Humming sound from rear end .. - JeepForum.com
post #1 of 4 Old 06-27-2006, 06:52 AM Thread Starter
dspmans_04_X
I was wondering what would be considered as "normal" sounds or noises from a Jeep. Being a first time owner and getting used to the differences. I have an 04 "X" and when giving it throttle at any speed I hear a humming noise from the rear end (not the tires). If I let off the gas the sound dissappears. It's an automatic with a lift on 33" tires. I just purchased the vehicle a week ago from a dealer and they have no info on the lift installed, so I don't know what has been done to it exactly. I have tried to contact previous owner to get this information. It only has 28700 miles and still under warranty, but depending on how this lift was installed, I'm wondering if that will void anything.
Specs that I know, 4.0, automatic, 3.73, Pro Comp lift (unsure amount of lift, guessing 3 - 4 inch possible), 33 x 12.5 x 15 tires
Any info is greatly appreciated.
dspmans_04_X is offline
post #2 of 4 Old 06-27-2006, 07:05 AM
HOSS1
Sounds asif its been re-geared. At any rate the ring gear sounds to be going out. Pinion depth not set right.
HOSS1 is offline
post #3 of 4 Old 06-27-2006, 07:11 AM
FlexyTJ
FlexyTJ's Avatar
I'd like to know how you came to this thoughtful conclusion?
As for the sound, Jeeps have drivetrain noise. How much depends. Good luck determining what is a normal sounding jeep drivetrain over the internet
MK Motorsport & Fabrication
FlexyTJ is offline
post #4 of 4 Old 06-27-2006, 07:39 AM
fisher836
fisher836's Avatar
If it's a Dana 35, it's thinking about when it's going to implode. If it's Dana 44, it's thinking about when it's going to see a set of Superior axles.
Definition of Rubicon:
A limit that when passed or exceeded permits of no return and typically results in irrevocable commitment.
fisher836 is offline
random squeak/wierd humming sound eclipse27 TJ Wrangler Technical Forum 1 11-06-2008 07:21 PM
humming sound nicksbar YJ Wrangler Technical Forum 12 05-18-2008 02:22 PM
Weird Humming sound when engine turned off Jeep'nSon TJ Wrangler Technical Forum 7 06-07-2007 03:45 PM
Pop sound from rear end jtfannin TJ Wrangler Technical Forum 23 12-25-2006 07:02 PM
Humming sound from under the hood??? 89JEEPNYC YJ Wrangler Technical Forum 0 03-22-2002 09:53 AM
