I got very close in figuring out my drain, just need a little push...
| Rugged Ridge XHD Front Modular Bumper Systems 2007-2012 Je | REPLACEMENT SOFT TOP SALE AT BASELINE 4x4 OUTFITTERS - 88- | TJ 5.25" Speaker Adapters - NalinMFG |
#1 | |
I had a drain on the battery, so pulling all (yes all the fuses out PDC included) and the starter and alternator wires off. I disconnect the neg battery line and hooked up a tester. The light was off until I put the f6 fuse (30a) in the PDC under the hood. Then the light came back on. So what could be causing this? This has tanken all day and I pretty much tore apart my jeep looking for this drain! Thanks
www.MaDeucePaint.com Keeper of The Rattle ()==() |
#2 |
Running Secretly Amok!
First off...and the battery is how old?
#3 |
battery is only 2 days old. Brand new gold ... whatever from autozone.
Update Also when I up in the F17 fuse in the PDC it lights up the tester
www.MaDeucePaint.com Keeper of The Rattle ()==() Last edited by StupendousMan; 09-10-2010 at 08:07 PM.. |
#4 |
!!! SLAYER !!!
**'06 Blacked Out LJ** > > > LJ Owners Group < < < Black Jeep Society "We are one. One society. Digitless." "I am not a number, I am a free man!" |
#5 | |
www.MaDeucePaint.com Keeper of The Rattle ()==() Last edited by StupendousMan; 09-10-2010 at 08:51 PM.. |
#6 |
Rockin jeep
f6 goes to ASD relay and #4 injector.
f17 under hood lamp which will draw if you have the hood open with a lamp in it, left & right courtesy lamp, radio, instrument cluster, sound bar dome lamp. I would say you a light switch staying on like the hood lamp since it's hard to see with the hood closed. |
#7 | |
Any clue why ASD relay and #4 injector would be causing a short some where in the system. I replaced the ASD reply with my AC one and still something is causing a short
#8 |
Rockin jeep
So no door lamps, under dash lamps, door switch?
No clue why the wiring diagram goes there, any change when you pull the ASD relay and just leave it out? |
#9 | |
I pulled the ASD relay and still is goes as well??? I am pulling out my hair
#10 |
what you should be looking for is how much those fuses are drawing as some drianage is going to happen no matter what you do.
#11 |
Rockin jeep
I missed one thing on the # 6 fuse, it also goes to the PCM and that will draw a certain amt of milliamps but it shouldn't drain the battery down.
#17 also goes to the data link port, I didn't figure that one mattered but if you have a code reader pluged in it might. Is there any after market electrical stuff installed, if so check all of it. |
#12 |
As per your advice I went out and got a tester, and (not exactly sure if this is right) I put the meter on "DC mA" and with the negative cable off the battery I touched one end of the meter to the post and one to the cable. It read 0.01 And with the radio connected I get 0.03 Also, when I connect the light under the hood then it measures 9.97 (just doing as much testing as I can) So.... it sounds like it is fine and should not be a problem right?
#13 |
Rockin jeep
Sounds like your on the right track. Here is some good reading on elec drains.http://www.crankshaftcoalition.com/wiki/How_to_find_an_electrical_drain
#14 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
