i got mirror relocation brackets but can't see passenger mirror - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > i got mirror relocation brackets but can't see passenger mirror
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineEngo winches available at www.rockridge4wd.com! Free shipp
Unread 12-25-2006, 04:42 PM   #1
thelazerviking
what do i do about this?
thelazerviking is offline   Reply With Quote
Unread 12-25-2006, 04:45 PM   #2
JeepCreepn01
$ It's Only Money $
JeepCreepn01's Avatar
you got the ones you can only really see with the doors off, thats how mine are no big deal realy, or if you really want grab the top of the mirror and pull down it will be alittle sideways but you can see some of it
JeepCreepn01 is offline   Reply With Quote
Unread 12-25-2006, 04:55 PM   #3
thelazerviking
is there anywhere i cna get a longer arm or something?
Unread 12-25-2006, 05:20 PM   #4
gawdzkitchen
I have the same problem. What I did, was pull it in to the second click from completely closed and then pushed the mirror itself all the way out. This seems to get me through Houston traffic pretty good when the weather is really bad. The other option is, I had a friend buy a set of the trailer towing mirrors that extend out and did a little mod to them to make them work. Also, I know another guy that just stuck one of those little round mirrors on and he seems to think that its working pretty good. Just my $.02.
gawdzkitchen is offline   Reply With Quote
Unread 12-25-2006, 05:50 PM   #5
ErikJordan
Pimp Hand
ErikJordan's Avatar
post a link of the relocaters you have.
you may need to rotate the mirror so you can see it through the windshield.
___________________________________________
What is all of this talk of Savvily designed products?
ErikJordan is offline   Reply With Quote
Unread 12-25-2006, 06:07 PM   #6
BigPoppaG
Take your doors off or use your Driver mirror and rear mirror.
Not much else is going to fix it.
1998 4.0L Sport
4.5" SUPERLIFT, Warn Skid Plate, Trail Gear Rock Sliders, JKS Disco's
STEELERS RULE!!!
http://bigpoppag.blogspot.com/
http://www.mpjai.com/
BigPoppaG is offline   Reply With Quote
Unread 12-25-2006, 08:23 PM   #7
keithert
keithert's Avatar
I mounted the passenger mirror to the door in the usual place. When the doors are off I was okay with only having a driver mirror. I suppose if it was summer and the doors would be off a lot I would mount the passenger mirror to the relocator and rotate it out as others have suggested. I tried putting a convex blind spot mirror on the passenger mirror. It let me see more but wasn't all that usefull.
Current: 2005 Wrangler Unlimited - Past: 90 and 92 Trackers and 98 Wrangler SE
keithert is offline   Reply With Quote
Unread 12-25-2006, 10:14 PM   #8
Airborne4X4
1979 CJ7
I went with CJ-7 style mirrors that mounted on the windshield frame. I cut and re drilled the Passengerside mirror and postitioned it like a normal mirror would be. (Typically, the CJ-7 style mirror on the passengerside is view out through the windshield.) At anyrate, I can still only see 1/2 of it from a normal seated position. If I lean just a bit, I can enough to get by.
THere's a couple three shot of them mounted. I like the look and I like being legal.
The last pic shows (some what) how visable the passenger side mirror is.
Chrome can get you home, you can signal the search aircraft with it!
Airborne4X4 is offline   Reply With Quote
Unread 12-26-2006, 11:09 AM   #9
Y2KWRANGLER
wish I had thought of that. no mirror drives me crazy
If it Breaks it needed replacing anyways!
Canadian Jeep Club Member#1
Red Jeep Club Member #390
http://www.jeepforum.com/forum/f7/canadian-jeep-club-eh-364619/
bcjeep club.ca http://66.7.207.100/~bcjeepcl/index.php
Y2KWRANGLER is offline   Reply With Quote
