I made a _____ for my TJ! (post your homemade Jeep stuff here) - Page 14 - JeepForum.com
 4Likes
post #196 of 3576 Old 04-30-2007, 07:43 AM
sardog12
sardog12's Avatar
Originally Posted by sparkeep
If they know anything about jeeps, they will put it in 4LO to start it and then put it back into high range and drive away. Clutch safety is disabled in low range.
Didn't know that. Thanks, it is good to know.
GEAUX TIGERS
sardog12 is offline
post #197 of 3576 Old 05-05-2007, 03:03 PM
PackMan
PackMan's Avatar
Location: Home of the Super Bowl XLI Champion Indianapolis Colts
Made some fog light brackets for my Jeeperman bumper with light hoop. With the light hoop, the factory fogs could not be mounted on the bumper where they belong. The light hoop is for off-road / driving lights, fogs need to be mounted low.
I spent $4 at the hardware store and bought a 3/16" steel repair strap. It was about 8" long, 1" wide, and had a few pre-drilled holes in them.
I cut about 3" off each end, and rough sanded the cut ends. They would be hidden, so I didn't bother making them look pretty. I had to drill out the hole that would mount to the bumper. I then rattle-canned them black, and used a longer grade 8 bolt for the mount from the light hoop to the winchplate on the bumper. The ends stuck out, almost flush with the top of the bumper. I then mounted my fog lights.
PackMan is offline
post #198 of 3576 Old 05-05-2007, 04:19 PM
stogie25
stogie25's Avatar
I built panels that bolt on where my winter flares go. They really clean up the line of the unflared Jeep, and offer a little protection as well.
I welded a couple of tabs onto my lightbar and attached my CB antenna on a swivel so it lays horizontal when I am not using it, and stands verticle when in use.
I modded my winch plate to accomodate my free flatbed wrecker winch.
I also built a misting system to cool me off in summer. I use my Jerry can as a water source, a RV pump, and patio misters mounted to my Olympic rack.
Jarhead Jeep Club
O|||||||O
97 Black TJ (one owner), BFG KM2 35s, 4.7L Stroker, ARB's, Dana60 rear, Dana30HP Front Warn manual hub conversion, 6 inch mostly Tera long arm lift. Rhino lined tub. Allied Rock 8 beadlocks. Tera-Low 4:1. Sanden OBA. Sniperfab tube fenders.
My Build Thread
stogie25 is offline
post #199 of 3576 Old 05-09-2007, 05:13 PM
Faramir66103
I've made a GPS/iPod mount, an Instatrunk (sort of), and some HiLift mounts.
The GPS/iPod mount is ABS plastic left over from a costuming project that I cut to shape, and formed with a heat gun. It's attached to the bezel with a simple nut and bolt.
and
The Instatrunk (sort of) is 16 guage steel that I got from a local sheet metal place. It slides under the seat belt brackets and is held in place by the rear seat. I added a strip of aluminum angle to add some rigidity. If I had to do it again, I'd probably have the sheet metal place just add a rear lip for that needed rigidity.
Here are the HiLift Mounts, not my design, something I read about here. They are shaft collars from the local Grainger drilled and tapped to accept the threaded rod.
FWIW,
Adam
'99 TJ Sport, 4.0 I6, 5 speed manual transmission, Hi Lift w/offroad kit, Viair 450C compressor, Garmin GPS, Skid Row Engine/Transmission, steering box & radiator skid plates, Kilby gas tank plate, AtoZ Fab full length rocker guards, Performance Accessories 1" Body Lift, OME 2.5" HD springs & shocks, JKS trackbars front & rear, BFG AT 33x12.5r15, EBC Yellow pads and Centric rotors
Faramir66103 is offline
post #200 of 3576 Old 05-09-2007, 06:59 PM
R. Potts
Originally Posted by Faramir66103
Nice work on everything, but I really like the Hi Lift mounts.
08 JK Rubicon Unlimited
R. Potts is offline
post #201 of 3576 Old 05-16-2007, 04:34 PM
frankiejr
Junior Member
frankiejr's Avatar
Finally got around to painting my headlight trim black.
