HVAC issues - JeepForum.com
post #1 of 7 Old 09-17-2013, 07:13 PM Thread Starter
thejohnson486
HVAC issues
So I'm having that crazy melting problem with the hvac controls.... so I replaced the switches the Climate control and the Fan Speed Selector. I also replaced the blower motor. well I get all of this done after fixing the Previous owner hack job. and the blower is not working. any ideas where to start? I think its something with the switch but not sure.
thejohnson486 is offline
post #2 of 7 Old 09-17-2013, 07:48 PM
Hammond_Egger
Check the blower motor resistor and the wiring/relay going to the blower motor. Mine melted his year.
I went to the junkyard and pulled the whole harness from a Cherokee (same as TJ, and there are tons of Cherokee's in junkyards).
Hammond_Egger is offline
post #3 of 7 Old 09-17-2013, 08:01 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Are the HVAC panel plugs (or any other) melted?...
Knuckelhead is offline
post #4 of 7 Old 09-18-2013, 02:41 AM
nichelsond
Good luck,
Here is my thread .... hope it helps! I would suggest to do the relays ... I did
http://www.jeepforum.com/forum/f9/bl...ssues-1552426/
nichelsond is offline
post #5 of 7 Old 09-18-2013, 04:55 PM Thread Starter
thejohnson486
So I have power at the hvac climate Congolese but as soon I chose anything like defrosting my voltmeter is showing no volts I have no clue if its the switch or some sort of ground issue
post #6 of 7 Old 09-18-2013, 04:56 PM Thread Starter
thejohnson486
I pulled the relay it was hot
post #7 of 7 Old 09-18-2013, 07:29 PM Thread Starter
thejohnson486
Fixed iit was the relay thanks for all tour help.
