I am at a total loss! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > I am at a total loss!
Poison Spyder JK LED Taillight & Wiring Harness KitsPoison Spyder JK Crusher CornersPANDEMIC-USA 50" Double row LED LIGHT BAR!! These thi
Unread 06-14-2015, 05:30 PM   #1
grnt87
Hello all. I have a 2000 TJ that is pushing me to my whits end! I have no tail or brake lights. I do however have turn signals, hazards, and reverse lights. I have changed ALL fuses, headlight switch, brake switch, multi-function switch and still nothing! Any help would be greatly appreciated. Thanks in advance!
grnt87 is offline   Reply With Quote Quick reply to this message
Unread 06-14-2015, 10:08 PM   #2
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Have you checked and cleaned the 3 mounting bolts that hold your tail light assembles to the tub and the sockets that the tail light bulbs are installed in?
Filling in your profile helps when you have future questions.
Welcome to the forum...
Knuckelhead is offline   Reply With Quote Quick reply to this message
Unread 06-14-2015, 10:35 PM   #3
Jeepster83
When you replaced the multifunction switch and such in the column, did you notice the condition of the male and female sides of the plugs? We're there my burnt terminals?
And just because you're here, Knucklehead,
Being right has nothing to do with arrogance. It's only perceived that way by those that are wrong.
WyoTech West Sacramento - Graduated 8/19/2011
Back into my Jeep... finally.
Jeepster83 is offline   Reply With Quote Quick reply to this message
Unread 06-14-2015, 11:22 PM   #4
mukluk
The reverse lights, tail lights, and brake/turn lights all share the same ground, so theoretically the ground should be good as at least two of those are working... definitely couldn't hurt to check the assemblies and contacts therein to ensure you don't have corrosion though.
In the driver's footwell, outer kick panel, you'll find a large gang connector with numerous different coloured connectors plugged into it. Unplug the black one -- with the parking lights on should see 12v at pin 1 and when you apply the brakes you should see 12v at pin 7.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline   Reply With Quote Quick reply to this message
Unread 06-15-2015, 12:08 AM   #5
Knuckelhead
AFSOC Retired
The OP's multifunction switch is quite a bit different than your 2003 TJ switch...
Unread 06-15-2015, 01:57 PM   #6
grnt87
I have tried that as well. Thanks though.
Unread 06-15-2015, 01:58 PM   #7
grnt87
I will try this tonight thanks for your help. If the problem is here does that mean that assembly needs to be replaced?
Unread 06-15-2015, 11:59 PM   #8
mukluk
Depending on whether 12v is present or not at those locations will determine where you'll need to look further. Whenever you disconnect plugs/connectors such as these, always inspect them for loose or damaged pins/contacts, signs of arcing or shorts, and corrosion -- also take a look at the wires where they go into the connector and ensure that none are discoloured, burnt, or chafed. Sometimes electrical problems can be resolved simply by disconnecting and solidly reconnecting the applicable plugs in the system.
2000 TJ SE
2005 LJ Rubicon
Unread 06-16-2015, 05:31 PM   #9
billiebob
All the wiring is inside the rear wheel wells. If someone ripped out the plastic liners the wiring/connectors might be damaged.
My Uncles first Jeep was a Government Issued Jeep in 1944.
Back when ALL Jeeps were Government Issued.
billiebob is offline   Reply With Quote Quick reply to this message
Unread 06-16-2015, 08:18 PM   #10
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
Start at the kick panel. If you are getting power there then check for power (with multimeter) at the housing. You may have a broken wire in between.
RnEmOvr is offline   Reply With Quote Quick reply to this message
