I don't know how many of you here would do this, but I am in the process and need som - JeepForum.com
post #1 of 29 Old 05-29-2007, 11:43 PM Thread Starter
charlescho
charlescho's Avatar
I need some help getting this sucker off
to those who haev done it, any pointers so I don't waste 30 wheels?
ABC - A/Ox4 - SAMPLE - OPQRST
charlescho is offline
post #2 of 29 Old 05-29-2007, 11:45 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Getting what off? Dude, we need some help with understanding exactly what you're trying to do.
Jerry Bransford is online now
post #3 of 29 Old 05-29-2007, 11:47 PM Thread Starter
charlescho
charlescho's Avatar
hahah sorry, the whole shock / coil mount from the frame with as little damage as possible....
I think I zoned out there...thanks J. B!
post #4 of 29 Old 05-29-2007, 11:49 PM
Red_
2016 KL Cherokee
Plasma cutter?
Red_ is offline
post #5 of 29 Old 05-29-2007, 11:50 PM
Jerry Bransford
Administrator
Plasma cutter and a grinder. Or torch and a grinder.
post #6 of 29 Old 05-29-2007, 11:53 PM Thread Starter
charlescho
charlescho's Avatar
I wish I had access to a plasma or a torch, I'm stuck with an angle grinder, sawzall, dremel, jsut the regular garage tools....
I think I can get it if I keep going at it, but at 1.99 / cut off wheel, it gets expensive when your using 3~4 a day....
Jerry got any other ideas?
post #7 of 29 Old 05-29-2007, 11:54 PM
dyna
AAhhh, what might I ask your trying to acomplish? If nothing else get some good cutting wheels, I can be a butcher but your work makes me look skilled.
dyna is offline
post #8 of 29 Old 05-29-2007, 11:56 PM Thread Starter
charlescho
charlescho's Avatar
other than cutting the shock/coil hoops off for coilovers?
post #9 of 29 Old 05-30-2007, 12:04 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Go to your local welding supply and get some Sait .045 4.5" cut-off discs. They zip through welds like a hot knife through warm butter.
For removing that front shock tower in it's entirety, tilt the disc at a 45 degree angle midpoint on the face of the weld. It's not welded on the top, so you only have to cut the ones you see on the outside of the frame.
Gauge your depth to keep from slicing the frame which will only take a couple of cuts for you to get the hang of.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #10 of 29 Old 05-30-2007, 09:30 AM
BoHeck
dremel .
1999 TJ 4.0 manual 4.88 on 35" Pro Comp Xtreme Muds/RE 4.5" lift 3.5" springs - RE mono shocks/Dana 44 locked with ARB - Alloy USA shafts/AA SYE Tom Wood's DS/AtoZ Fab Rockers/ 60" Hanson Prerunner Style Front Bumper/Jeeperman Rear Bumper Swing Away with Side Extensions/Bestop Sailcloth tinted/Roundeyes/Infinity Sound System
BoHeck is offline
post #11 of 29 Old 05-30-2007, 09:44 AM
silvergreentj
silvergreentj's Avatar
this was going to be my suggestion also, blaine beat me...cut the welds from the sides at an angle, you'll start seeing which way it cuts the easiest. be patient.
Slow Life-02TJ-35 Trepadors
98TJ-33 Mtzs
Low Life-87 slammed e30
silvergreentj is offline
post #12 of 29 Old 05-30-2007, 11:21 AM
jeeptj19992001
well you could of un-bolted most of it. before you started hacking it up.
think next time
03 rubi....growing bigger and better every day...
jeeptj19992001 is offline
post #13 of 29 Old 05-30-2007, 11:38 AM Thread Starter
charlescho
charlescho's Avatar
think next time
honestly I dont think there is much that can be unbolted here, it is welded on come on! think! ;p
Thanks guys got most of it off with a cut off wheel. A dremel would be nice but it overheats too fast compared to the bigger tools and the bits are so expensive
post #14 of 29 Old 05-30-2007, 11:46 AM
Jerry Bransford
Administrator
think next time
Go out and look at your own TJ and see if the shock and spring tower can be unbolted. What you will discover is that it is welded and not bolted to the frame.
post #15 of 29 Old 05-30-2007, 11:56 AM
Benderff
Benderff's Avatar
At this point I'd tow it to a large cliff and push it over, then say it was stolen......
Good luck
Benderff is offline
6:1 low range for a new process??? GodsRollerskate TJ Wrangler Technical Forum 22 01-22-2010 05:50 PM
D44 Swap Process missionAvs TJ Wrangler Technical Forum 14 09-16-2009 02:54 PM
New Process Gear cj847 Wrangler General Discussion 10 02-07-2009 08:11 AM
In the process of doing a lift, need help! 89_Sahara YJ Wrangler Technical Forum 5 10-22-2005 11:32 AM
modification process????? Jeepin_Al TJ Wrangler Technical Forum 4 06-16-2004 12:52 PM
