hydrolocked engine... - JeepForum.com
post #1 of 17 Old 04-11-2008, 06:16 AM Thread Starter
Baller_63
Baller_63's Avatar
So I got into a hole that was alot deeper than i thought and i hydrolocked my engine. Looking for a direct replacement for my 2000 4.0 with a 5spd what years will mate up without any issues?
Thanks,
Zac
Baller_63 is offline
post #2 of 17 Old 04-11-2008, 06:27 AM
Haik
supaJEEP
Haik's Avatar
97-02 guaranteed. If I'm not mistaken the engine has been on the chrysler computer since 1991 but I'm not certain if the plugs are all the same for anything earlier than '97. Anything later than '02, maybe someone who knows for sure can chime in? I don't believe any changes were made right up to the end of the TJ era, but I can't find documentation to support that. Google has failed me.
http://www.jeepforum.com/wiki/index.php/4.0L_I-6
Haik
-SOLD- White Jeep Club Member #8675309
Rubicon Express 5.5" Long Arm Lift Kit - Advance Adapters SYE w/ Custom driveshaft
35" SuperSwamper Boggers - SMF rear bumper w/ swingout tire carrier
Cobra 75 WX ST - Firestick II 5' - PIAA 520 - PIAA 525 - 488 Gears - Detroit Locker
SMF front
bumper w/ bull bar - Warn 9500ti winch
Haik is offline
post #3 of 17 Old 04-11-2008, 08:24 AM
RED107
4.0
I believe that 97-99 are the same but in 00 they got rid of the distributor. The engine wire harness is a little different as well.
02 Sport 4.5 Inch Rubicon Express Long Arm
15X8 American eagle 185 w/35/1250/15 BFG KM2's, BushWacker Pocket 6 inch Fender Flares
Warn Bumpers Front and Rear Warn XD9000I /rear Disc
RED107 is offline
post #4 of 17 Old 04-11-2008, 08:26 AM
EvilM0nkey
EvilM0nkey's Avatar
and starting in 02 they improved the head IIRC. Are you sure the engine is blown? If there isn't anything obviously broken it could be a good time to do a stroker.
-Ross
EvilM0nkey is offline
post #5 of 17 Old 04-11-2008, 08:27 AM
LeftoverSalmon
LeftoverSalmon's Avatar
Time for a stroker!
LeftoverSalmon is offline
post #6 of 17 Old 04-11-2008, 10:07 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Did you actually bend something in the engine? Have you done all the usual stuff to an engine that sucked in some water such as removing all the plugs and cranking the engine to pump the water out?
Jerry Bransford is offline
post #7 of 17 Old 04-11-2008, 10:12 AM
Zew
Zew's Avatar
As i said in my email to you the 97 to early 99's are the same, the late 99's and up have no distributor, and run coil packs. They also changed the cam so that they use a different cam sprocket and cam retention plate.
If you're looking to put a 4.0 back in it you need to get a 2000 and up engine.
Just buy my 318 swap
Zew is offline
post #8 of 17 Old 04-11-2008, 11:42 AM
03silversport
The OP is a friend of mine and lives in my home town. He told me last night he shot a rod through the bottom of his oil pan, says it is about the size a .22 caliber round would make.
03silversport is offline
post #9 of 17 Old 04-11-2008, 12:00 PM Thread Starter
Baller_63
Baller_63's Avatar
yep its hydro locked i got all the water out of the engine and it threw a rod out of #1 cylinder... Got a hole in the bottom of the oil pan Zew your 318 is sounding better and better I dont know if the computer is good as well as all the engine accessories
post #10 of 17 Old 04-11-2008, 12:21 PM
tebriel
is that totally true though? if he's just replacing the "block" then all the rest of his stuff from the 00 will bolt up to the new engine.
-teb
tebriel is offline
post #11 of 17 Old 04-11-2008, 02:08 PM
Zew
Zew's Avatar
-teb
There are bosses on the 00 and up engines to bolt the coil packs to. The older 97-99 blocks dont have them. I'm sure there's other things about the two different year groups, but this is just a few things i've learned while looking up stroker builds.
Zew is offline
post #12 of 17 Old 04-11-2008, 02:34 PM
EvilM0nkey
EvilM0nkey's Avatar
the computer is fine. it's water sealed. most of the engine accessories are probably good too.
-Ross
post #13 of 17 Old 04-11-2008, 05:42 PM Thread Starter
Baller_63
Baller_63's Avatar
ins called me back and they are considering the vehicle a total loss I do not have the option to buy it back since it is not 9yrs old.... Thought about canceling the claim but they are giving me 15,000 out of it and thats enough to pay off loan and reimburse me for most of my after market acc... Rest in piece my jeep time for a new project jeep going to look at 4dr jks and a few used tjs today
post #14 of 17 Old 04-11-2008, 07:08 PM
87warrior
87warrior's Avatar
I bought my rubi in 03 with TWO rods pushed through the oil pan. The other 4 have beautiful arcs in them I purchased it from an insurance salvage sale; had 12,000 miles on it and still had that new car smell. My title reads : Previously had flood damage
To make it easy on your life, get any 4.0 2000-2006. These have the Coil rail and camshaft position sensor. Any 4.0 from any model; TJ, WJ, XJ - auto or manual will work. I stuck a 2000 WJ 4.0 w/ 18,000miles in my rubi while rebuilding the stock 4.0. I found it for $800 bucks and was shipped up from Houston to the local scrap yard. You would probably need to swap over a few sesnors as the plugs can differ b/w models. IIRC I had to swap over my TPS and oil sending unit.
Please do not make the same mistake I made by getting a replacement or simply rebuilding..... STROKE IT. Has I known a Jeep (amc) 4.0 was built just like a small block chevy before hand, it would have been no problem.
An encouragment picture:
FWIW: I would rather replace the engine over dropping the tranny ANY day
03
(Rubicon build)
92
(92/99 Comanche Project)
86
(Heavy Four)
87warrior is offline
post #15 of 17 Old 04-11-2008, 08:02 PM Thread Starter
Baller_63
Baller_63's Avatar
to buy it back i would need a liscence from the state of ill to rebuild salvage title vehicles and go to auction to get it... Unless that said vehicle is nine yrs or older. Hey Ill jeepers its time for a fire sale all must go but you gotta have parts to replace after market parts with. Check my sig and pm me ill make sum helluva deals. Probably getting an 04 rubi next week so at least i got something to look forward to
Engine code p1281, engine cold for too long....which temperature thermostat to use? ShadowLawz TJ Wrangler Technical Forum 11 11-25-2014 11:23 AM
Who has Hydrolocked their JK luigi0523 JK Wrangler Technical Forum 1 10-29-2009 12:06 PM
Hydrolocked at 2800 miles Creashion JK Wrangler Technical Forum 35 11-10-2008 08:36 PM
Hydrolocked....new engine time raZe YJ Wrangler Technical Forum 5 09-23-2004 10:25 PM
Check engine light and engine sthal after cleaning battery posts AirborneSilva TJ Wrangler Technical Forum 4 05-26-2003 11:43 PM
