07-18-2009, 08:12 PM
#2026
Originally Posted by kearns
I don't have dimensions, I made a cardboard dummy just big enough to fit my amp and follow the lines of the fenderwells. In the first photo of it upside down, you can see the flanges that bolt down under the seat brackets. cut a couple large holes and used 12V computer fans for ventilation. Carpeted to match and it disappears nicely.
o ok, but do you / can you still use the seat
05' TJ
07-19-2009, 07:32 PM
#2027
Yesterday I made a poor man's spare tire mount. Modified my Thule bike rack with a Dana 35 axle shaft
The rack even folds down flat to allow the rear door to open fully.
07-20-2009, 06:36 AM
#2028
thats a good idea
07-20-2009, 08:58 AM
#2029
I used 1" spacer blocks under the rear seat brackets to give enough room for the amp box, and yes, the seat still functions like stock. One more note, on either side of the seat there is a shaft that locks it down, those hit the subwoofers and needed to be cut shorter, but they still lock into the brackets fine.
I haven't had time to look for any more photos. I'll try to get to it this week.
07-21-2009, 10:14 AM
#2030
Originally Posted by shrubeck
Made a copy of this one last night for my Jeep. Total cost $13 for the pipe. I figure it will get me by better than stock until I can pony up for some real HD steering.
THANKS!!
I have beat mine pretty hard on some rocks and it hasnt bent yet.
07-21-2009, 10:17 AM
#2031
newb
I made a TJ for my LJ.
07-21-2009, 10:41 AM
#2032
Disgruntled Jeepforum'er
Location: NY/NJ/PA Tri-State Middletown NY 10941, New York
Looks great.
-Ryan
Google Voice (or the number Grape calls when drunk): 845-476-8182
Originally Posted by Enzo Ferrari
"The Jeep is Americas only real sports car!"
Originally Posted by MrBlaine
"Jeeps do not make jeepers, jeepers make Jeeps."
07-29-2009, 11:05 AM
#2033
Updated to my previous third brake light- I made a _____ for my TJ! (post your homemade Jeep stuff here) - Page 22
Made a new third brake light holder to accomodate CB antennas and create a stronger mount. The previous unit vibrated too much for my liking when the antenna hit stuff.
Finished and Sandblasted:
Welds
Primed and painted semi-gloss black and installed. Holds 2 3ft CB antennas. Those are cheapo "Diesel" antennas I got on ebay. The brake light should clear a 35" tire easy.
And no, the mounts aren't straight. The small 1/4" top plates warped during welding. And no I don't care and I probably won't fix it...
EDIT:
I had to add one of the stock rubber isolators to the mount to keep the tire carrier from whacking it. I just drilled a hole in the center square tubing and tacked a nut on it. Its a stainless M8 socket head cap screw in the isolator. Just what I had laying around. I found out the tire carrier was vibrating quite a bit off-road - this amounted to nearly 1" of deflection!
07-29-2009, 01:08 PM
#2034
brake light bracket looks good  ..its a jeep,if ya use it who wants perfect anyhow,haha
if my old trucker mind remembers right,,if you have both antennas hooked up your radio wont work worth a crap compared to 1 antenna? unless there much farther apart..i think im right on this if memory serves me right.
but 1 can always be a spare
07-29-2009, 06:09 PM
#2036
More pics please........
07-29-2009, 07:35 PM
#2037
they'll eventually be hooked to two different radios. A Cobra 75WXST and a Uniden BCT7. Right now the antennas aren't working at all...apparently I painted it too good, its not grounding!!   I gotta wait till X-mas when I go home so I can get my SWR meter too.
maybe click the link in his sig?
07-29-2009, 08:02 PM
#2038
Your right, I'm sure it is 110 inches. To get the best preformance using co-phase antenna set-ups.
07-29-2009, 08:55 PM
#2039
i made a half-door window roll down fastener! I bought Beige velcro tape (to match soft top and door color) and put one square on outside of cloth underneath bottom of window,and one on the inside. after i unzip windows i tightly roll it down and than fasten the velcro around the roll. perfect for drivin on highways with little flappin!
08-01-2009, 07:16 AM
#2040
Got any pics? I'm interested in seeing what it looks like.
Blue Jeep Club Member #193
My Jeep Pics
I live. I wheel. I am. Jeep
