I Gotta Lift Question - JeepForum.com
post #1 of 5 Old 07-17-2003, 12:39 AM Thread Starter
zzquik
zzquik's Avatar
Ok, I noticed how it said that the Rubi in the new Tomb Raider movie had a 4" susp. lift and 35" tires. Is that possible? If so, is it recommended. I thought that for every one inch lift you get you go up one inch in tire. Im still contemplating on what lift to get and how big..I want to fit 35's but I dont know how big a lift you have to get. I was thinking about 3 in susp. 2 in body but now I dont know.. I would appreciated the feedback
zzquik is offline
post #2 of 5 Old 07-17-2003, 02:32 AM
cspann
cspann's Avatar
wrong section
not to be a smart ***, but i think you might get more feedback if you posted in the LIFTS/SHOCKS/TIRES section... Good luck
1997 Black on Yellow
4.0 Manual
Rubicon Express 3.5" 33 BFG's
Locked up front
ATOZ rockers (the best Ive found)
a litle bit of armor, more to come
Super 35 w\Detroit coming in soon.
and then sum.........
cspann is offline
post #3 of 5 Old 07-17-2003, 12:32 PM
macb
macb's Avatar
you should probably post in the lift section...is this a rubi your talking about?
2" body won't look very good, seen it - yuck, I got a buddy with 4.5" lift on a rubi and 33s and it will stuff em pretty good but they don't rub.
3.5" Terraflex, 1" BL, Flat Belly Pan, Currie Steering, 35s, Cowl Intake, blah blah blah:
Bob Supplee:
or (405) 799-8977
Stu Olson's great jeep resource site:
macb is offline
post #4 of 5 Old 07-17-2003, 01:57 PM
TotalJeep
3" suspension lift w/2" BL will work but it's not the best set up for 35's. Either go 6" lift or 4" lift w/1" BL for the 35's. If you want to get real expensive you could run the Tera-Flex 4" long arm LCG kit. In a recent review of the Tera-Flex 4" long arm LCG kit the jeep w/the system ran 37's. The magazine was 4wheeldrive and sport utility.
RE 4.5 kit or 5.5 kit would also work well w/35's. Good luck
TotalJeep is offline
post #5 of 5 Old 07-17-2003, 08:53 PM
KILLERtj
KILLERtj's Avatar
Heres the Jeep I know:
1. RE4.5" lift running 35's--no prob
2. Tera 4"w/ 1" spring spacers and 1" BL running 35's--no prob
3. Tera 4" long arm running 35's--no prob
4. RE4.5" lift running 37's--added washers to keep from rubbing
All of those Jeeps are Rubicons and they all have had no problems with running 35's or bigger. You may have to lift the amount the tire stuffs into the fender. The tire still droops a lot and they get plenty of flex. I got a 02 SE and I am going to be running 35's with a 4" Tera and a 1" BL.
Peace Out
KILLERtj
Red Jeep Club #5
Vampire Jeep Club #6
02 Wrangler SE, Ford 8.8, 4.88's, Tera-Flex S4T, 35" MTR's
Faster than a Ferrari on rocks!
KILLERtj is offline
Lifting my TJ....Gotta Question Piercedfister TJ Wrangler Technical Forum 8 10-04-2007 05:00 PM
gotta cam question sleazy_peazy TJ Wrangler Technical Forum 2 06-28-2006 06:34 AM
Hey TJ'ers. . . gotta question for you kairo TJ Wrangler Technical Forum 1 09-25-2005 02:29 PM
Gotta question as a new member 1989YJNebraska YJ Wrangler Technical Forum 12 12-04-2004 07:18 AM
'bout to lift her up....gotta question. bamakrw YJ Wrangler Technical Forum 18 03-05-2004 05:46 PM
