I have a serious Question that needs to be answered. (4wd light and t-case shifting) - JeepForum.com
post #1 of 18 Old 06-28-2010, 08:01 PM Thread Starter
SOLIDJP44
Guys im having a problem, ever since i installed my body lift on my jeep (rough country 1.25) my 4wd part time light on the dash no longer comes on and i need to know why. Also im having a problem if i dont catch 4 high just right it seems to make a free spin or a grinding whine, and im really getting pissed over this. I called the guys at rough Country and said they never have a problem with body lifts. I do have a small tc drop and i had to add the bracket for the 4wd linkage. Why is this becoming minor into a nightmare. is there anything i need to do, i do notice when i take it out of 4wd i do tend to get a slight shudder down near the transmission tunnel almost like something is bouncing around down there. I never had this issue before the body lift. Id liek to leave it on but it may be coming off due to im so ticked at the moment. Anything guys please respond...thank you Nate.
-00 Mildly Modified Wrangler SporT-Sold
2011 GMC ALL/Terrain Sierra z71-Current
SILVER JEEP CLUB MEMBER #55
SOLIDJP44 is offline
post #2 of 18 Old 06-28-2010, 08:06 PM
Sweeney
You may just need to adjust the transfer case shifter linkage. Do a search for the procedure.
Sweeney is offline
post #3 of 18 Old 06-28-2010, 08:09 PM
wushaw
Rockin jeep
wushaw's Avatar
Yup, xfer case adjustment will fix ya right up.
wushaw is offline
post #4 of 18 Old 06-28-2010, 08:14 PM
KKiowaTJ
Sounds like binding in the linkage. Loosen it all up and and re tighten it on level ground. I had the best luck with the adjusting it so 4lo engages perfect and never pops out on side hills. But it sounds like the the tub bracket is causing most of your problem. Good luck
MOPAR!
KKiowaTJ is offline
post #5 of 18 Old 06-28-2010, 08:32 PM
moonshinefuel
You called RoughCountry, they said, they never had a problem with body lifts..Now that is rich. How can you not like that response.
moonshinefuel is offline
post #6 of 18 Old 06-28-2010, 10:02 PM
phillies4752
phillies4752's Avatar
Its the linkage. I had the same problem with mine. Loosen the bolt that holds the shaft in place and slide it forwards a believe. You might need to give it a little tap if its rusty. Find the sweet spot and tighten back down.
phillies4752 is offline
post #7 of 18 Old 06-29-2010, 07:53 AM Thread Starter
SOLIDJP44
will the light come back on then, when you say linkage you mean the the factory tab needs to be bent
post #8 of 18 Old 06-29-2010, 08:09 AM
phillies4752
I didn't have to bend anything. On your RC 1.25 body lift it should show you on the back of the instructions. It did on mine
post #9 of 18 Old 06-29-2010, 08:11 AM Thread Starter
SOLIDJP44
I have studied these instructions, i loosened everythign and re tighten everything. Id like to know why the light won't come on though
post #10 of 18 Old 06-29-2010, 08:22 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
I edited your thread title. It helps to put the problem right there rather than having a vague title.
The light not working is most likely the switch which is located on the driver side of the t-case.
It has 2 wires. One is a ground (black) and it runs to the passenger, rear of the engine block. The other wire goes to the gauge cluster an it is black and red.
Here is how to diagnose the problem:
(1) Check the fuse in the fuseblock module. (Fuse #10 behind the glove box, 10 amp)
If OK, go to Step 2. If not OK, repair the shorted circuit or
component as required and replace the faulty fuse.
(2) Turn the ignition switch to the On position.
Check for battery voltage at the fuse in the fuseblock
module. If OK, go to Step 3. If not OK, repair the
open circuit to the ignition switch as required.
(3) Turn the ignition switch to the Off position.
Disconnect and isolate the battery negative cable.
Unplug the transfer case switch wire harness connector.
Check for continuity between the ground circuit
cavity of the transfer case switch wire harness connector
and a good ground. There should be continuity.
If OK, go to Step 4. If not OK, repair the open
circuit to ground as required. The ground is cavity B, the same cavity that the solid black wire uses.
(4) Connect the battery negative cable. Turn the
ignition switch to the On position. Install a jumper
wire between the part time four wheel drive indicator
lamp driver circuit cavity (cavity A, black and red wire)
wire harness connector and a good ground. The fourwheel
drive indicator lamp should light. If OK,
replace the faulty transfer case switch. If not OK, go
to Step 5.
(5) Turn the ignition switch to the Off position.
Remove the instrument cluster. With the transfer
case switch wire harness connector still unplugged,
check for continuity between the part time four
wheel drive indicator lamp driver circuit cavity of the
right instrument cluster wire harness connector (con-
nector B) and a good ground. There should be no continuity.
If OK, go to Step 6. If not OK, repair the
short circuit as required.
(6) Check for continuity between the part time
four wheel drive indicator lamp driver circuit cavities
of the right instrument cluster wire harness connector
(connector B) and the transfer case switch wire
harness connector. There should be continuity. If OK,
replace the faulty bulb. If not OK, repair the open
Wheelin98TJ is offline
post #11 of 18 Old 06-29-2010, 08:33 AM Thread Starter
SOLIDJP44
to Step 5.
wow, thanks man im going to check this now, what would cause a thumping noise from the transmission tunnel though?
post #12 of 18 Old 06-29-2010, 08:45 AM
Wheelin98TJ
JEEP FREAK
Did you install a t-case bracket with the body lift?
A common cause for knocking when taking off is the t-case shifter linkage. Here is more info:
Jeep TJ Transfer Case Shifter Knocking TSB
post #13 of 18 Old 06-29-2010, 01:25 PM Thread Starter
SOLIDJP44
I think this is exactly my problem, now i wonder if i should take it in and mention something although its 10 years later....what to do
post #14 of 18 Old 06-29-2010, 01:27 PM
Wheelin98TJ
JEEP FREAK
A TSB is not a recall where it gets fixed for free.
Its just advice for the Jeep techs on how to fix the problem.
post #15 of 18 Old 06-29-2010, 02:54 PM Thread Starter
SOLIDJP44
if i was to take it in and mention it they should fix it is what your saying? if im understanding this correctly. thanks and sorry if i misread that, nate.
4wd light , transfer case
Answered my squeak question, RF U-joint going bad-advice blackattak TJ Wrangler Technical Forum 3 07-30-2009 07:52 PM
Need Clutch question answered BigDon Wrangler General Discussion 1 06-23-2009 02:35 PM
tire size question answered Obcean2 YJ Wrangler Technical Forum 0 01-04-2008 07:20 PM
Need a quick lift question answered The owl TJ Wrangler Technical Forum 5 01-20-2007 02:38 PM
need real quick question answered... BlueTJMCRT TJ Wrangler Technical Forum 7 12-19-2006 07:56 PM
