Hydraulic throwout bearing to mechanical.. - JeepForum.com
post #1 of 6 Old 01-30-2007, 09:17 PM Thread Starter
youngjeeper11
youngjeeper11's Avatar
1987 YJ Wrangler
Long story short, we put a YJ AX15 into my friends 99 wrangler 4.0l. stupidly we used a used hydraulic throwout bearing that came with the ransmission (used in YJs, not TJs) and what do you know, it started leaking like mad. So I was wondering if I can use a TJ style slave cylinder, and throwout bearing and fork, in the YJ style AX15?
TJ
Jeep 1:Used to have a 93 YJ 2.5l- 3.5" Black Diamond, Chevy TBI 5.7l V8, SM 465 4 speed, 8.8 rear( 4.10, L/S), rhinoline, Mile Marker 9000, NP 231, Had to sell it due to college
Jeep 2: 89/91 YJ, 4BT Cummins, NV4500, NP 231, Old Man Emu 2.5" suspension lift, 1" body lift.....Runs and drives, but very much a project
Interned at Novak Conversions 2 summers ago
Ask me about my 4BT Cummins Motor Mounts!!
youngjeeper11 is offline
post #2 of 6 Old 01-30-2007, 09:19 PM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Why is it leaking? How can you tell? I would think just get a new TJ TO bearing?
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline
post #3 of 6 Old 01-31-2007, 05:07 PM Thread Starter
youngjeeper11
1987 YJ Wrangler
No see, In YJ's, they did not use just a throwout bearing, fork and slave cylinder, they have an all in 1 Hydraulic throwout bearing that all mounts inside the bell housing, and are known for leaking, looks like this
http://www.novak-adapt.com/images/pi...ut_bearing.jpg
and that thing mounts on the input shaft in the bellhousing, all you see is hoses going into the bellhousing to this thing. check out the info on them on novak. problem still stands, can I get rid of the problematic hydraulic throwout bearing, and use a TJ style fork and throwout bearing, or should I just get a new hydraulic throwout bearing, have they made them any better?
TJ
post #4 of 6 Old 01-31-2007, 05:20 PM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
I would email Novak. I've gotten great customer support from them, and I didn't even buy anything! I would guess that as long as long as the AX-15 didn't change any between the TJs and YJs, you should be able to buy the TJ parts. I would go ahead and do that.
If you want to see the TJ parts, click the link in my sig for My Photobucket. Look through "The Heep" album, and there should be about 5 pics in there of inside the bel housing. I would post them here, but Photobucket is blocked at work.
Andy, KD8EIA
Grewe02 is offline
post #5 of 6 Old 01-31-2007, 05:26 PM Thread Starter
youngjeeper11
1987 YJ Wrangler
those pics definitly help, only problem is, I have no idea what the inside of the bellhousing for the jeep I have looks like...hmmm, gues ill e-mail novak
post #6 of 6 Old 01-31-2007, 05:31 PM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Let me know what they say. I'm interested.
Andy, KD8EIA
Grewe02 is offline
Pilot bearing/Throwout bearing? TJ4JT TJ Wrangler Technical Forum 9 11-03-2009 01:07 PM
spun bearing or throwout bearing bad gearhead1985 YJ Wrangler Technical Forum 5 05-30-2009 11:42 PM
Quick throwout bearing/clutch/hydraulic Q PhilipJ YJ Wrangler Technical Forum 2 09-02-2006 03:47 PM
hydraulic throwout bearing BrandonParvin YJ Wrangler Technical Forum 1 02-27-2002 02:59 AM
hydraulic throwout bearing evilpsych YJ Wrangler Technical Forum 3 12-17-2001 09:01 PM
