I was chasing down this noise............. - JeepForum.com
post #1 of 9 Old 09-23-2012, 08:02 AM Thread Starter
meatlord
Maximum Disaster
meatlord's Avatar
......In my front end, when I came upon this.
I discovered multiple broken welds on my steering gear and brackets. The size and quality of the oem welds is pathetic to say the least. I did some quick rescue welding on it, as I was attending a jeep event early the next morning. The plan is to remove the gearbox completely and weld around the rest of it.
Anyone else have these issues, and what was done to remedy/correct/replace/upgrade. Looking for info and options at this point. My rig is not a DD, but frequently sees long trips, and drivability is a necessity.
And on a side note....I made the 2+ hrs trip to the show, and there was a good turn out this year again.
05 Rubicon "Big Stupid" / 99 XJ on 31s "Nurple" SOLD. / 07 WK Limited CRD GDE Hot Tuned DPF delete. / 00 TJ "One Shot Wonder"/ 12 Altima 3.5 SR CVT / 00 Suzuki DR650.
meatlord is offline
post #2 of 9 Old 10-14-2012, 07:34 AM Thread Starter
meatlord
Maximum Disaster
meatlord's Avatar
Bump.....anyone have this issue?
meatlord is offline
post #3 of 9 Old 10-14-2012, 10:19 AM
dmgiff
Steering box brace or hydro-assist. All the leverage you put on those big tires when you're turning against rocks will take it's toll.
dmgiff is offline
post #4 of 9 Old 10-14-2012, 07:14 PM
familyTJ
Haven't heard of that happening. But dmgiff is right.
familyTJ is offline
post #5 of 9 Old 10-14-2012, 07:49 PM
LJameson
If you're running 37s and no hydro assist, then you must have massive arms. It's no wonder why they cracked
1990 YJ
LJameson is offline
post #6 of 9 Old 10-14-2012, 08:12 PM
TheRealKTrain
JK Wrangler
Have you driven a setup like this? Power steering still does it's job, it's just welds were the weak link. Even with no power steering it's still not too bad. Don't be a wimp
"We are what we repeatedly do. Excellence, then, is not an act, but a habit." Aristotle
Μολὼν λαβέ
TheRealKTrain is offline
post #7 of 9 Old 10-14-2012, 08:23 PM Thread Starter
meatlord
Maximum Disaster
meatlord's Avatar
How about some links to any braces etc, not really looking for full hydro, but may consider an assist when I swap front axles. I am currently running a PSC pump now. The OEM welds are very subpar, I am planning on removing my steering gear and putting some beef to it when I get time.
meatlord is offline
post #8 of 9 Old 10-14-2012, 08:27 PM Thread Starter
meatlord
Maximum Disaster
meatlord's Avatar
Actually its not as bad as you would think, I have a PSC pump and steering is effortless, you really have to bind it up hard to make steering difficult. I'm looking to find a permanent fix with out going full hydro at the moment.
meatlord is offline
post #9 of 9 Old 10-14-2012, 08:32 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Quite common when you don't reinforce the box mounts or run hydro assist with tires that size.
ratmonkey is offline
failure , gearbox , steering , welds
Chasing noise for a year now. Silver yj TJ Wrangler Technical Forum 7 12-14-2010 04:04 PM
Chasing a noise..looking towards T-Case relocation Bracket. A1A-LJ TJ Wrangler Technical Forum 3 01-11-2009 02:21 PM
Chasing Vibration dtriplej6 YJ Wrangler Technical Forum 0 09-02-2008 09:31 PM
still chasing a clunk.... tman204 TJ Wrangler Technical Forum 3 01-05-2008 10:31 PM
Chasing A Smell YJHoller YJ Wrangler Technical Forum 3 11-04-2003 08:52 AM
