hp30 disco to non-disco conversion - JeepForum.com
post #1 of 3 Old 06-22-2005, 12:45 PM Thread Starter
Bucket110
Bucket110's Avatar
I am going to be getting a hp30 dirt cheap from a friend of mine. The only problem is that its from an older cherokee and is vac disonnect. I need to know what I need to do to run this axle in my Tj.
I know that i need to block the vac motor asseble whole but what able axle seals? I heard that i need to run a 44 axle seal or something like that...anybody know? thanx.
2002 TJ Blk, 4.0, 5spd, dual top/doors, Dana 30/44, 6", 35's, 4.88s, locked f/r, air, KC lights, CB, PSC rockers/cage/corners, m8000, flat fenders, custom front bumper, TXT rear
2003 F350 diesel....tow rig
NEJEEPZ
Bucket110 is offline
post #2 of 3 Old 06-22-2005, 12:48 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
You can get a kit from Warn that they include with their hub conversion kit that includes both the internal seal and external cover plate for the older vacuum disco axle. I'm not certain they sell that kit separately but it's worth a call to Warn's customer service.
Jerry Bransford is offline
post #3 of 3 Old 06-22-2005, 01:46 PM
penguinland
penguinland's Avatar
The seal is a spicer 42500 and the backing plate you can make yourself if you have a piece of plate, a way to cut it, a grinder and a drill. When I bought mine it already had the conversion done but it will had the vacuum unit attached. I just made a plate and changed out the seals. Here's a good write-up
http://www.madxj.com/MADXJ/technical...97andSeals.htm
2004 WJ 4.0
2" BDS springs + 3/4" spacers up front , Goodyear Duratrac 245/75R16, Yaesu FT-7900R
penguinland is offline
HP30 w/disco swapped in - What seals to use? gtxracer TJ Wrangler Technical Forum 5 11-06-2010 10:58 AM
What is a Disco and do I need them ? JeepnAZ TJ Wrangler Technical Forum 14 06-03-2008 08:37 AM
JKS Disco help Rocky5 TJ Wrangler Technical Forum 4 08-06-2007 09:12 AM
swapping in HP30 with vacuum disco into tj BK'sTJ TJ Wrangler Technical Forum 1 12-10-2006 05:03 PM
Disco or no Disco? Bethlehem TJ Wrangler Technical Forum 8 03-07-2006 04:28 PM
