I made a _____ for my TJ! (post your homemade Jeep stuff here) - Page 104 - JeepForum.com
 4Likes
post #1546 of 3576 Old 01-13-2009, 06:43 PM
SmashinTJs
BUMP for new Ideas
SmashinTJs is offline
post #1547 of 3576 Old 01-13-2009, 06:53 PM
fish4life
I made a simple, dirt cheap way to hold the rear seat in when it's folded forwards. I don't know about you, but mine always falls out of those damn mounts when i go on a trail with it folded.
Anyways, i just drilled the two pins that insert into the mount, and put a cotter pin through
so cheap, and so easy.
fish4life is offline
post #1548 of 3576 Old 01-13-2009, 06:57 PM
CliffB31
Pics please.
CliffB31 is offline
post #1549 of 3576 Old 01-13-2009, 07:01 PM
rubberducky14
a front bumper.. i'll be makin a back one with a rear tire swing too
you don't seem to be gettin much love on this thread, but THAT THING IS SICK!!!!!!!!!!! Can't wait for the tire carrier
rubberducky14 is offline
post #1550 of 3576 Old 01-13-2009, 07:56 PM
GzrGlide
GzrGlide's Avatar
Our '98 came with that from the factory!!!
Mike
<<< ya know ya want to!
98 TJ SE
RE 4.5SF with 3.5 springs & Tera QDFTs
Super 35 & Detroit in back w/4.88s
33x10.5 BFG KM2's
Cobra 75WXST w/4' Wilson Antenna
Warn M8000
(1) Rubber Ducky
GzrGlide is offline
post #1551 of 3576 Old 01-14-2009, 07:34 AM
CRJeepin
Originally Posted by Rubiconmike View Post
Way to go.
Much better take off angle.
How about some cj shots.
Wish I had some - it's still in pieces! I'm in the middle of a frame-off, the frame repair work is finished but it's too cold to POR-15 it so it's stored in the shed until it's warm enough to coat. In the meantime I'm going to rebuild the T-150 (cheap kit from Novak - why not) and finish up a few odds and ends on the motor (rear main seal, etc). And keep searching for a steel tub at the right price!
CRJeepin is offline
post #1552 of 3576 Old 01-14-2009, 10:19 AM
Rubiconmike
Nice job on the tic tac box.
To me that's what jeepin is all about.
I love makeing stuff for the jeep.
Ofcorse wheelin to.
Rubiconmike is offline
post #1553 of 3576 Old 01-14-2009, 10:39 AM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
Originally Posted by CRJeepin View Post
Here's a close up of the clamp, but that's all I got. The welds were done outside and before I spent a thousand hours burning CJ-5 frame so they are a bit rough, but they're strong enough for this. There are 3 passes, the top one is a bit spotty (used it to fill in low spots).
The clamps are Rock Hard 4x4 (the guys that make the bolt in cage), other than that just a piece of tubing bent to fit and I cheated & bought a tire mount plate for like $5 at the PA Jeep show, it was 5/8" thick and pre-drilled I figured I'd put that much into drill bits and grinding wheels if I cut my own!
If you were wanting more visibility, you could possibly turn the mount upright and hold the tire horizontally, that way you would have storage under it and it shouldn't be much higher than the rear seat. It would stick out over the tailgate and you would lose part of that 16" or so that you said you gained.
Looks good, I like it.
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #1554 of 3576 Old 01-15-2009, 08:25 AM
CRJeepin
I thought about doing that, but decided I wanted to be able to run the tailgate since I usually have tools and stuff in the back when wheeling and didn't want to risk loosing anything.
What I plan to do for "over the road" use is build a rack to go over a tonneau cover that I can mount my tire onto. That's going to use two side rails just above the tub (welded to the roll cage but removable with bolted flanges).
CRJeepin is offline
post #1555 of 3576 Old 01-15-2009, 08:55 AM
dkBOVICE
I made a custom CB mount that requires no drilling...I'll take some pictures and post this afternoon
2006 Wrangler X
dkBOVICE is offline
post #1556 of 3576 Old 01-15-2009, 10:27 AM
dbbd1
dbbd1's Avatar
Always handy to know, cannot wait for the pic's.
Thanks.
The opinions of worthless people, are worthless.
The only problem that you have with anyone in this world, is what you expect of them.
Society is no match for a stupid person.
"Life Is tough but it is tougher when you are stupid"
-John Wayne
dbbd1 is offline
post #1557 of 3576 Old 01-15-2009, 10:46 AM
JPROBSON3
Yes ^ agreed
Trails in Life:
Rubicon, Ca: 1
Hollister, Ca: 6
/l- [ ___ ]⎧
l--l-o-llllll-o-l
ROKMEN-4-Life
JPROBSON3 is offline
post #1558 of 3576 Old 01-15-2009, 12:21 PM
ID_Zizzer
CB Mount
I made an overhead CB mount out of 1x2 tubing that was laying around the garage. The wiring is all ran down behind the passenger side window trim. I also added an LED dash light under the CB.
ID_Zizzer is offline
post #1559 of 3576 Old 01-15-2009, 12:27 PM
ID_Zizzer
HI-Lift Jack
My father-in-law made some holders for my Hi-lift jack. It's scrap stainless steel from his work all welded up on graveyard shift, Cost = $0.
Only downside is that it gets frequent mud baths, but what else are you going to do with a 60" hi-lift.
post #1560 of 3576 Old 01-15-2009, 12:35 PM
Rubiconmike
Hey that opens up a hole new place to put things in the Tj's.
WAY TO GO!!!
Hey dbbd1 Can you show me a photo of you're antena mount
on the back of yer tj?
I just got a cobra 75 wx and was just going to drill a hole
on top of the tire mount on the pasenger side.
But it looks like your'es is on a bracket or some thing.
The higher the coil above the roof the better so the signal
can bounce.
The hood is the best place but it whould not last long out here with the tight trails we role in.
Here is where i wheel.
Not much dunes here.
home made , homemade , tj
I made a _____ for my YJ! (post your homemade Jeep stuff here) shinigami YJ Wrangler Technical Forum 3593 02-26-2017 05:43 PM
Has anyone made a Homemade Hardtop Sunroof? snaustin09 YJ Wrangler Technical Forum 10 04-14-2015 06:31 AM
where is the homemade stuff thread??????????????????????????????/ michaelg TJ Wrangler Technical Forum 9 11-11-2008 07:33 PM
Anyone made a homemade Hood lift? Sky Hye TJ Wrangler Technical Forum 10 10-15-2007 09:16 PM
home made stuff surfsmeller YJ Wrangler Technical Forum 1 05-03-2004 06:32 PM
