HP30 swap finished - JeepForum.com
post #1 of 4 Old 03-15-2007, 01:51 PM Thread Starter
Polaris
Polaris's Avatar
HP30 swap finished
I got a HP30 axle out of a late 80's XJ to bolt in to match my rear 8.8 with a ratio of 4.10. It went smoothly, except for finding an axle seal that would fit into the non-machined passenger side tube. Swapping in the axle consisted of using my TJ single piece axles and knuckles. I was told by some that the vacuum disconnect housing would need to be trashed in favor of a block-off plate, but after taking off the four bolts of the cover and removing the shift fork and sleeve, I just RTV'd it, reinstalled the screws and plugged the hole. Sounds daunting to some, but it wasn't hard at all. I did pretty mcuh the whole thing myself. HP30's offer more clearance and stronger reverse cut ring/pinion gears. I saved myself about $400 over a front regear in the process and came out with a stronger front axle. I'm surprised to not see more of this swap
Writeup and explanation of "reverse cut" gears with pics:
http://thepointbreak.org/jeep/hp30.php
Pics
http://www.thepointbreak.org/gallery...?g2_itemId=468
2000 TJ Sport, 3-speed slushbox
HP30, ChroMoly shafts, Ford 8.8 rear, 4.10s 35s
ORIGINAL Black Jeep Club Member #34
Polaris is offline
post #2 of 4 Old 03-15-2007, 02:13 PM
Varnish
Varnish's Avatar
Cool. Your second link is truncated in the middle.
'06 LJ, '88 YJ
Varnish is offline
post #3 of 4 Old 03-15-2007, 02:21 PM
dennisuello
dennisuello's Avatar
Do something like this and also weld on some control arm bracket skids. Your disconnect housing will thank you later.
dennisuello is offline
post #4 of 4 Old 03-15-2007, 09:19 PM Thread Starter
Polaris
Polaris's Avatar
Does the HP30 really need a truss?
Polaris is offline
HP30 swap thread...but this one's a how-to Kerndone TJ Wrangler Technical Forum 8 02-06-2012 07:32 PM
My 8.8 swap is finally finished! Fun2Jeep YJ Wrangler Technical Forum 26 07-10-2009 09:29 PM
Finished 8.8 swap (NOW WHAT?) bywaters TJ Wrangler Technical Forum 38 07-14-2008 08:35 AM
LS1 Swap Finished Stu Olson TJ Wrangler Technical Forum 34 11-15-2005 10:14 PM
finished 8.8 swap! dooz TJ Wrangler Technical Forum 2 01-27-2003 12:12 AM
