I know you guys are sick of this, but here is another Herculined jeep - JeepForum.com
post #1 of 5 Old 08-05-2006, 07:08 PM Thread Starter
jzmtl
jzmtl's Avatar
Finally got off my *** to do it after pulling the carpet and seeing surface rust, turned out not bad I would think. I took my time and removed pretty much everything, the tailgate hinge was removed, grinded, and herculined seperately. Because I was doing it bit by bit during evening time, it took me nearly a week to reach this step.
First I swept out the interior, washed with water and soap. Then I sanded all the surface with 80 grit sand paper (the scratch pad came with the kit is next to useless), wire wheeled all the surface rust, swept, washed with water and soap. After washing with soap two times xylene is pretty much a fomality, but I did it anyway. The painting is done according to instruction. I did two coats with the gallon can, but each coat was pretty thick.
Lesson learned: 1. Wear the damn coverall, I looked like a dalmation in my shorts and shirt after two coats, the roller came with the kit splatters when you roll. 2. You need the nitril gloves, xylene eats through latex under ten seconds. 3. Always leave a bit for touchup, as no matter how you roll, you will miss a spot or two. I had to dig the can out of garbage to cover two missed spots, luckily there was some undried liner still in the can to finish up. 4. The "Goo Gone" **** you buy for five bucks 200 ml is primarily xylene, pure xylene works just as good but costs 1/5 as much.
I think I'll end up putting carpet on top of it anyway for now, since due to time and financial reasons I won't be going offroad for a while.
The funny thing about this signature is that by the time you realize it doesn't say anything, it's too late for you to stop reading it.
User CP > Options > Uncheck "Show Signatures"
jzmtl is offline
post #2 of 5 Old 08-05-2006, 07:14 PM
BigPeters
looks good, did you put it on your pedals?
"...same **** , bigger pile"
Gun Metal Blue Jeep Member #25
BigPeters is offline
post #3 of 5 Old 08-05-2006, 07:15 PM
Divinitous
Disgruntled Jeepforum'er
Divinitous's Avatar
Eithor you had a good amount of rust inside the tub that was bubbling up or you had some big chinks in the herculiner. But over all it still looks good.
-Ryan
Google Voice (or the number Grape calls when drunk): 845-476-8182
Originally Posted by Enzo Ferrari
"The Jeep is Americas only real sports car!"
Originally Posted by MrBlaine
"Jeeps do not make jeepers, jeepers make Jeeps."
Divinitous is offline
post #4 of 5 Old 08-05-2006, 07:19 PM Thread Starter
jzmtl
jzmtl's Avatar
Yep I put it on the pedals, hope it won't be as slippery
There was some rust, but were grinded down to bare metal before coating. Some of the ones you see are probably due to light reflection rather than uneven surface.
jzmtl is offline
post #5 of 5 Old 08-05-2006, 07:59 PM
TJdave
TJdave's Avatar
That is awesome. I have been trying to convince myself to do this for a while.
1997 Green TJ
RE 3.5 SF Lift Kit w/ Rancho 9000 shocks
Currie AntiRock and HD steering,
KC daylighters, Warn Front bumper
and some
rock sliders all sitting on 33's
NRA Jeeper #9
Ham Radio Call: KI6KCU
TJdave is offline
Herculined The Jeep (pictures) brrempel TJ Wrangler Technical Forum 23 07-01-2014 12:59 PM
What does your herculined jeep look like cody11ca YJ Wrangler Technical Forum 9 08-08-2010 01:38 PM
Another Herculined Jeep Tub!!! 2000jeeper TJ Wrangler Technical Forum 18 08-11-2009 10:07 PM
Has anyone herculined their hole jeep? stokesj19 YJ Wrangler Technical Forum 17 04-03-2008 11:45 AM
