I just removed the "Dont Remove" torx from my AX-5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > I just removed the "Dont Remove" torx from my AX-5
Amsteel Blue Synthetic Winch line Free ShippingSteering and more from Ruffstuff!Rough Country Deals at JeepHut.com
Unread 06-19-2009, 03:13 PM   #1
LandoCommando
Thinking it was the fill port.
How deep of **** am I in?
Signatures are for attention whores.
Oh the irony.
LandoCommando is offline   Reply With Quote
Unread 06-19-2009, 03:38 PM   #2
Mean Max
Don't poke the bear
Mean Max's Avatar
As long as you put it right back in, you should be fine.
Max
Click here to see all of my different albums on Photobucket.
Choose any album to see all of my pics!
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline   Reply With Quote
Unread 06-19-2009, 03:41 PM   #3
JeSimmers
its just another plug that is positioned lower than the regular fill plug, it hurts absolutely nothing to remove it, just dont use that hole to refill your trans because using that hole lowers the fluid capacity because of its position.
Red Jeep Club Member #454
JeSimmers is offline   Reply With Quote
Unread 06-19-2009, 04:34 PM   #4
LandoCommando
I thought I read somewhere that it keeps things aligned in there or something along those lines
Oh the irony.
Unread 06-19-2009, 06:50 PM   #5
Mini-Me26
I read the Moon is made of cheese.
Mini-Me26 is offline   Reply With Quote
Unread 06-19-2009, 08:32 PM   #6
LandoCommando
Oh ill find it now....
Oh the irony.
Unread 06-19-2009, 08:35 PM   #7
LandoCommando
After a brief period of searching through my history I found it.
http://www.moabjeeper.com/articles/t...?articleID=488
All the way at the bottom:
"A final word of caution for those that don't follow directions too well(that means most of us guys). On the drivers side is another bolt that looks very similar to the fill plug located on the PASSENGER SIDE. If you start eye-balling that driver side bolt, and you get the urge to remove it, STOP and heed the advise stamped on the bolt - "DO NOT REMOVE". There is a reason for this. The bolt is used to keep the internals of your transmission in there proper alignment."
Oh the irony.
