i have a TJ np231/ax5 in my YJ, need linkage help - JeepForum.com
post #1 of 2 Old 01-09-2010, 04:22 PM Thread Starter
SteveJcoYJ
i have a np231 out of a tj in my yj, i have been unable to solve my issue for linkage. the yj system wont work for it
it seems the arm on the case works in the opposite way then the YJ case did
i've tried making linkage for it before and nothing seems to work right
could someone give me a pic of their linkage, or a custom linkage they made to rid of the body mounted mechanism ?
quadratec carrys a tj transfercase shifter correection bracket that rids of the body mount, http://www.quadratec.com/products/52554_210.htm , i'll buy that if i know it will correct my problem, any experiences ?
SteveJcoYJ is offline
post #2 of 2 Old 03-06-2012, 10:25 AM
TJTimbo
Same Problem
I know this is a old thread , i was just wondering how you fixed this problem. I have similar linkage problems in my Tj because i used a YJ transfer case.
TJTimbo is offline
BA10/5 with NP231...4WD shift linkage? Toms87 YJ Wrangler Technical Forum 5 05-08-2009 08:52 PM
NP231 Linkage removal 95wrangler4life YJ Wrangler Technical Forum 13 12-22-2008 02:53 AM
NP231 Shift Linkage themoneypit YJ Wrangler Technical Forum 2 01-18-2007 05:34 AM
NP231 Transfer case shift linkage jeepgiant YJ Wrangler Technical Forum 2 09-05-2005 08:49 PM
Questions about Swapping out Old NP231 for New NP231 computerguy YJ Wrangler Technical Forum 2 08-11-2004 02:42 PM
