HP30 regear - JeepForum.com
post #1 of 2 Old 06-16-2010, 08:09 PM Thread Starter
timpenny92
HP30 regear
im regearing a HP30 for my TJ. just finished the rear axle took a while but got a good pattern and all works well. on the front new 4.10 gears, bearings, seals, ARB locker. i have done two methods to set pinion depth. first assembled with same amount of shims as original .000 yes no shims just the oil slinger and baffle. measured the checking distance and ran a pattern both very obvious, pinion to deep on the ring gear. but no shims to remove. my question, can i remove the oil baffle and or the oil slinger and be ok?
timpenny92 is offline
post #2 of 2 Old 06-21-2010, 08:34 PM Thread Starter
timpenny92
bump to the top
HP30, what else do I need? Apex TJ Wrangler Technical Forum 19 04-28-2010 11:15 PM
Do the HP30? theducksguts TJ Wrangler Technical Forum 20 02-12-2010 08:22 PM
Hp30 4130jeeptj TJ Wrangler Technical Forum 1 02-07-2007 02:30 PM
Hp30>?? drew76924 TJ Wrangler Technical Forum 2 12-03-2006 09:04 PM
HP30 from a YJ?? Bucket110 TJ Wrangler Technical Forum 5 10-07-2004 10:22 PM
