HP dana 30 question - JeepForum.com
post #1 of 11 Old 11-04-2013, 09:59 PM Thread Starter
mhcblues119
HP dana 30 question
Is the carrier from a vacuum disconnect and a non-dissconnect interchangeable? Found a carrier with 4:10 gears from a vacuum disconnect and would like to swap it into a non-disco model and swap it under my TJ.
Any input would be greatly appreciated!
"Big Blue"
mhcblues119 is offline
post #2 of 11 Old 11-04-2013, 10:06 PM
rchase559
Yes. Be prepared to setup the gears though if you are swapping those in too.
If you are just using the carrier, you will just need to set backlash.
rchase559 is offline
post #3 of 11 Old 11-04-2013, 10:07 PM
BriansCJ
1994 XJ Cherokee
All dana 30 carriers are interchangable.
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #4 of 11 Old 11-04-2013, 10:14 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
But the ring and pinions are not...
Knuckelhead is offline
post #5 of 11 Old 11-04-2013, 10:19 PM Thread Starter
mhcblues119
Both of these axles are HP dana 30s. On is a disconnect one is not. The gears are already installed into the carrier inside the axle housing. I was hoping to take the carrier and gears out of the one axle and switch them into the non-disco one.
I know that the lp and hp gears are not interchangeable but the 2 diff models of HP dana 30 should be correct?
"Big Blue"
post #6 of 11 Old 11-04-2013, 10:37 PM
rchase559
Originally Posted by mhcblues119
Both of these axles are HP dana 30s. On is a disconnect one is not. The gears are already installed into the carrier inside the axle housing. I was hoping to take the carrier and gears out of the one axle and switch them into the non-disco one. I know that the lp and hp gears are not interchangeable but the 2 diff models of HP dana 30 should be correct?
Ring and pinions are not interchangeable. Once they leave the factory, they are matched set and must be used together. Using one pinion with another ring gear is not recommended at all.
You can swap both ring and pinion from on axle to another (assuming they're both HP or LP) but not just the ring gear or just the pinion.
Just to clarify, you are talking about the ring and pinion and not the spider gears correct?
post #7 of 11 Old 11-04-2013, 10:45 PM Thread Starter
mhcblues119
Correct me if im wrong. but cant i take the carrier out including (spider gears, ring and pinion) all at once? or am i misunderstanding
"Big Blue"
post #8 of 11 Old 11-04-2013, 10:48 PM
rchase559
Yes you can do that. You will more likely than not have to set the gears up in the new housing like I said in my first post.
Edit: proofread and fixed
post #9 of 11 Old 11-04-2013, 10:59 PM Thread Starter
mhcblues119
What do you mean not set that up? Shouldnt it be just a plug in play? As in i pull the axles and take out the old carrier. Instal the new carrier and then reinstall axles? This is the first time i will ever be messing with the inside of an axle so I'm new to this. I have swapped axles before but never before build one.
"Big Blue"
post #10 of 11 Old 11-05-2013, 07:11 AM
biffgnar
biffgnar's Avatar
The tolerances you are working with to do a gear setup properly are small enough that perfectly normal variations between housings can be enough to require the setup to be different one to another even using the same carrier and gears.
biffgnar is offline
post #11 of 11 Old 11-05-2013, 07:54 AM
-jb-
Swap it in, check the gear pattern. If it's to shallow or to deep, you need to adjust your gear.
Yellow Jeep Member #42
01 TJ Sport
00 TJ Sport
-jb- is offline
