hp30 swap questions - JeepForum.com
post #1 of 10 Old 02-14-2010, 06:21 PM Thread Starter
globalnomad
hp30 swap questions
I have a buddy who flipped his yj a few months ago, and is parting it out. he has a hp30 axle on it, and I was wondering if it was a good canidate to swap into my tj. I know that the axle is vacuum disconnect. Will this swap work? I saw something on stu's website about it, but was wondering if I should go through the trouble or just get a junkyard xj non disco. the reason I ask is because it has 4.10 gears, and all the ones I have found at the local pick and pull yards are not the same ratio (will be swapping a 4.10 8.8 as well)
globalnomad is offline
post #2 of 10 Old 02-14-2010, 06:25 PM
never monday
if it's cheap, go for it.
you'll need to do the CAD delete, I'd weld all the tube to casting joints.
never monday is offline
post #3 of 10 Old 02-14-2010, 06:29 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Many say the vacuum delete version is stronger on that side due to the big square housing the disco was installed in. All you need to do is replace the 2-piece axle shaft with a 1-piece replacement & screw a cover over the opening after installing a set of new internal axleshaft seals.
Getting
Jerry Bransford is offline
post #4 of 10 Old 02-14-2010, 06:33 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
And what about the control arm and coil spring mounts?...
Knuckelhead is offline
post #5 of 10 Old 02-14-2010, 06:40 PM
never monday
TREKS D30 Axle Truss
notch around the CAD housing
post #6 of 10 Old 02-14-2010, 06:49 PM
Jerry Bransford
Administrator
Whoops yeah, glad you caught that. It'd be a lot better if he found one out of an XJ since that will bolt right in. It'd be a pretty fair project to make that YJ leaf spring HP D30 fit into a coil spring TJ.
Getting
post #7 of 10 Old 02-14-2010, 06:58 PM
Knuckelhead
AFSOC Retired
I went with the XJ. That way the control arms take the beating, not the drive shaft. Hopefully...
post #8 of 10 Old 02-14-2010, 07:55 PM
Greg_Volkman
not worth it to convert a YJ HP30. You'd need new mounts. at that point, I'd just be looking at a waggy 44. Might as well find an XJ HP30. I found mine on craigslist with 4.10 gears for $100.
-0|||||||0-
He who hunts in a pack is still a dog. The lion hunts alone, and so do I. - Napoleon
Conducting an argument by appealing to authority is not using your intelligence; it is just using your memory. - Leonardo Da Vinci
Greg_Volkman is offline
post #9 of 10 Old 02-14-2010, 09:20 PM
jeepnmike
jeepnmike's Avatar
Jerry,
My buddy will sell me a complete vacuum disconnect HP D30 out of an XJ for $50. Will my TJ shafts fit in there? I don't see why not, just making sure. Thanks!!
'95 YJ- 1.25" BL, 31" bfg's, black cragars, herc'd tub. sold
'99 TJ Sport- 35's, 8.8, 4.88s, 5" RC LA, JB SS SYE, UFC TT, HD steering
jeepnmike is offline
post #10 of 10 Old 02-14-2010, 11:30 PM
Greg_Volkman
mike, they will, but you'll require new out/inner passenger seals. I did this with my TJ. Stu has a good write up on his site with part numbers...look for the "TJ shafts in a YJ" conversion article. Can't remember the part numbers off the top of my head.
I also converted the outer knuckles/hubs/rotors to 99+ TJ.
-0|||||||0-
HP30 swap thread...but this one's a how-to Kerndone TJ Wrangler Technical Forum 8 02-06-2012 07:32 PM
HP30 swap/Currie HD Steering/M.O.R.E. steering brace BigWaylon TJ Wrangler Technical Forum 32 01-02-2011 05:24 PM
HP30 swap finished Polaris TJ Wrangler Technical Forum 3 03-15-2007 09:19 PM
Hp30 4130jeeptj TJ Wrangler Technical Forum 1 02-07-2007 03:30 PM
Hp30 flip124 TJ Wrangler Technical Forum 1 02-27-2006 01:45 PM
