I'm torn - 35's vs 33's - Page 2 - JeepForum.com
post #16 of 64 Old 08-05-2010, 08:22 PM
SuperWade2
More Money than Brains
SuperWade2's Avatar
I built my rig for 35's+ about 3 years ago... I ran 33's until this past April.
My lift was too tall (for 33's, and the LCOG police would say too tall for 35's), my Gearing was too low (4.56's with 3sp auto) for much highway driving and my axles and other stuff (Brakes, etc) was overkill for 33's... I knew I was building for 35's and just wanted to get all of the other stuff ready before having the cash to do 35's.
I didn't run any super hard trails, but everywhere I went, I did absolutely as well as every guy out on the trails with 35's. There were areas where I wasn't getting hung up or stuck where guys I was wheeling with 35's did...
So I guess it depends on where you want to go. I didn't really plan on it taking me 3 years to go from 33's to 35's, but it did, and I think I'm fairly well setup now on 35's to do the trails that I plan on being able to do. It's not well setup for everywhere, but build it for the terrain you wheel in!
2014 WK2 Overland 5.7L - LEASE TURN IN
2017 WK2 Overland
SuperWade2 is offline
post #17 of 64 Old 08-05-2010, 08:35 PM
inglisleslie
Originally Posted by jforse View Post
Yes, but it is considerably more $$ to move to 35's. How often do you hit the trail?
not as much as the jump from 35 to 37...its WAAAY cheaper to go from 33s to 35s. And if your car is stick then downshifting can help with braking alot
/l ,[ ______],
l---l_--OllllllllO- My BUILD Thread----> http://www.jeepforum.com/forum/f22/white-l-cog-1074040/index10.html
()_) ()_)--O-)_)
inglisleslie is offline
post #18 of 64 Old 08-05-2010, 08:49 PM
Benderff
Benderff's Avatar
Not really....
Benderff is offline
post #19 of 64 Old 08-05-2010, 09:03 PM
inglisleslie
Originally Posted by Benderff View Post
Not really....
Just the price of the tires!
33" about $200
35" about $250
37" about $350
With 37"s you will want 5.13 gearing which means your dana 30 carrier is useless. You will need upgraded shafts on whatever rear axle your running (44, 8.8, 60 if your lucky!) With these axles hopefully you have rear disc brakes...I have seen many people with 4.0L standard transmission on 35" with the stock dana 35 with the super kit or with just upgraded shafts and still running rear drum brakes...although I dont recommend it...having the ability to downshift definitely aids in the "slowing down" process
/l ,[ ______],
()_) ()_)--O-)_)
post #20 of 64 Old 08-05-2010, 09:13 PM
viperbluelx
It all depends on what you want to spend. Me, I'm keeping my 33's and saving for everything I need to do a tummy tuck. I'd much prefer that over the guys that run 35's with a stock skid and transfer case drop cause they are always getting hung up on everything.
04 Rubicon, 5.5" RE LA with Tri-link, 35" KM2, 4.88's
viperbluelx is offline
post #21 of 64 Old 08-05-2010, 09:20 PM
Benderff
Benderff's Avatar
Your threads make me laugh... My previous post was refering to your idea that downshifting would make up for lack of brakes.
33" about $200
35" about $250
37" about $350
Benderff is offline
post #22 of 64 Old 08-05-2010, 09:48 PM
redsoxski
redsoxski's Avatar
I put together a pretty good build package for running 33's and I have no regrets. I'm running the smallest tires of all the Jeeps in my club and I'm able to run all the trails they do. Yes, I drag a bit more, have to pick my lines better and get a chance to use my winch more but I don't mind it at all. The other advantages are that its easier to climb into, I can drive to the trails, don't have to trailer and the medium trails aren't "boring". My rig is a good all around rig - good on the road, good on the trail. Another advantage is I seem to break a lot less than the bigger rigs that are putting more stress on the components. All I would have to do to go to 35's is add a bit of fender clearance but I'm really happy with the way it is now.
redsoxski is offline
post #23 of 64 Old 08-05-2010, 09:55 PM
inglisleslie
i agree nothing beats the real thing...aka a big brake kit...And why do my threads make you laugh? I ask questions about others opinions and i have learned so much in the past 6 months from this forum. You have to know nothing to appreciate what you have learned...and trust me i have just started leaning about jeep stuff...I dont have a father who is mechanically inclined to teach me anything so all the stuff i lean i teach myself...I wish i was as lucky as some of you guys and could wheel with my pops and have him teach me lots of cool tricks...Maybe i can at least learn as much as i can so i can pass it down to my kids
Nothing beats bigger brakes
I do know from DH biking that the front brakes are about 65-70% of your power
/l ,[ ______],
()_) ()_)--O-)_)
post #24 of 64 Old 08-05-2010, 11:27 PM
loaderopp
consider this, the difference is 1 inch from ground to center of hub. between 35's and 33's
Built not bought!!!
