as well. I used heavy fender washers on the back side to keep the bolts from trying to pull through.
/l ,[___], l--L --OlllllO- ()_) ()_)-o-)_) -2006 Impact Orange LJ- MY BUILD THREAD http://www.jeepforum.com/forum/f22/nmlj-stock-rock-1077208/ THE HARDEST THING ABOUT A ZOMBIE OUTBREAK WOULD BE PRENTENDING NOT TO BE EXCITED
#2489 |
" Volkswagen "
Drop down tailgate.... Did it a couple days ago.
Jeep build up...ONGOING Jeep build up...ONGOING R.I.P. Tow Pig Dually build Rear bumper/spare tire carrier build Track bar bracket fabrication AtoZ cage install/build NeetoCJ was a generous guy and renewed my membership..... Blame him for your troubles! |
#2490 |
Kenbo, are you using the original door latch ?
| Tags |
| home made, homemade, tj |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
