I keep boiling/loosing coolant??? - JeepForum.com
post #1 of 9 Old 05-29-2013, 01:12 PM Thread Starter
01-tj-mad
Ok so here goes ......New Radiator and radiator cap, New Hoses (top and bottom) New highflow thermostat housing, new thermostat, no signs of leaks (inside or outside of jeep) and I am out of coolant in a week of daily driving.
Pressure tested ok with no leaks, No smoke, no discoloration in oil or trans fluid.... NOTHING NOTHING NOTHING. I cant fugure it out
There is sometimes the sweet smell of coolant but no evidence of its where a bouts....
Any suggestions???
01-tj-mad is offline
post #2 of 9 Old 05-29-2013, 01:17 PM
NotURMailman
NotURMailman's Avatar
Try running it up to temp at idle with the hood up and waching for pin hole leaks.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #3 of 9 Old 05-29-2013, 01:22 PM Thread Starter
01-tj-mad
Should I be focusing on hoses, engine, radiator? where? everywhere?
post #4 of 9 Old 05-29-2013, 01:25 PM
NotURMailman
Once it heats up (make sure the cooling system is full first) check around the entire cooling system.
Have you checked around the water pump weep hole really good for burnt coolant residue?
post #5 of 9 Old 05-29-2013, 01:30 PM Thread Starter
01-tj-mad
Ok im on it ill be back soon with results thanks for taking time to answer me
post #6 of 9 Old 05-29-2013, 01:36 PM
NotURMailman
Sorry I didn't have anything more specific, but it has to be going somewhere. And those slow leaks can hit hot engine components and evaporate befoer they can drip or make a wet spot.
post #7 of 9 Old 05-29-2013, 01:36 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
Check near the exhaust manifold, if it leaks there the exhaust will burn it away with no signs of a leak. If you can't find a leak you may have a blown headgasket.
RnEmOvr is offline
post #8 of 9 Old 05-29-2013, 01:45 PM
Yankee-Juliet
This happened to me once. Turned out I had an air pocket inside the engine so it was not completely full of coolant. When the engine got hot the thermostat would open and suck the coolant into the block. This made my coolant level look low and since there was not enough coolant anyway, it would get hot. Try taking off the radiator cap, let the engine run and as it heats up keep adding coolant. Once you have been at normal operating temp for a while and the rad is full you should be good. Hope this helps.
BTW: If this does not help, pull the thermostat and check it. I have gotten bad ones before and a buddy of mine even installed one upside down.
"I reject your reality and substitute my own." ~ Adam Savage
"Dog-gone it Roy-Jean, how many times do I have to explain it to ya, when I tell ya to put a rock under the wheel, I MEAN A ROCK!!" ~ C.W. McCall
Yankee-Juliet is offline
post #9 of 9 Old 05-29-2013, 02:46 PM
Zolt
It could be an "air lock" in the system.
It could be a bad cap.
It could be a bad thermostat.
Zolt is offline
overheating
