Hum and Vib From Rear - Tires, Wheel or Pinion Bearing - JeepForum.com
post #1 of 6 Old 12-07-2010, 05:42 AM Thread Starter
UncleWilson
UncleWilson's Avatar
I just rotated my tires (5 tire rotation), and Now I hear a wah wah wah with a vibration coming from the rear of the vehicle, but only at +60 mph. There is about a 1 second pause between the wah's. I for sure feel it when on the accelorator or holding constant speed. If I speed up to 70 mph and coast I think the noise goes away, or at least becomes significantly minor. I didn't have this problem prior to the tire rotation. My first inclination is this is a bearing (pinion or wheel). However, the front right tire (now on the left rear) had been driven on for ~250 miles with a slight bit too much toe in. Could it be the tire?
2006 LJ Rubi JKS BL/MML, Curries Arms, 3", UCF Skids, Riddler, 35 GY MTR W/K, Black Rock 909's, Black Magic, Rokmen Sliders, Savvy GTS, Cloaked, 4.88
o[__Q_]o
(OIIIIIO)
[]==O==[]
UncleWilson is offline
post #2 of 6 Old 12-07-2010, 05:50 AM
Fropleyqk
Fropleyqk's Avatar
2014 JK Wrangler
You rotated the tires then a new vibe popped up. Id say its the tires. Get a road force balance and if it is the tires, itll be fine.
Fropleyqk is offline
post #3 of 6 Old 12-07-2010, 10:37 AM Thread Starter
UncleWilson
Would tires create a vibe only after 60 mph or would it happen before that too?
o[__Q_]o
(OIIIIIO)
[]==O==[]
post #4 of 6 Old 12-07-2010, 10:44 AM
timberwolf0122
The vibe is a resonance frequency thing, your only hitting the right freq near 60MPH, you might get it at other speeds.
Atheist Jeep Club Member #2
Doctor Who has died 13 times, is on his 14th regeneration and has a time machine, beat that Jesus.
timberwolf0122 is offline
post #5 of 6 Old 12-07-2010, 11:01 AM
MO2500
If you had no problem before the roatation then it's the tires.
Instagram: @omsmike
MO2500 is offline
post #6 of 6 Old 12-07-2010, 11:04 AM
Fropleyqk
Fropleyqk's Avatar
2014 JK Wrangler
In my experience tire vibes happen at specific speeds. Other types of vibes tend to be more constant and or increase with speed.
pinion bearing diagnosis , tire wear , vibrations , wheel bearing
what are signs of a bad rear pinion bearing? Muddeprived TJ Wrangler Technical Forum 21 01-06-2017 03:42 PM
Rear Pinion bearing MooseMarine YJ Wrangler Technical Forum 14 05-15-2009 10:06 PM
Rear Pinion Bearing Replacement? Shannonism TJ Wrangler Technical Forum 14 04-11-2009 11:46 PM
rear pinion bearing help acerabel1 YJ Wrangler Technical Forum 7 02-18-2009 07:57 AM
rear pinion bearing? 1coppersv YJ Wrangler Technical Forum 6 10-01-2007 05:08 PM