2005 Rubicon Unlimited, 5.5 inch custom long arm, 1 inch daystar body lift, River Raider Snorkel, Custom bumper/winch mount, sliders, tire carrier. 37x13.50 R17 Nitto Mudgraplers, Bushwacker flat fender. Custom 1/2 cab. Hyline hood vents. Custom tonnue cover and tool box. HID-X off road lights, LED driving lights custom rear bumper/m6000 rear monted winch.
loaderopp is offline
post #25 of 64 Old 08-05-2010, 11:31 PM
DH19922010
You'll want 35's down the road trust me. I have 33's and haven.t had much trouble on the trails i've done and still want 35's. I just need to get a currie lift, upgrade my brakes, and some chromo axles up front.......... So three grand basically
My advice would be to get the hp30 no matter what because it'd only cost you three hundred more and you'll get an arb and on overall better axle. And you'll want 35's anways.
DH19922010 is offline
post #26 of 64 Old 08-05-2010, 11:44 PM
Jon_Alex
I have 33s now and am not sure whether I want 35s. My 33s will do the toughest trails in norcal... plus they're more manageable than 35s in every other condition. Think about a Land Rover. See any Defender 90s on 35s? That's because you don't need 35s unless you're running the Hammers in socal or something, and other than that it just raises your cog up that much higher. Getting your diffs higher is not that big of a deal, and most rocks are not big enough to require 35s. Not on the Rubicon, not on Fordyce.
Of course, when I say you don't need 35s... I mean you don't NEED them... the only advantage I can think of is that you can do certain things a little faster.
On 33s my Jeep looks sane. On 35s you're getting to the point of resembling a moving cube... people spending thousands of dollars to put slightly larger tires on a vehicle that will never be a buggy anyway... not always an advantage, although that's not to say I find it unreasonable. It's just debatable.
KJ6HYE
"Convictions are more dangerous enemies of truth than lies." -Nietzsche
Jon_Alex is offline
post #27 of 64 Old 08-06-2010, 01:22 AM
SugarBear
1969 CJ5
If you're really torn between 33's and 35's, you can search for some 34's!
1969 CJ5
2.5" Rancho Kit/Shocks/Steering Stabilizer, 2" Shackles, Koenig PTO Winch, 31x10.5x15 Cooper STT's
SugarBear is offline
post #28 of 64 Old 08-06-2010, 07:28 AM
Jetscuh
O rly?
2015
I pretty much did the same thing.
I got some odd looks running a RockJock 60 with 33's.
The clearance wasn't horrible since it's a RockJock and not just a regular Dana 60 but I still was careful and didn't off road much with the 33's. When I did, it did just fine.
Jetscuh is offline
post #29 of 64 Old 08-06-2010, 08:46 AM
Noonen
1983 CJ7
You also gotta figure in the approach angle on obstacles, not just ground clearance.
Consider a 6" obstacle.
The difference between a 33" and 35" tire is approx 1.5* approach angle, the difference between 31" and 33" is almost 2*
If you bump the obstacle to 10" you are talking 2* between 33 and 35 and 2.5* between 31" and 33"
There is more to larger tires than just ground clearance, my experience has show me that 1 or 2* of rollover advantage is quite significant.
'83 1 Ton LQ4 CJ7
Noonen is offline
post #30 of 64 Old 08-06-2010, 10:18 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Don't take this the wrong way because it's not meant in a disparaging manner in the least. If you'd care to drive a bit this winter and do one day of riding along with us in JV, you would never make that last comment again.
Depending on terrain, it is not debateable in the slightlest.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
35 , 33 , tires , tj , wrangler , road manners
Torn between 33's and 35's need encouragement!! RussK JK Wrangler Technical Forum 92 01-31-2010 02:55 AM
Currently 33's, Looking to go 35's.... AFD68 TJ Wrangler Technical Forum 13 12-15-2009 11:19 AM
Im torn if your lifted running 33's or 35's help me out please Ron83CJ Wrangler General Discussion 10 03-05-2009 01:45 PM
MPG 33's vs 35's... Swindle133IWB TJ Wrangler Technical Forum 15 08-21-2006 02:25 PM
33's vs. 35's Matt P TJ Wrangler Technical Forum 10 04-15-2003 01:06 PM
