Quantcast HyLine Hemi Build - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > HyLine Hemi Build
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-
Old 10-16-2009, 12:50 PM   #1
TnTCustoms
Vendor
TnTCustoms's Avatar
HyLine Hemi Build
It's time for another great build by T&T Customs! I'm calling this one our HyLine Hemi build. You thought Cody's 40's on 4" were nice how about 42" MT/R's on 4.5"? To make it all the more fun this Jeep has already gone through AEV and had a 5.7L Hemi dropped in it . Between the Hemi and the 5.13's in the ProRocks your face automatically goes when you hit the gas! The Jeep currently sits on 37's and a RE longarm system. We are going to be upgrading the suspension with our Rock-Trek Long-arm Suspension, stretching the wheelbase front and rear, installing our HyLine Full Replacement Tube Fenders and HyLine Stretch Corner Armor along with our "Guardian" front bumper, rock sliders, tire carrier, replacement rear crossmember, etc..
Here it is..
37's rubbed on 5.5"
42's
T&T Customs, Inc- GO EQUIPPED !
TnTCustoms is offline   Reply With Quote
Old 10-16-2009, 12:51 PM   #2
TnTCustoms
Vendor
TnTCustoms's Avatar
The transmission is big and is running a deep pan so we'll be fabbing a custom BP for it.
Old 10-16-2009, 12:51 PM   #3
TnTCustoms
Vendor
TnTCustoms's Avatar
On Cody's build we moved the the front axle forward to gain a couple more inches of wheelbase. We did this by rotating the steering box and moving the coil mounts on the axle along with some other modifications that I'll show later. His steering box was based off of a 4-bolt YJ box so all we had to do was notch the crossmember for clearance. This Jeep has the factory Mercedes style box which is considerably larger so just notching the crossmember was not going to be possible, it needed to be moved.
Before shot
After, using a new crossmember tube.
You can see how close the box is even to the new crossmember. We'll be making some plates to tie the new crossmember to the frame and to re-strengthen the frame rails and act as a steering box mount. I'm sure that you've noticed that the front tube is smaller than the factory one. We've been working with ORO on a custom mounting setup for their dual rate SwayLoc swaybar. Which we give a huge to! We have been running the SwayLoc on a couple of our shop rigs and after running several other brands, it is by far our favorite setup, and is getting installed on the rest of our rigs.
Old 10-16-2009, 01:01 PM   #4
Imped
TITS
Imped's Avatar
Delightful, absolutely delightful!
OlllllllO
Float Test Build
IndyORV
Best served cold
Imped is offline   Reply With Quote
Old 10-16-2009, 01:28 PM   #5
Onion22
HEMI & 42s looking forward to this build, what did you pull the HEMI out of?
-Sry bout my speling, i went too public school... an not dat offten.
- Member of "Kansas Mountain Rescue Patrol" if i see a mountain I'll rescue it.
White Rubi LJ, 6spd, 35" BFG KM2's My LJ Build Attempt
Onion22 is offline   Reply With Quote
Old 10-16-2009, 01:47 PM   #6
Unlimited04
Unlimited04's Avatar
Unlimited04 is offline   Reply With Quote
Old 10-16-2009, 01:47 PM   #7
gribbles
sweet, cant wait for more progress
indyORV
My Jeep
2000 TJ, 100" wb
2007 WK CRD
gribbles is offline   Reply With Quote
Old 10-16-2009, 02:48 PM   #8
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
Looks good. Subscribed.
Stretched TJ Future, Coil overs, 40s, 60/14 bolt
My Build Thread.
www.kifourwheelers.com www.indyorv.com
For Sale:
TJ 44 Combo, 4.88s, detroit, Alloy USA shafts, Disc Brakes, HD lower mounts, Clayton tube Truss
35" procomp tires with Aluminum wheels $650
(4) 5x4.5 steel beadlocks $200
3 11"& 2 13" BBCS shocks
Ford Dana 60 Rear $150
Big Daddy Offroad HD tie Rod
(4) 15x8 5x4.5 TJ, YJ, XJ, etc bolt pattern Aluminum wheels $175
JeepRocks86 is offline   Reply With Quote
Old 10-16-2009, 02:54 PM   #9
mcg311TJ
That's what I want to do with my build
mcg311TJ is offline   Reply With Quote
Old 10-16-2009, 03:01 PM   #10
jasonv1234
Man that rig was nuts before, I can't wait to see it now when its completed!
jasonv1234 is offline   Reply With Quote
Old 10-16-2009, 04:05 PM   #11
LGriffith
Awesome. Can;t wait to see this one come together. Good work
04 LJ|2.5" OME|RE arms|1" BL|ROKMEN|Savvy|33" MTZ's
LGriffith LJ Build
LGriffith is offline   Reply With Quote
Old 10-16-2009, 06:59 PM   #12
Bennettj13
I'm a big meanie head
Bennettj13's Avatar
It's going to be sexy as hell Rod. You need to talk the owner into doing the rear stretch corners with the wraparound flares. Those are amazing. Great job guys.
::SELLING::
Bennettj13 is online now   Reply With Quote
Old 10-16-2009, 09:14 PM   #13
Wrenchands
Wrenchands's Avatar
1995 XJ Cherokee
Subscribed...
TNT 5.5", 35 x 12.5 MTRs on Trail Ready Beadlocks
Armor: 2x6 inch 3/16 tube rockers, Factory Front and Gas Tank skids, Homemade Mini Skids, Riddler Differential Covers, and Homebrew Hybrid cage.
Recovery: AJs Offroad Custom Front Winch Bumper and Rear Tanker Bumper with Homebrew Tire Carrier/Stinger.
Rhinolined entire Exterior black, and Herculined interior.
Axles: 4.56 superior gears in D30 and 8.25 with 29 spline.
Steering: Currie Extreme and PSC Hydro-assist
Cardomain: http://www.cardomain.com/ride/2973108
Wrenchands is offline   Reply With Quote
Old 10-16-2009, 09:31 PM   #14
Okanagan_TJ
Definitely want to see this
04 TJ RME | 4.0L 5 Speed | Dana 30/Dana 44 3:73 Gears | 33x12.50x15 GY Duratrac | 3" BDS | Currie Currectlync HD Steering | EBC Brake Upgrade | Gibson Exhaust | HID Headlight Conversion | Edge Trail Jammer Throttle Body & Module | AEM Brute Force CAI | AMSOIL Synthetic |
Okanagan_TJ is offline   Reply With Quote
Old 10-16-2009, 09:57 PM   #15
LJman06
what will eventually become of my LJ
Stock LJ...........for now
"If you ain't first you're last"
LJman06 is offline   Reply With Quote
Glock Forum
