I'd like to put 35"s on my Tj - JeepForum.com
post #1 of 4 Old 06-21-2012, 06:57 PM Thread Starter
Colby609
Alright, so i'm ready to upgrade to 35" tires. However, I only have a 4" Rough Country suspension lift, and everything mechanical is stock. Would I be able to fit 35"s on? If not, what would I need to do to fit them? Regear? More lift?
Colby609 is offline
post #2 of 4 Old 06-21-2012, 07:04 PM
Aaron0028
what rear axle do you have? thats important. everything is stock except the lift? steering is important. gears are a big deal. brakes arent as big of a deal but are still a big deal. theres a lot of threads on this how to run 35's properly that are good to read.
Aaron0028 is offline
post #3 of 4 Old 06-21-2012, 07:07 PM
ble10
ble10 is offline
post #4 of 4 Old 06-22-2012, 01:39 PM Thread Starter
Colby609
Thanks guys.
Colby609 is offline
advice , tires , tj
Recless Driving Charge due to "Squealing tires" and "Fish-tailing" Zachnap Wrangler General Discussion 108 05-17-2012 01:49 PM
Dealer says "dirty throttle body" and needs "to flush/clean the injectors"..... WheelinTJ2004 TJ Wrangler Technical Forum 18 05-17-2010 12:54 PM
E-brake only stops the jeep when going in "R" or "N", but not "D" Gabe TJ Wrangler Technical Forum 4 02-27-2010 07:09 PM
mettalic "clank", "pop", "squeak" txpedro TJ Wrangler Technical Forum 2 03-21-2007 06:45 PM
Can't locate "Switched" and "unswitched" wire leads behind the glove box on 04 TJ Sparty TJ Wrangler Technical Forum 4 04-03-2004 02:24 PM