I've really been wanting to do this for a while. Now that I know I really like the way it looks, I'm going to buy some black trim since it's only $20 and isn't painted (black plastic, dings won't affect them). Then I'll put aside my old painted ones for when I Herculiner the tub.
.frankiejr
p.s. I was finally able to bump this thread back. Yeehaw!
frankiejr is offline
post #202 of 3576 Old 05-16-2007, 04:40 PM
TJ on the Rocks
TJ on the Rocks's Avatar
Faramir66103 ,
Simple , yet very effective job with the High Lift mount .
That's probably strongest version of the sport-bar mount I've seen .
Good thinking !
I'm going to copy that .
TJ on the Rocks is offline
post #203 of 3576 Old 05-16-2007, 07:57 PM
Faramir66103
Thanks for all the kind words folks! I really wish I'd taken down who it was who came up with that HiLift mount idea. I've had a lot of great comments on it, and would like to give credit where it's obviously due. For now let's chalk it up to "really cool JeepForum member"!
Adam
post #204 of 3576 Old 05-17-2007, 01:38 PM
Patriot
Adam
What size are the shaft collars?
'03 TJ
Blue Jeep Club Member #58
Patriot is offline
post #205 of 3576 Old 05-26-2007, 09:42 PM
rdhclark
I like the idea of mounting your jack like that, but is it possible to mount it so that you can still put the soft top down?
rdhclark is offline
post #206 of 3576 Old 05-27-2007, 12:49 AM
blkhwk20k
blkhwk20k's Avatar
Originally Posted by Thorty
this looks like a nuclear device
-Mike
'96 XJ 2-Door
blkhwk20k is offline
post #207 of 3576 Old 05-27-2007, 02:21 AM
KnightFire
KnightFire's Avatar
homemade front skid plate with some Hella Micro Fog / HID-driving lights:
Thorty
That's AWESOME! It looks nearly identical to the Tomb Raider movie Jeep's skid plate:
http://www.difflock.com/buyersguide/...er/index.shtml
I'd definitely be inclined to buy one...
Patriot Blue 4.0L
Cardinal Red 355CI
Flame Red 5.7L 4x4
Titanium Metallic 4.7L 4x4
KnightFire is offline
post #208 of 3576 Old 05-27-2007, 10:07 AM
Faramir66103
That's a good question. I'm not sure, other than I bought the ones that had an internal diameter that was equal to the external diameter of the sport bars. I didn't measure them myself since I don't have calipers that large, but someone on the original thread posted the proper dimension. I'll see what I can find.
EDIT: I checked and the shaft collars are stamped "2 1/4" which I believe means two and a quarter inches inside diameter.
Yes, the soft top still goes down, just not quite as far. It rides about 3" or so higher and I have to be a little more careful when tucking all that material in around the jack than I otherwise would have to be. The next time the soft top goes on, the lift mounts will be re-positioned lower as well. There's more room there than one would think.
FWIW,
Adam
post #209 of 3576 Old 05-27-2007, 10:32 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
This is really simple, but most people don't think of it. Went to hardware store and got 2 lock-pins for the Hi-Lift jack. One for the handle, one for the base. I had to drill the handle...so it was 2 minutes of work . Comes apart in seconds.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #210 of 3576 Old 05-27-2007, 11:27 AM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
i dont understand point of starter or clutch disable, havent you ppl ever heard of push starting? if you want to disable something make it the fuel system
RnEmOvr is offline
home made , homemade , tj
I made a _____ for my YJ! (post your homemade Jeep stuff here) shinigami YJ Wrangler Technical Forum 3596 05-15-2017 01:26 PM
Has anyone made a Homemade Hardtop Sunroof? snaustin09 YJ Wrangler Technical Forum 10 04-14-2015 06:31 AM
where is the homemade stuff thread??????????????????????????????/ michaelg TJ Wrangler Technical Forum 9 11-11-2008 07:33 PM
Anyone made a homemade Hood lift? Sky Hye TJ Wrangler Technical Forum 10 10-15-2007 09:16 PM
home made stuff surfsmeller YJ Wrangler Technical Forum 1 05-03-2004 06:32 PM
