huge coolant leak/ creamy coolant?? - JeepForum.com
post #1 of 18 Old 12-28-2009, 05:02 PM Thread Starter
11Bgixx
Noticed coolant leak only because the heat went out on my jeep. Popped the hood to check it last night and saw some of the orange mess but it wasnt that bad. Put coolant in it. It took almost an entire jug. Went for a 4 mile drive tonight and when i got back it was pouring out of my jeep by the bucket. This is what it looks like now. Please tell me its not a head gasket.
11Bgixx is offline
post #2 of 18 Old 12-28-2009, 05:07 PM Thread Starter
11Bgixx
11Bgixx is offline
post #3 of 18 Old 12-28-2009, 05:20 PM
wushaw
Rockin jeep
wushaw's Avatar
That would be bad one blown head gasket. Get a pressure tester and pump it up and look for leaks.
wushaw is offline
post #4 of 18 Old 12-28-2009, 05:23 PM
smamas
Wash it off, fill it again, probably with water since you are going to take it apart, start it and watch for the leak. That will be easy to find.
'05 Rubi, RE4.5"LA, RE Mono's, 33"MTR's, Savvy Gas Tank Skid
smamas is offline
post #5 of 18 Old 12-28-2009, 05:26 PM
vosevichs
Is there water in your oil??? Pull the did stick
Scott Vosevich
vosevichs is offline
post #6 of 18 Old 12-28-2009, 06:42 PM
jknutter
jknutter's Avatar
Looks like a mustard milkshake... Like Vosevichs said pull the dip stick and see what it looks like. Hard to say by the pictures because considering how much is sprayed on the fender the motor actually looks pretty clean. Are you running yellow antifreeze? If so sorry to say but it is probably a head gasket...
05 Rubicon
jknutter is offline
post #7 of 18 Old 12-28-2009, 06:51 PM
mcg311TJ
I don't know why, But all of a sudden I have the need for some Indian food. Chicken Tikka Masala anyone?
mcg311TJ is offline
post #8 of 18 Old 12-28-2009, 07:47 PM
ChrisYJ - Italy
That Jeep ate too much mexican last night
sorry i couldn't resist!!!
Well i would say there is a great possibility of a dead head gasket. Follow what the fellow jeepers said and track down the leak ! Good luck!
ChrisYJ - Italy is offline
post #9 of 18 Old 12-28-2009, 09:44 PM
Bubba3200
Crazy looking stuff....tell me what brand that coolant is so I DONT buy it...LOL!!!
Bubba3200 is offline
post #10 of 18 Old 12-30-2009, 10:12 PM Thread Starter
11Bgixx
found the problem tonight.. no leak in the head gasket thank god. it was simply a bad thermostat..it was blocking the coolant from flowing right and it was getting backed up actually overflowing out of the overflow jug..the fan was blowing it all over the place and thats what caused the massive mess..And the reason that it looks like that is because the radiator is in some serious need of a good douching..I flushed it 5 times and it still has rust running out of it..But regardless its 20 degrees outside so now that its running right again i think ill wait till it warms up a touch before i flush it completely out.
11Bgixx is offline
post #11 of 18 Old 12-30-2009, 10:57 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Originally Posted by 11Bgixx View Post
it was getting backed up actually overflowing out of the overflow jug..the fan was blowing it all over the place and thats what caused the massive mess...
That's why I have all the under-hood drains routed back to mid frame (radiator over flow, washer bottle (added a drain) and A/C condensation drain). I don't like anything dripping under the engine...
Knuckelhead is offline
post #12 of 18 Old 12-30-2009, 11:23 PM
cfmiller58
good call
10 char
Black Jeep Society
cfmiller58 is offline
post #13 of 18 Old 12-31-2009, 07:26 AM
Slithering_Joe
11Bgixx, that looks like some seriously rusty water (no antifreeze/coolant) in there.
4.0L TJ
Slithering_Joe is offline
post #14 of 18 Old 12-31-2009, 08:52 AM Thread Starter
11Bgixx
Yep i flushed every ounce of coolant out of it and ran water through it multiple times flushing the system and it came out rusty every time. Its getting better but its still a filthy mess.
11Bgixx is offline
post #15 of 18 Old 01-11-2010, 01:12 AM
Ben_321
thats crazy! never seen coolant like that!
does you rad look rusty when you look in the rad cap?
if so you might want to replace it thats insanely rusty looking coolant!.
Ben_321 is offline
Coolant leak jeepin79 TJ Wrangler Technical Forum 10 03-12-2008 09:23 PM
Coolant Leak - Help Kiwi_TJ TJ Wrangler Technical Forum 9 07-19-2007 05:05 AM
Big Coolant Leak! TJeepery TJ Wrangler Technical Forum 4 04-13-2007 11:52 PM
Coolant leak help jloehle TJ Wrangler Technical Forum 14 03-22-2007 01:24 PM
Coolant leak?? J13760 YJ Wrangler Technical Forum 20 06-24-2005 08:54 AM
