#1 | |
Junior Member
HP Dana 30 or not
I was at the wrecking yard this afternoon and saw alot of cherokee's with High Pinion dana 30's. Is it be a good idea to change my low pinion to a high pinion?
#2 |
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#3 |
TITS
Sure, especially if you're going to spend the money on regearing. Might as well spend the money on a stronger axle. It's the perfect front axle for 35's or smaller. If you're considering going bigger than 35's, I'd skip straight to old school HP D44's or D60's.
#4 |
Why not? It's a bolt in...
#5 |
intentionally left blank
If you plan on leaving the front open (I would with 35's) make sure to get one with 4.10 gears so you can reuse the carrier. I bought a HP D30 for less then the cost of a new carrier. The 4 bangers came with 4.10 gears.
#6 |
Love mine. I put a TruTrac in and it works great. For a grand total of $700 give or take $20, I have a stronger axle, better gears, a TruTrac and two spring clips. They can really take a beating.
Hold onto something... Quick!!! |
#7 |
TITS
One more nice thing....they use shims to set the pinion bearing preload, not a crush sleeve.
#8 |
i also put a trutrac in my HP30 also trussed it and added vanco brakes
www.youtube.com/kgries http://photobucket.com/kgries in the 80's.... we had Ronald Reagan, Bob Hope, and Johnny Cash. Now we have Obama, No Hope, and No Cash.. |
#9 |
Junior Member
Does it matter what year it comes out of?
#10 |
This talks about differences in years
They're are a few pluses to the HP. It will automatically give you a better drive shaft angle, and you're less likely to be bashing your u-joint, plus as people have mentioned it is stronger and the 4.10 gears. I plan on doing this when I can afford gears for the rear as well. Last edited by bmxrules39; 10-11-2009 at 11:53 AM.. |
#11 |
TITS
Yes. You want a non-disco housing from (I believe) 1995-2000 XJ. HP and non-disco=good.
#12 |
#13 |
Junior Member
Will I need to modify the drive shaft or should I grab the one from the donner?
#14 |
you can go nondisco, re use your old axle shafts and install a ~$50 block off kit. That's what I did. Some people claim it cld even be stonger because of the added metal along the passenger side tube
'97 TJ Sport :4.7L STROKER:RSG AX-15 "Terminator":Accel 30lb/hr injectors:2000 intake manifold:HP Dana 30 & Ford 8.8 w/ stock LSD & 4.11s for now:RE 4.5" SF :OME Shocks:AA SYE & Dana CV shaft: MAXXIS Bighorn MTs 33x12.5R15:SRC Front & rear bumpers w/ tire carrier:Cragar Series 320 15x8s:WARN SDB-210HBs:KC slimlites Long & Fog:Bestop Replace-a-top : No Cat and Flowmaster Super 44 Offroad |
#15 |
You shld be fine. Think about it, if you're lifted this just puts the ds closer to stock height
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
