Hummer snorkel is in (Pics) - JeepForum.com
post #1 of 33 Old 05-05-2007, 06:19 PM Thread Starter
cheesycook
Accident Prone Bonehead
cheesycook's Avatar
I finally got all the peices together based on the one made by Greg.Volkman. Ended up using the original air tube, a 3" to 2" plumbing reducer, a 3" to 3" fitting cut in two pieces, a section of 3" PVC, a PVC toilet base, an H1 snorkel top off ebay, some Autozone ricer tubing, and an airbox off a 1992 Olds Ciera(same as tjeeper). I was going to install it all the way on the passenger side of the cowl but was too worried about having enough room. As it was I had a real bear of a time getting the cowling back in place after the install with the ducting in place. At least taking the filter out of the cowl I don't have to go in there anymore. The new filter housing is very secure without any additional bracing and fits under the hood even with the MML and one inch TB spacer. I can still change spark plugs or check my oil without removing it. I can also pull the pipe to get the windshield down. Visibility is not really impacted any more that the intake on my old Mach 1 sticking through the hood did. After two days I get alot of looks. I am very pleased with the results even though I wish there was a way of screwing it in as a unit for easy removal. My little girl tells everyone she installed it because she helped.
Thanks to everyone who gave me advise and ideas!
98 TJ 4.0 Stick 30 Lock-Right/44 True-Track,4.56. Fire RED. Optima Red top. 3" Full Traction lift, Cragar 352 Street locks w/3.75 BS. 32" BFG AT's. Sailcloth top.
tubular fenders. AtoZ Fab rockers and front and rear bumpers. TBT sportsbar and rear spreader. VDP 6 speaker bar. 2K Intake Manifold. Tuffy Speaker lock boxes. Power inverter. Cobra CB. Magellan GPS. Bed lined tub. 3core HD radiator. Olds airbox with Hummer snokle. Besttop seat covers with heaters. All running lights LED.Steering and oil pan skids. Mile Marker PE8000 winch. Currie Anti-Rock. Olympic trunk. Tuffy Console....and Buddha on the winch. :) And a child seat stained with mud.
Hermiston, ORL
, because I don't have a clue, but Stu does!
cheesycook is offline
post #2 of 33 Old 05-05-2007, 06:20 PM
Rocky529
Rocky529's Avatar
Looks good, but doesn't that bring down your view from the inside?
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #3 of 33 Old 05-05-2007, 06:22 PM Thread Starter
cheesycook
cheesycook's Avatar
Not much to be honest. I will eventually do some fine tuning to bring it down a tad. I just want to make sure I don't hit the windsheild wiper arm. I will adjust it when I can find a more "quick disconnect" method.
Hermiston, ORL
post #4 of 33 Old 05-05-2007, 06:23 PM
IWantMyMTZ
Thats sick! good job man! A little tall though.....EVERYTHING looks awesome, down to the repainting of the cowl cover. You should consider chopping the stem in half though.....Just my Opinion. Your rig, your sweat went into it...
2005 Jeep Unlimited - 4.0L Auto.
Pretty much stock except for 31'' MTZ tires.
I have a 4 page wish list though.......
IWantMyMTZ is offline
post #5 of 33 Old 05-05-2007, 07:02 PM
stathunter
Cheesy this is the first thing that you have done that I am not 100% impresses with. My personal opinion it seems a bit too tall.
Scott
2004 Black X w/ RE LA 37" SSR's, etc etc
In Michigan? Call Jim from
"Do or do not, there is no try" Yoda
stathunter is offline
post #6 of 33 Old 05-05-2007, 07:53 PM
grymsr
Vintage Member
grymsr's Avatar
I will be very curious if "The Man" gives you any trouble about it "obscuring" your driving view. Let us know if so.
How's that Hope and Change workin for ya?
Black Jeep Club v1.0 and v2.0 #1776
2004 Rubicon
2013 JKU Sport
grymsr is offline
post #7 of 33 Old 05-05-2007, 08:01 PM
ninjajeep
ninjajeep's Avatar
Looks like a chimney to me...nice pics!
You should have ran it up and over to the windsheild pillar and then up high like the arb snorkle. You just need some angle fittings.
'01 TJ 60th Anniv. Ed.
"6 cylinders of gut wrenching torque"
ninjajeep is offline
post #8 of 33 Old 05-05-2007, 08:14 PM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
looks good. I would bring it down a little
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #9 of 33 Old 05-05-2007, 08:33 PM
BigBLue05X
I saw some guy on here with the same hummer intake, but it went as high as the bottom weather stripping of the windshield. Cool Idea though. Oh yea, I thought I was the only one around here with the hood grilles on the side. They draw a lot of attention in my area.
BigBLue05X is offline
post #10 of 33 Old 05-05-2007, 08:40 PM
jeeptillidie
jeeptillidie's Avatar
I like that 100x better than a regular snorkel. And it wont be nearly as noticable if you ever decide to ditch it.
jeeptillidie is offline
post #11 of 33 Old 05-05-2007, 08:43 PM
WILLY348
Very cool there man.. awsome job
2003 Jeep Wrangler Sport: Current Jeep
2006 Jeep Wrangler Unlimited: (Sold and missed!)
2004 Ford Mustang Cobra
WILLY348 is offline
post #12 of 33 Old 05-05-2007, 09:00 PM Thread Starter
cheesycook
cheesycook's Avatar
Yeah fellas, it will definitely be coming down some. Right now I am dropping by the local plumbing shops looking for parts I could use. An angle fitting was one of the ideas I was toying with just to sort of pivot it a bit farther to the passenger side. I will post what I come up with. One big difference I am noticing is that I don't have that high pitch turbo sound emminating from my dash that I had with the cowl filter. I am also looking for something resembling an ARB cap. Just something that the air is pushed into as opposed to something it wisks across. We will see.
Hermiston, ORL
post #13 of 33 Old 05-05-2007, 09:08 PM
BrettDez
Looks good
Definately looks cool though, even if it is a bit high.
-Brett
My Jeep: 2012 Jeep Wrangler Unlimited Rubicon, 6-Spd Manual, Cosmos Blue
"The Smurf":
Previous Jeeps:
BrettDez is offline
post #14 of 33 Old 05-05-2007, 09:09 PM
Erin Go Bragh
Erin Go Bragh's Avatar
That looks pretty cool and kinda neat how you put it together. How much did it cost for everything and how many hours did it take?
Erin Go Bragh is offline
post #15 of 33 Old 05-05-2007, 09:14 PM Thread Starter
cheesycook
cheesycook's Avatar
I would say all together it cost me around $70 including the K&N filter. I should have bought one from Accel. Theirs have more filter area.
Hermiston, ORL
Snorkel top-cover like Hummer kuebelwagen TJ Wrangler Technical Forum 8 08-20-2011 07:25 PM
Hummer Snorkel Question wrangler2007 TJ Wrangler Technical Forum 5 08-16-2009 06:35 AM
Hummer Snorkel Mod mgrammer Wrangler General Discussion 20 11-18-2008 10:45 PM
Hummer Snorkel Jakemd98 TJ Wrangler Technical Forum 3 08-31-2006 07:20 AM
Hummer Snorkel JESSETHELJ TJ Wrangler Technical Forum 6 07-07-2006 10:01 AM
